#include <reg51.h> //調用單片機頭文件
#define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
#define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
//數碼管段選定義 0 1 2 3 4 5 6 7 8 9
uchar code smg_du[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
// A B C D E F 不顯示
0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff}; //斷碼
uchar dis_smg[8] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8};
bit flag_100ms,flag_1s;
bit flag_stop = 1; //用做到了相應的樓停下
sbit beep = P3^7;
sbit xia = P3^6;
sbit zhong = P3^5;
sbit shang = P3^4;
uchar value2;
sbit led1 = P0^0; //8個發光二極管定義
sbit led2 = P0^1;
sbit led3 = P0^2;
sbit led4 = P0^3;
sbit led5 = P0^4;
sbit led6 = P0^5;
sbit led7 = P0^6;
sbit led8 = P0^7;
uchar dt_1; //1樓電梯標志位
uchar dt_2; //2樓電梯標志位
uchar dt_3; //3樓電梯標志位
uchar dt_4; //4樓電梯標志位
uchar dt_5; //5樓電梯標志位
uchar dt_6; //6樓電梯標志位
uchar dt_7; //7樓電梯標志位
uchar dt_8; //8樓電梯標志位
uchar dt_value = 1; //電梯到哪一層的變量
uchar dt_s_x ; //電梯上下的標志位
/****************獨立按鍵處理函數************************/
#define key_io P2
uchar key_can;
void key()
static uchar key_new = 0,key_old = 0,key_value = 0;
key_io = 0xff;
if(key_new == 0) //按鍵松開
if((key_io & 0xff) == 0xff)
key_value ++;
key_value = 0;
if(key_value >= 5) //按鍵松開松手檢測
key_value = 0;
key_new = 1; //按鍵松開后進入等待按鍵狀態
if((key_io & 0xff) != 0xff) //按鍵按下
key_value ++;
key_value =0;
if(key_value >= 5) //按鍵按下消抖
key_value = 0;
key_new = 0; //按鍵松開后進入等待松開按鍵狀態
key_can = 20;
if((key_new == 0) && (key_old == 1))
switch(key_io)
case 0xfe: key_can = 1; break; //得到按鍵值
case 0xfd: key_can = 2; break; //得到按鍵值
case 0xfb: key_can = 3; break; //得到按鍵值
case 0xf7: key_can = 4; break; //得到按鍵值
case 0xef: key_can = 5; break; //得到按鍵值
case 0xdf: key_can = 6; break; //得到按鍵值
case 0xbf: key_can = 7; break; //得到按鍵值
case 0x7f: key_can = 8; break; //得到按鍵值
// dis_smg[0] = smg_du[key_can];
key_old = key_new;
void key_with()
if(key_can == 1)
led1 = 0; //點亮發光二極管
dt_1 = 1; //
if(key_can == 2)
led2 = 0; //點亮發光二極管
dt_2 = 1;
if(key_can == 3)
led3 = 0; //點亮發光二極管
dt_3 = 1;
if(key_can == 4)
led4 = 0; //點亮發光二極管
dt_4 = 1;
if(key_can == 5)
led5 = 0; //點亮發光二極管
dt_5 = 1;
if(key_can == 6)
led6 = 0; //點亮發光二極管
dt_6 = 1;
if(key_can == 7)
led7 = 0;
dt_7 = 1;
if(key_can == 8)
led8 = 0;
dt_8 = 1;
/*********************當電梯不動時、判斷是向上、還是向下**********************/
void tiandi_shang_xia()
static uchar value;
if(dt_s_x == 0)
flag_stop = 1;
if(dt_value == 1) //電梯在第1層停下不走了
value = dt_2 + dt_3 + dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上
shang = 0; //顯示上
zhong = 0;
xia = 1;
if(dt_value == 2) //電梯在第2層停下不走了
value = dt_3 + dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 3) //電梯在第3層停下不走了
value = dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1 + dt_2;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 4) //電梯在第4層停下不走了
value = + dt_5 + dt_6 + dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1 + dt_2 + dt_3;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 5) //電梯在第5層停下不走了
value = dt_6 + dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1 + dt_2 + dt_3 + dt_4;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 6) //電梯在第5層停下不走了
value = dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 7) //電梯在第5層停下不走了
value = dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5 + dt_6;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 8) //電梯在第5層停下不走了
value = dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
/****************電梯向上、做最后的判斷是否還要繼續向上****************/
void dt_shang_guan()
uchar value;
if(dt_s_x == 1) //電梯向上 做最后的判斷是否還要繼續向上
if(dt_value == 1) //在第1層
if(value == 0) //說明上面沒有人按下
