基于51單片機的信號發生器,仿真用的proteus,程序用的是keil,數模轉換重要用的是DAC0832,可實現波形轉換。
仿真圖
#include"key.h"
#include"math.h"
unsigned int fword = 1000;
unsigned char Duty;
unsigned char gFunctionCount=0;
unsigned char gTimeCount=0;
unsigned char gType=0;
char FreqNum[5]={0,1,0,0,0};
char AmpNum[2]={5,0};
char DutyNum[2]={5,0};
/*延時函數:按鍵消抖用*/
static void delay10ms(void)
unsigned char j,i;
for(j=0;j<110;j++)
for(i=0;i<100;i++);
/*按鍵掃描函數:主函數主循環只調用此函數,其完成參數設定以及下達功能*/
void key_scan(void)
unsigned int freqtemp;
unsigned int amptemp;
unsigned char dutytemp;
if(KEY1==0) //功能鍵按下
delay10ms();
if(KEY1==0)
gFunctionCount++;
//功能設定一:設置波形
if(gFunctionCount==1)
gTimeCount=0;
EA = 0;
LCDDispChar(8,1,'#');
//功能設定二:設置頻率
else if(gFunctionCount==2)
gTimeCount=0;
LCDCursor();
LCDDispChar(8,1,' ');
LCDDispNum(6,2,FreqNum[3]);
//功能設定三:設置方波占空比
else if((gFunctionCount==3)&&(gType==1)) // ((gFunctionCount==4)&&(gType==1))
gTimeCount=0;
LCDCursor();
LCDDispNum(14,2,DutyNum[1]);
LCDDispNum(13,2,DutyNum[0]);
//設定完畢
else if((gFunctionCount==4)||((gFunctionCount==3)&&(gType!=1))) // ((gFunctionCount==5)||((gFunctionCount==4)&&(gType!=1)))
gFunctionCount=0;
LCDNotCursor();
//計算頻率值
freqtemp=(unsigned int )FreqNum[0]*10000+(unsigned int )FreqNum[1]*1000+(unsigned int)FreqNum[2]*100+(unsigned int)FreqNum[3]*10+(unsigned int)FreqNum[4];
if(freqtemp>10000)//當輸入頻率大于10kHz時,將頻率設置成10kHz
freqtemp = 10000;
LCDDispNum(3,2,1);LCDDispNum(4,2,0);LCDDispNum(5,2,0);LCDDispNum(6,2,0);LCDDispNum(7,2,0);
FreqNum[0]=1;FreqNum[1]=0;FreqNum[2]=0;FreqNum[3]=0;FreqNum[4]=0;
else if(freqtemp<1)//當輸入頻率小于1Hz時,將頻率設置成1Hz
freqtemp = 1;
LCDDispNum(3,2,0);LCDDispNum(4,2,0);LCDDispNum(5,2,0);LCDDispNum(6,2,0);LCDDispNum(7,2,1);
FreqNum[0]=0;FreqNum[1]=0;FreqNum[2]=0;FreqNum[3]=0;FreqNum[4]=1;
//幅值
amptemp =50;
//計算占空比
dutytemp=(unsigned char)DutyNum[0]*10 +(unsigned char)DutyNum[1];
if(dutytemp>90)//當輸入占空比大于90%時,將占空比設置成90%
dutytemp = 90;
LCDDispNum(13,2,9);LCDDispNum(14,2,0);
DutyNum[0]=9;DutyNum[1]=0;
else if(dutytemp<10)//當輸入占空比小于10%時,將占空比設置成10%
dutytemp = 10;
LCDDispNum(13,2,1);LCDDispNum(14,2,0);
DutyNum[0]=1;DutyNum[1]=0;
if(gType!=1)//當波形不為方波時,顯示橫杠表示無效
{ LCDDispString(13,2,"--");}
//設置數據處理完成,以下代碼進行DA輸出設置
fword = (unsigned int)(freqtemp*1.009); //設置頻率控制字
AmPort = (unsigned char)(50*5.1); //設置幅值
Duty = dutytemp; //設置方波占空比
EA = 1;
}while(!KEY1); //循環到松手
if(KEY2==0) //設定鍵按下
delay10ms();
if(KEY2==0)
gTimeCount++;
波形設定
if(gFunctionCount==1 && gTimeCount==1)
{ LCDDispString(5,1,"Squ");gType=1; }
else if(gFunctionCount==1 && gTimeCount==2)
{ LCDDispString(5,1,"Tri");gType=2; }
else if(gFunctionCount==1 && gTimeCount==3)
{ LCDDispString(5,1,"Saw");gType=3;}
else if(gFunctionCount==1 && gTimeCount==4)
{ gTimeCount=0;LCDDispString(5,1,"Sin");gType=0; }
頻率設定
else if(gFunctionCount==2 && gTimeCount==1)
{ LCDDispNum(5,2,FreqNum[2]); }
else if(gFunctionCount==2 && gTimeCount==2)
{ LCDDispNum(4,2,FreqNum[1]); }
else if(gFunctionCount==2 && gTimeCount==3)
{ LCDDispNum(3,2,FreqNum[0]); }
else if(gFunctionCount==2 && gTimeCount==4)
{ LCDDispChar(2,2,' '); }
else if(gFunctionCount==2 && gTimeCount==5)
{ gTimeCount=0;LCDDispNum(6,2,FreqNum[3]); }
方波設定
else if(gFunctionCount==3 && gTimeCount==1)
{ LCDDispChar(12,2,':'); }
else if(gFunctionCount==3 && gTimeCount==2)
{ gTimeCount=0;LCDDispNum(13,2,DutyNum[0]); }
}while(!KEY2); //循環到松手
if(KEY3==0) //加鍵按下
delay10ms();
if(KEY3==0)
FreqNum[3]++;
if(FreqNum[3]==10)
FreqNum[3]=0;
LCDDispNum(6,2,FreqNum[3]);LCDDispNum(5,2,FreqNum[2]);
FreqNum[2]++;
if(FreqNum[2]==10)
FreqNum[2]=0;
LCDDispNum(5,2,FreqNum[2]);LCDDispNum(4,2,FreqNum[1]);
Keil代碼與Proteus仿真下載:
基于51單片機的信號發生器.7z
(52.17 KB, 下載次數: 45)
2022-10-25 19:28 上傳
