查看: 4904|回復: 6
STM32單片機DHT11溫濕度環境監控系統Proteus仿真代碼 帶電機風扇
ID:1059945 發表于 2023-1-1 23:41 | 顯示全部樓層 |閱讀模式
STM32溫濕度環境監控系統DHT11 帶仿真proteus 8.12版本
溫濕度控溫溫度低加熱
溫濕度控溫溫度低加熱
  1. //頭文件
  2. #include <stm32f10x.h>
  3. #include "GPIOLIKE51.h"
  4. #include "1602.h"
  5. #include <dht11.h>
  6. #include "ADC.h"
  7. #include "delay.h"
  8. #include "stdio.h"
  9. #include "usart.h"
  10. #define uchar unsigned char
  11. #define uint unsigned int
  12.
  13. #define key1 PBin(6)
  14. #define key2 PBin(1)
  15. #define key3 PBin(2)
  16. #define key4 PBin(3)
  17. #define beep PBin(7)
  18. #define led PBout(4)
  19. #define led1 PBout(5)
  20. uchar DHT[5];
  21. uchar str[12];
  22. uchar st=30;
  23. uchar sh=40;
  24. //函數聲明
  25. void GPIO_Configuration(void);
  26. void key_process(void);
  27. //=============================================================================
  28. //文件名稱:Delay
  29. //功能概要:延時
  30. //參數說明:nCount:延時長短
  31. //函數返回:無
  32. //=============================================================================
  33. void Delay(uint32_t nCount)
  34. {
  35.   for(; nCount != 0; nCount--);
  36. }
  37. float valus;
  38. uint16_t AD_Val;
  39. uint8_t vals;
  40. uint16_t AD;
  41. uint16_t temp;
  42. u16 gz;
  43. //=============================================================================
  44. //文件名稱:main
  45. //功能概要:主函數
  46. //參數說明:無
  47. //函數返回:int
  48. //=============================================================================
  49. int main(void)
  50. {
  51.
  52.         char str[100];
  53.         GPIO_Configuration();
  54.         Adc_Init();
  55.         LCD_Init();    //液晶初始化
  56. //        uart_init(9600);
  57.         LCD_Write_String(0,0,"ST:    SH:");
  58.         LCD_Write_String(0,1,"T:   H:  ");
  59.         LCD_Write_String(10,1,"Lx:  %");
  60.   while(1)
  61. {
  62.                 temp++;
  63.                 if(temp%10)
  64.                 {
  65.
  66.                 AD_Val = ADC_GetConversionValue(ADC1);
  67.                 AD=4095-AD_Val;
  68.                 AD=(AD*99/4095);
  69.                 sprintf(str,"%d",AD);
  70.                 temp=0;
  71.                 }
  72.                 LCD_Write_String(12,1,str);
  73.                         if(AD>80)
  74.         {
  75.                 beep=1;
  76.         }
  77.         else{beep=0;}
  78.                 key_process();
  79.                 DHT_Start();
  80.                 DHT_ByteRead(DHT);
  81.                 DHT[0]=DHT[0]/2;
  82.                 DHT[2]=DHT[2]/2;
  83.                    str[0] = (DHT[0]/10)%10+0x30;  //十位轉為ASCII碼
  84.            str[1] = (DHT[0]%10)+0x30;  //個位轉為ASCII
  85.                    LCD_Write_Char(2,1,str[0]);
  86.                    LCD_Write_Char(3,1,str[1]);
  87.                    str[0] = (DHT[2]/10)%10+0x30;  //十位轉為ASCII碼
  88.            str[1] = (DHT[2]%10)+0x30;  //個位轉為ASCII
  89.                    LCD_Write_Char(7,1,str[0]);
  90.                    LCD_Write_Char(8,1,str[1]);
  91.
  92.
  93.                         str[0] = st/10+0x30;  //十位轉為ASCII碼
  94.            str[1] = st%10+0x30;  //個位轉為ASCII
  95.                    LCD_Write_Char(3,0,str[0]);
  96.                    LCD_Write_Char(4,0,str[1]);
  97.                    str[0] = sh/10+0x30;  //十位轉為ASCII碼
  98.            str[1] = sh%10+0x30;  //個位轉為ASCII
  99.                    LCD_Write_Char(10,0,str[0]);
  100.                    LCD_Write_Char(11,0,str[1]);
  101.
  102.