dt_s_x = 0; //電梯停下不動了
shang = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 2) //在第2層
shang = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 3) //在第3層
shang = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 4) //在第4層
value = dt_5 + dt_6 + dt_7 + dt_8;
shang = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 5) //在第5層
shang = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 6) //在第6層
shang = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 7) //在第7層
value = dt_8;
shang = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 8) //在第8層
shang = 1; //關閉上字
zhong = 1;
/****************電梯向下、做最后的判斷是否還要繼續向下****************/
void dt_xia_guan()
uchar value;
if(dt_s_x == 2) //電梯向下 做最后的判斷是否還要繼續向下
xia = 1; //關閉上字
zhong = 1;
flag_stop = 1;
value = dt_1;
xia = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
xia = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
xia = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
xia = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
xia = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5+ dt_6;
xia = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5 + dt_6 + dt_7;
xia = 1; //關閉上字
zhong = 1;
}else
flag_stop = 1;
/***********************電梯處理函數************************/
void td_dis()
uchar value,value1;
value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
if(value != 0)
{ //100ms
if(flag_stop == 1) //到相應的樓了 要停下
/***************************向上走電梯***********************************/
if(dt_s_x != 0) //向上走電梯
value1 ++;
if(value1 >= 10) //1s
value1 = 0;
if(dt_s_x == 1) //向上走電梯
dt_value ++;
shang = 0; //顯示上字
zhong = 0;
if(dt_s_x == 2) //向下走電梯
dt_value --;
xia = 0; //顯示下字
zhong = 0;
if(dt_value == 1) //當到了第一層的時候
if(dt_1 == 1)
led1 = 1; //關閉第一層發光二極管
dt_1 = 0; //清零電機在的標志
flag_stop = 0; //到停下
beep = 0; //打開蜂鳴器
else if(dt_value == 2) //當到了第二層的時候
if(dt_2 == 1)
led2 = 1; //關閉第二層發光二極管
dt_2 = 0; //清零電機在的標志
beep = 0; //打開蜂鳴器
else if(dt_value == 3) //當到了第3層的時候
if(dt_3 == 1)
led3 = 1; //關閉第3層發光二極管
dt_3 = 0; //清零電機在的標志
beep = 0; //打開蜂鳴器
else if(dt_value == 4) //當到了第4層的時候
if(dt_4 == 1)
led4 = 1; //關閉第4層發光二極管
dt_4 = 0; //清零電機在的標志
beep = 0; //打開蜂鳴器
else if(dt_value == 5) //當到了第5層的時候
if(dt_5 == 1)
led5 = 1; //關閉第5層發光二極管
dt_5 = 0; //清零電機在的標志
beep = 0; //打開蜂鳴器
else if(dt_value == 6) //當到了第6層的時候
if(dt_6 == 1)
led6 = 1; //關閉第6層發光二極管
dt_6 = 0; //清零電機在的標志
beep = 0; //打開蜂鳴器
else if(dt_value == 7) //當到了第7層的時候
if(dt_7 == 1)
led7 = 1; //關閉第7層發光二極管
dt_7 = 0; //清零電機在的標志
beep = 0; //打開蜂鳴器
else if(dt_value == 8) //當到了第8層的時候
if(dt_8 == 1)
led8 = 1; //關閉第8層發光二極管
dt_8 = 0; //清零電機在的標志
beep = 0; //打開蜂鳴器
if(flag_stop == 0)
// flag_stop = 1;
// value1 = 0;
value2 ++;
if(value2 % 3 == 0)
if(dt_s_x == 1) //上
shang = ~shang;
zhong = ~zhong;
if(dt_s_x == 2) //下
zhong = ~zhong;
xia = ~xia;
if(value2 >= 10) //1.0s
beep = 1; //關閉蜂鳴器
if(value2 >= 20)
value2 = 0;
dt_shang_guan(); //電梯向上 做最后的判斷是否還要繼續向上
dt_xia_guan(); //電梯向下 做最后的判斷是否還要繼續向下
/*************定時器0初始化程序***************/
void time_init()
EA = 1; //開總中斷
TMOD = 0X01; //定時器0、工作方式1
ET0 = 1; //開定時器0中斷
TR0 = 1; //允許定時器0定時
/******************主程序**********************/
dis_smg[0] = smg_du[1];
time_init();
key(); //按鍵程序
if(key_can < 20)
if(dt_s_x == 0)
value2 = 0;
flag_stop = 1;
key_with();
tiandi_shang_xia(); //當電梯不動時、判斷是向上、還是向下
dis_smg[0] = smg_du[dt_value]; //顯示
P1 = ~dis_smg[0];
if(flag_100ms == 1)
flag_100ms = 0;
td_dis(); //電梯處理函數
/*************定時器0中斷服務程序***************/
void time0_int() interrupt 1
static uchar value;
TH0 = 0x3c;
TL0 = 0xb0; // 50ms
value ++;
if(value % 4 == 0)
flag_100ms = 1 ;
