查看: 1619|回復: 0
8266modbus接收nonos
ID:405603 發(fā)表于 2022-11-5 23:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
看了小宋老師的課嘗試著寫的,拋磚引玉。
#if UART_SELFTEST&UART_BUFF_EN
os_timer_t buff_timer_t;
void ICACHE_FLASH_ATTR
uart_test_rx()
    uint8 uart_buf[128]={0};
    uint16 len = 0;
    len = rx_buff_deq(uart_buf, 128 );
    tx_buff_enq(uart_buf,len);
        crc = GetCRC16(uart_buf, len-2);
        crch = crc >> 8;
        crcl = crc & 0xFF;
    char *PA;
    CHAR *PB;
    if(uart_buf[0]=='0' && uart_buf[1]=='1' && uart_buf[2]=='0' && uart_buf[3]=='3')
    { char buf[0]=0x01;
           buf[1]=0x03;
           int cnt;
               memset(CCC,0,sizeof(CCC));
               memset(DDD,0,sizeof(DDD));
               memset(CRCL,0,sizeof(CRCL));
               memset(CRCH,0,sizeof(CRCH));
        uart0_sendStr("modbus讀本機狀態(tài)模式");
            PA=uart_buf;
            PA=PA+4;
            PB=PA+4;
                memcpy(CCC,PA,strlen(PA)-strlen(PB));
                buf[3]=CCC;
                PA=PB;
                PB=PA+4;
                memcpy(DDD,PA,strlen(PA)-strlen(PB));
                buf[4]=DDD;
                cnt=atoi(DDD);
                PA=PB;
                PB=PA=2;
                memcpy(CRCH,PA,strlen(PA)-strlen(PB));
                PA=PB;
                PB=PA=2;
                memcpy(CRCL,PA,strlen(PA)-strlen(PB));
            if ((CRCH!=crch) || (CRCL!=crcl))
                return;
           os_sprintf(buf[2],cnt*2);
           buf[5]=0;//或1,表示某個設(shè)備的狀態(tài)
                   buf=buf[0]+buf[1]+buf[2]+buf[5]+crch+crcl;
                   uart0_sendStr(buf);
    else if(uart_buf[0]=='0' && uart_buf[1]=='1' && uart_buf[2]=='0' && uart_buf[3]=='6')
            uart0_sendStr("modbus寫本機狀態(tài)模式");
#endif
