這個產(chǎn)品圖看一下,標(biāo)價RMB12K,僅僅是一個DAC
High End Discrete R-2R Sign Magnitude DAC / HeadAmp
旗艦!
全平衡!
27 bit!
DSD256/PCM384
售價: RMB 11,980
dac1541 internals dac1541 retail packaging
Specifications:
THD @ -1 dB <0.005%
THD @ -60 dB <0.02%
Resistor Precision 27 bit, 0.01% – 0.02% Resistors
Clock Jitter RMS 0.3 pS typical
S/N 20 Khz Bandwith >123 dB unweighted
Frequency Range +0.1 -1.0 dB 20hz – 20Khz
USB Input Type B, Isolated, Full/High Speed
USB Input Mode Selectable Audio Class 1.0 or Audio Class 2.0
SPDIF / AES / Toslink Inputs Up to 24 bit / 192 Khz
USB Input PCM Up to 24 Bit / 384 Ksps
USB Input DSD Up to DoP-128 and DSD-256
Digital volume control -80 dB to +10 dB
Output Line RCA, 2.0V RMS, Zout 50 ohm
Output Line Balanced 3 pins XLR, 4.0V RMS, Zout 100 ohm
Output Headphones 6.3 mm Jack, 6.5V RMS, Zout 1.5 ohm
1300mW @ 32Ω
Output Headphones Balanced 4 pins XLR, 13V RMS., Zout 3.0 ohm
4400mW @ 32Ω
Power Consumptation 90-265V AC, max 35W
Size 250 x 205 x 40 mm
Weight 1.5 Kg
Warranty 3 Years |
