只需一步,快速開(kāi)始
查看: 1653|回復(fù): 0
單片機(jī)+adc0808控制pwm輸出程序
ID:1035952 發(fā)表于 2022-6-20 16:26 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
sbit CLK=P2^4;
sbit ST=P2^5;
sbit EOC=P2^6;
sbit OE=P2^7;
sbit PWM=P3^0;
void DelayMS(uint ms)
uchar i;
while(ms--) for(i=0;i<40;i++);
uchar Va1;
TMOD=0x02;
TH0=0x14;
TL0=0x00;
IE=0x82;
TR0=1;
ST=0;ST=1;ST=0;
while(!EOC);
OE=1;
Va1=p1;
OE=0;
if(Va1==0)
PWM=0;
if(Va1==0xff);
continue;
if(Va1==0xff)
PWM=1;
DelayMS(0xfff);
continue;
PWM=1;
DelayMS(Va1);
PWM=0;
DelayMS(0xff-Val);
void Timer0_INT() interrupt 1
CLK=~CLK;
