查看: 1286|回復: 0
DHT22 Arduino代碼
ID:1059445 發表于 2023-1-1 19:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
DHT dht(DHTPIN, DHTTYPE);
void setup() {
  Serial.begin(115200);
  Serial.println(F("DHT22 example!"));
  dht.begin();
void loop() {
  float temperature = dht.readTemperature();
  float humidity = dht.readHumidity();
  // Check if any reads failed and exit early (to try again).
  if (isnan(temperature) || isnan(humidity)) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
  Serial.print(F("Humidity: "));
  Serial.print(humidity);
  Serial.print(F("%  Temperature: "));
  Serial.print(temperature);
  Serial.println(F("°C "));
  // Wait a few seconds between measurements.
  delay(2000);