  103.                         if(DHT[0]>=st) led=0;
  104.                         else led=1;
  105.
  106.                         if(DHT[2]<=sh) led1=0;
  107.                         else led1=1;
  108.
  109.                    }
  110. }
  111.
  112. //=============================================================================
  113. //文件名稱:GPIO_Configuration
  114. //功能概要:GPIO初始化
  115. //參數說明:無
  116. //函數返回:無
  117. //=============================================================================
  118. void GPIO_Configuration(void)
  119. {
  120.   GPIO_InitTypeDef GPIO_InitStructure;
  121.
  122.   RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB , ENABLE);
  123. //=============================================================================
  124. //LED -> PC13
  125. //=============================================================================
  126.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  127.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  128.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  129.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  130.
  131.
  132.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  133.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  134.
  135. //        GPIO_Write(GPIOA, 0xffff);
  136.
  137.           GPIO_Write(GPIOB, 0xffff);
  138.                 GPIO_ResetBits(GPIOB,GPIO_Pin_7);
  139. }
  140. void key_process(void)
  141. {
  142.
  143. if(key1==0)             //??1
  144.    {
  145.     delay_ms(10);
  146.         if(key1==0)
  147.          {
  148.
  149.           while(!key1);
  150.           st++;
  151.                  if(st>=35) st=35;
  152.
  153.           }
  154.    }
  155.
  156.
  157. if(key2==0)             //??1
  158.    {
  159.     delay_ms(10);
  160.         if(key2==0)
  161.          {
  162.
  163.           while(!key2);
  164.         st--;
  165.                  if(st<=25) st=25;
  166.
  167.           }
  168.    }
  169.
  170.          if(key3==0)             //??1
  171.    {
  172.     delay_ms(10);
  173.         if(key3==0)
  174.          {
  175.
  176.           while(!key3);
  177.         sh++;
  178.                  if(sh>=45) sh=45;
  179.
  180.           }
  181.    }
  182.
  183.
  184. if(key4==0)             //??1
  185.    {
  186.     delay_ms(10);
  187.         if(key4==0)
  188.          {
  189.
  190.           while(!key4);
  191.         sh--;
  192.                  if(sh<=35) sh=35;
  193.
  194.           }
  195.    }
  196. }
  197. /*
  198. GPIO的八種模式
  199. 4種輸入模式:
  200. ① 輸入浮空 GPIO_Mode_IN_FLOATING
  201. ② 輸入上拉 GPIO_Mode_IPU
  202. ③ 輸入下拉 GPIO_Mode_IPD
  203. ④ 模擬輸入 GPIO_Mode_AIN
  204. ◆ 4種輸出模式:
  205. ① 開漏輸出 GPIO_Mode_Out_OD
  206. ② 開漏復用功能 GPIO_Mode_AF_OD
  207. ③ 推挽式輸出 GPIO_Mode_Out_PP
  208. ④ 推挽式復用功能 GPIO_Mode_AF_PP
  209. ————————————————
  210. */
Keil代碼與Proteus8.13仿真下載:
仿真程序.7z (235.54 KB, 下載次數: 439)
ID:850421 發表于 2023-3-10 16:58 | 顯示全部樓層
寫的很好,待我測試一下
ID:1066092 發表于 2023-3-25 02:41 | 顯示全部樓層
兄弟,你這個keil下使用的插件是哪個?vdmagdi在keil5里我一直都無法正常使用,它指向了系統臨時文件夾無法指向編譯目錄,裝載不了編譯后的文件無法一起聯調啊。
ID:291668 發表于 2023-3-26 17:55 | 顯示全部樓層
這個仿真功能不錯,應該學習學習!
ID:737490 發表于 2023-4-30 12:36 | 顯示全部樓層
請問,仿真的時候DHT11測試一直不變都是溫濕度27,AD也測不出來是為什么啊。管腳控制風扇、喇叭、燈也不聽使喚
ID:914036 發表于 2023-5-7 13:37 | 顯示全部樓層
樓主蜂鳴器那里的宏定義有點問題,應該是PBout(7)
ID:1015682 發表于 2023-5-9 13:28 | 顯示全部樓層
小琪不想學習 發表于 2023-4-30 12:36
請問,仿真的時候DHT11測試一直不變都是溫濕度27,AD也測不出來是為什么啊。管腳控制風扇、喇叭、燈也不聽 ...
是的
