查看: 2102|回復: 0
8086將十六進制轉化為ascii碼
ID:1034417 發表于 2022-6-13 19:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
實驗程序如下
data segment
    ; add your data here!
DAT   SEGMENT
    AA       DB  01H,23H,45H,67H,89H,0ABH,0CDH,0EFH
    COUNT   EQU  $-AA
    STRING  DB  COUNT*2  DUP(0),'$'
DAT  ENDS
    pkey db "press any key...$"
ends
stack segment
    dw   128  dup(0)
ends
code segment
    ASSUME CS:CODE,DS:DATA
start:
; set segment registers:
    mov ax, data
    mov ds, ax
    ; add your code here
    MOV SI,OFFSET AA
    MOV DI,OFFSET STRING
    MOV BL,COUNT
GO:
    MOV AL,[SI]
    MOV BH,AL
    MOV CL,4
    SHR AL,CL
    CMP AL,9
    JBE NEXT1
    ADD AL,7
NEXT1:
    ADD AL,30H
    MOV [DI],AL
    INC DI
    MOV AL,BH
    AND AL,0FH
    CMP AL,9
    JBE NEXT2
    ADD AL,7
NEXT2:
    ADD AL,30H
    MOV [DI],AL
    INC DI
    INC SI
    SUB BL,1
    JNZ GO
    LEA DX,STRING
    MOV AH,9
    INT 21H
CODE ENDS
END START
