直接上圖(樓主根據(jù)喜好設(shè)置,也可自行通過 < Edit - Configuration - Colors & Fonts > 進(jìn)行調(diào)整)
打開效果
選中效果
涉及文件:51.prop、global.prop(主要是這個(gè)文件)
更改配色涉及到的文件變動
為避免出現(xiàn)奇怪的異常,進(jìn)行下面操作前,請備份上述的兩個(gè)文件
方式一:解壓,放置在對應(yīng)目錄即可(例如:C:\Keil_v5\UV4\global.prop)
global.zip
(1.33 KB, 下載次數(shù): 134)
2022-7-13 17:19 上傳
點(diǎn)擊文件名下載附件
具體文件
方式二:不方便下載的同學(xué),這里貼出了global.prop文件的具體內(nèi)容,復(fù)制替換也可以
- # properties for all file types
- indent.automatic=1
- virtual.space=0
- view.whitespace=0
- view.endofline=0
- code.page=936
- caretline.visible=1
- highlight.matchingbraces=1
- print.syntax.coloring=1
- use.tab.color=1
- create.backup.files=0
- auto.load.ext.modfiles=0
- save.prj.before.dbg=1
- save.files.before.dbg=1
- function.scanner.project=1
- function.scanner.files=1
- function.scanner.modules=1
- # properties for c/cpp files
- syntax.colouring.cpp=1
- use.tab.cpp=0
- tabsize.cpp=2
- line.margin.visible.cpp=1
- fold.cpp=1
- monospaced.font.cpp=1
- # properties for asm files
- syntax.colouring.asm=1
- use.tab.asm=0
- tabsize.asm=4
- line.margin.visible.asm=1
- monospaced.font.asm=1
- # properties for other files
- use.tabs=0
- tabsize=4
- line.margin.visible.txt=1
- monospaced.font.txt=1
- # setting for code completion and syntax check
- cc.autolist=1
- cc.highlightsyntax=1
- cc.showparameters=1
- cc.triggerlist=1
- cc.triggernumchars=3
- cc.enter.as.fillup=0
- cc.usealpha4inactcode=1
- cc.alphavalue=50
- # autosave for editor files
- autosave=1
- autosave.interval=5
- # vertical edge at right margin
- edge.mode=0
- edge.column=80
- # Specification for text selection and caret line
- selection.fore=#D4D4D4
- selection.back=#3F3F3F
- caret.fore=#FFFFFF
- caret.back=#2A2A2A
- # Color for vertical edge
- edge.colour=#66FAFA
- # C/C++ Editor files
- template.cpp="#define","#define |";"#if","#if |\r\n\r\n#endif";\\
- "#include","#include <|>";"Header","// Header:\r\n// File Name: |\r\n// Author:\r\n// Date:\r\n";\\
- "continue","continue;";"do","do\r\n{\r\n\t// TODO: enter the block content here\r\n\t\r\n\t|\r\n} while ();\r\n";\\
- "enum","enum |\r\n{\r\n\t\r\n};\r\n";"for","for(|;;)\r\n{\r\n}";\\
- "fpointer_type","typedef int (* |F)();\r\n";"function","void function(|)\r\n{\r\n\r\n}\r\n";\\
- "if","if (|)";"ifelse","if (|)\r\n{\r\n}\r\nelse\r\n{\r\n}";\\
- "struct","struct | \r\n{\r\n\r\n};\r\n";"switch","switch (|)\r\n{\r\n\tcase:\r\n\t\tbreak;\r\n\tcase:\r\n\t\tbreak;\r\n\tdefault:\r\n\t\tbreak;\r\n}";\\
- "void","void | ();\r\n";"while","while (|)\r\n{\r\n}";\\
- font.monospace.cpp=Courier New
- style.cpp.32=font:Courier New,size:10,fore:#4F4F4F,back:#151515
- style.cpp.4=font:Courier New,size:10,fore:#00D59F,back:#151515
- style.cpp.10=font:Courier New,size:10,fore:#6A6A6A,back:#151515
- style.cpp.1=font:Courier New,size:10,fore:#00954A,back:#151515
- style.cpp.2=font:Courier New,size:10,fore:#00954A,back:#151515
- style.cpp.5=font:Courier New,size:10,fore:#FF8000,back:#151515
- style.cpp.6=font:Courier New,size:10,fore:#FF8080,back:#151515
- style.cpp.11=font:Courier New,size:10,fore:#00A5F4,back:#151515
- style.cpp.9=font:Courier New,size:10,fore:#D5D500,back:#151515
- style.cpp.7=font:Courier New,size:10,fore:#FF8080,back:#151515
- style.cpp.34=font:Courier New,size:10,fore:#FFFF00,back:#3A3A3A
- style.cpp.35=font:Courier New,size:10,fore:#FF0000,back:#151515
- style.cpp.16=font:Courier New,size:10,fore:#FF55AA,back:#151515
- style.cpp.12=font:Courier New,size:10,fore:#E3C6E3,back:#151515
- style.cpp.86=font:Courier New,size:10,fore:#FFFFFF,back:#151515
- # Asm Editor files
- font.monospace.asm=Courier New
- style.asm.32=font:Courier New,size:10,fore:#000000,back:#FFFFFF
- style.asm.1=font:Courier New,size:10,fore:#616161,back:#FFFFFF
- style.asm.2=font:Courier New,size:10,fore:#FF0000,back:#FFFFFF
- style.asm.3=font:Courier New,size:10,fore:#7F007F,back:#FFFFFF
- style.asm.4=font:Courier New,size:10,fore:#000000,back:#FFFFFF
- style.asm.5=font:Courier New,size:10,fore:#000000,back:#FFFFFF
- style.asm.6=font:Courier New,size:10,fore:#0000FF,back:#FFFFFF
- style.asm.7=font:Courier New,size:10,fore:#0000FF,back:#FFFFFF
- style.asm.9=font:Courier New,size:10,fore:#0000FF,back:#FFFFFF
- style.asm.10=font:Courier New,size:10,fore:#0000FF,back:#FFFFFF
- style.asm.11=font:Courier New,size:10,fore:#007F00,back:#FFFFFF
- style.asm.12=font:Courier New,size:10,fore:#7F007F,back:#FFFFFF
- style.asm.8=font:Courier New,size:10,fore:#46AA03,back:#FFFFFF
- # Editor Text files
- font.monospace.txt=Consolas
- style.txt.32=font:Verdana,size:10,fore:#FFFFFF,back:#151515
