功能: 點(diǎn)亮由FD650B ic驅(qū)動(dòng)的電子屏,并實(shí)現(xiàn)按一下按鍵就數(shù)字加1,本來(lái)想時(shí)間周期里可以自動(dòng)加1的,結(jié)果好像有沖突,以后再說(shuō) 芯片型號(hào)STC15F104W單片機(jī)先找650b的廠(chǎng)家看資料,就看到了幾個(gè)說(shuō)明書(shū)。并沒(méi)有想象中的源碼,然后網(wǎng)上到處百度,找的的資料是偏面向?qū)ο蟮膶?xiě)法,看不懂,自己瞎擼吧。顯示屏板子就直接用的拆機(jī)設(shè)備的前面板,這里我們多。最終效果。
那個(gè)面板圖也找了份。
話(huà)不多說(shuō),直接上源碼吧。
先上hd650.h文件
單片機(jī)源程序如下:
- #ifndef __FP__FD650__H
- #define __FP__FD650__H
- /*** type redefine ***/
- typedef unsigned char MS_U8;
- typedef unsigned short MS_U16;
- typedef unsigned long MS_U32;
- typedef int MS_S32;
- typedef int MS_BOOL;
- /****************************begin for FD650 define struct***************************** */
- #define LEDMAPNUM 40
- //key mapping
- typedef struct
- MS_U8 keyMapData;
- MS_U8 keyMapLevel;
- } MS_KEYMAP;
- //led mapping
- typedef struct _led_bitmap
- MS_U8 character;
- MS_U8 bitmap;
- } led_bitmap;
- //數(shù)碼管顯示常量
- static const led_bitmap bcd_decode_tab[LEDMAPNUM] =
- { {'0', 0x3F}, {'1', 0x06}, {'2', 0x5B}, {'3', 0x4F},
- {'4', 0x66}, {'5', 0x6D}, {'6', 0x7D}, {'7', 0x07},
- {'8', 0x7F}, {'9', 0x6F}, {'a', 0x77}, {'A', 0x77},
- {'b', 0x7C}, {'B', 0x7C}, {'c', 0x58}, {'C', 0x39},
- {'d', 0x5E}, {'D', 0x5E}, {'e', 0x79}, {'E', 0x79},
- {'f', 0x71}, {'F', 0x71}, {'H', 0x76}, {'h', 0x74},
- {'o', 0x5C}, {'t', 0x78},
- {'l', 0x30}, {'L', 0x38}, {'N', 0x37},{'n', 0x37},
- {'p', 0x73},{'P', 0x73}, {'O', 0x3F}, {'u', 0x1C},
- {'U', 0x3E},{'S', 0x6D}, {'s', 0x6D},{'-', 0x40},
- {' ', 0x00}
- };//BCD decode
- /****************************end for FD650 define struct***************************** */
- /* *************************************硬件相關(guān)*********************************************** */
- #define HIGH 1
- #define LOW 0
- #define FRONTPNL_START_TIME_MS 3 //((1000 / 50) / LED_NUM)
- #define FRONTPNL_PERIOD_TIME_MS 150
- #define FP_LED_MAX_NUM 4
- #define FrontPnl_MSECS_TICK 100 //100 msecs/tick
- #define FrontPnl_TICKS_SEC 1 //10 ticks/sec
- // 設(shè)置系統(tǒng)參數(shù)命令
- #define FD650_BIT_ENABLE 0x01 // 開(kāi)啟/關(guān)閉位
- #define FD650_BIT_SLEEP 0x04 // 睡眠控制位
- #define FD650_BIT_7SEG 0x08 // 7段控制位
- #define FD650_BIT_INTENS1 0x10 // 1級(jí)亮度
- #define FD650_BIT_INTENS2 0x20 // 2級(jí)亮度
- #define FD650_BIT_INTENS3 0x30 // 3級(jí)亮度
- #define FD650_BIT_INTENS4 0x40 // 4級(jí)亮度
- #define FD650_BIT_INTENS5 0x50 // 5級(jí)亮度
- #define FD650_BIT_INTENS6 0x60 // 6級(jí)亮度
- #define FD650_BIT_INTENS7 0x70 // 7級(jí)亮度
- #define FD650_BIT_INTENS8 0x00 // 8級(jí)亮度
- #define FD650_SYSOFF 0x0400 // 關(guān)閉顯示、關(guān)閉鍵盤(pán)
- #define FD650_SYSON ( FD650_SYSOFF | FD650_BIT_ENABLE ) // 開(kāi)啟顯示、鍵盤(pán)
- #define FD650_SLEEPOFF FD650_SYSOFF // 關(guān)閉睡眠
- #define FD650_SLEEPON ( FD650_SYSOFF | FD650_BIT_SLEEP ) // 開(kāi)啟睡眠
- #define FD650_7SEG_ON ( FD650_SYSON | FD650_BIT_7SEG ) // 開(kāi)啟七段模式
- #define FD650_8SEG_ON ( FD650_SYSON | 0x00 ) // 開(kāi)啟八段模式
- #define FD650_SYSON_1 ( FD650_SYSON | FD650_BIT_INTENS1 ) // 開(kāi)啟顯示、鍵盤(pán)、1級(jí)亮度
- #define FD650_SYSON_4 ( FD650_SYSON | FD650_BIT_INTENS4 ) // 開(kāi)啟顯示、鍵盤(pán)、4級(jí)亮度
- #define FD650_SYSON_8 ( FD650_SYSON | FD650_BIT_INTENS8 ) // 開(kāi)啟顯示、鍵盤(pán)、8級(jí)亮度
- // 加載字?jǐn)?shù)據(jù)命令
- #define FD650_DIG0 0x1400 // 數(shù)碼管位0顯示,需另加8位數(shù)據(jù)
- #define FD650_DIG1 0x1500 // 數(shù)碼管位1顯示,需另加8位數(shù)據(jù)
- #define FD650_DIG2 0x1600 // 數(shù)碼管位2顯示,需另加8位數(shù)據(jù)
- #define FD650_DIG3 0x1700 // 數(shù)碼管位3顯示,需另加8位數(shù)據(jù)
- #define FD650_DOT 0x0080 // 數(shù)碼管小數(shù)點(diǎn)顯示
- // 讀取按鍵代碼命令
- #define FD650_GET_KEY 0x0700 // 獲取按鍵,返回按鍵代碼
- #endif
然后上主程序文件 單片機(jī)用的是那種最小開(kāi)發(fā)板,幾元錢(qián)的那種
最后源碼也傳到開(kāi)源平臺(tái)了,希望大家用的開(kāi)心
評(píng)分
查看全部評(píng)分
