查看: 2807|回復: 0
51單片機電子時鐘Proteus仿真代碼
基于51單片機4鍵電子時鐘
//必要說明,定時器中斷函數是經過計算的50ms,但在使用Proteus仿真時時間不準確。
//比實際表要快。對此不進行調整,因為中斷函數是經過硬件檢驗通過的。
#include <reg51.h>   //包含必要頭文件
//定義按鍵
sbit HourAdjust = P1^0;   //時調整選擇鍵
sbit MinuteAdjust = P1^1;  //分調整選擇鍵
sbit SecondAdjust = P1^2;  //秒選擇選擇鍵
sbit Adjust = P1^3;    //調整鍵
//定義標志位
bit SecondFlag = 0;    //秒標志
bit FlashFlag = 0;    //秒閃標志
bit Second10Flag = 0;   //10秒標志
bit HourAdjustFlag = 0;   //時調整標志,A鍵按下置1,10秒后清0
bit MinuteAdjustFlag = 0;   //分調整標志,A鍵按下置1,10秒后清0
bit SecondAdjustFlag = 0;   //秒調整標志,A鍵按下置1,10秒后清0
unsigned char Led1,Led2,Led3,Led4,Led5,Led6;  //定義緩存
int TimeCount,Second10Count;   //定義計數器
unsigned char code LedTab[]=  //定義共陰極數碼管表,0x00用于清除顯示
   {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
void Delay100us(int Times);    //定義延時函數
//*****************************定時器中斷服務程序******************************r
//程序功能:動態驅動數碼管,同時完成定時功能。
void timer() interrupt 3 using 2
TR1 = 0;
TL1 = 0x13; TH1 = 0x2C; //重新賦值
P0 = 0x00;    //顯示小時
P2 = 0xfe;
P0 = LedTab[Led1];
Delay100us(1);
P0 = 0x00;
P2 = 0xfd;
if(FlashFlag)   //秒顯(1秒顯,1秒隱)分前小數點
  P0 = LedTab[Led2] | 0x80;
  P0 = LedTab[Led2] & 0x7f;
Delay100us(1);
P0 = 0x00;    //顯示分
P2 = 0xfb;
P0 = LedTab[Led3];
Delay100us(1);
P0 = 0x00;
P2 = 0xf7;
if(FlashFlag)   //秒顯秒前小數點
  P0 = LedTab[Led4] | 0x80;
  P0 = LedTab[Led4] & 0x7f;
Delay100us(1);
P0 = 0x00;    //顯示秒
P2 = 0xef;
P0 = LedTab[Led5];
Delay100us(1);
P0 = 0x00;
P2 = 0xdf;
P0 = LedTab[Led6];
Delay100us(1);
TR1 = 1;
if(TimeCount < 100)  //秒計數器
  TimeCount++;
  TimeCount = 0x00;
  SecondFlag = 1;  //置位秒標志
  if(Second10Flag) //10秒計數器
   if(Second10Count < 20)
    Second10Count++;
    Second10Count = 0x00;  //10秒計數器清0
    Second10Flag = 0;   //清除10s標志
    HourAdjustFlag = 0;   //清除調整標志位
main(void)
//初始化
int Second = 30;  //初始化時間
int Minute = 12;
int Hour = 20;
Led1 = 0x00;   //清除顯存
Led2 = 0x00;
Led3 = 0x00;
Led4 = 0x00;
Led5 = 0x00;
Led6 = 0x00;
SecondFlag = 0;
TimeCount = 0x00;
//設置定時器中斷
TMOD = 0x10f;   //GATE=0             01010001
       //C/T=0--定時/計數器1工作于定時方式
       //M1=1;M0=0--選擇工作模式1,構成最大定時器
       //T0:在此程序不使用
TL1 = 0x13; TH1 = 0x2C; //指定定時時間為50ms  65536-50/(11.0592/12)=11283=2C13h
EA = 1;     //開總中斷
TF1 = 0;
ET1 = 1;    //開定時器中斷
TR1 = 1;    //開始計時
//對時間進行調整程序
  if(SecondFlag)
   if(Second%2 == 0)
    FlashFlag = 1;
    FlashFlag = 0;
   if(Second < 59)
    Second++;
    if(Minute < 59)
     Minute++;
     if(Hour < 23)
      Hour++;
      Hour = 0;
     Minute = 0;
   Second = 0;
  SecondFlag = 0;
//時間調整程序
  if(HourAdjustFlag)   //調整時程序
   if(Second10Flag)
    if(FlashFlag)  //時秒顯
     Led1 = 0x0a; //時隱
     Led2 = 0x0a;
     Led1 = Hour/10; //時顯
     Led2 = Hour%10;
    Led1 = Hour/10;
    Led2 = Hour%10;
   Led1 = Hour/10;
   Led2 = Hour%10;
  if(MinuteAdjustFlag)  //調整分程序
   if(Second10Flag)
    if(FlashFlag)  //分秒顯
     Led3 = 0x0a;
     Led4 = 0x0a;
     Led3 = Minute/10;
     Led4 = Minute%10;
    Led3 = Minute/10;
    Led4 = Minute%10;
   Led3 = Minute/10;
   Led4 = Minute%10;
  if(SecondAdjustFlag)  //調整秒程序,控制秒顯
   if(Second10Flag)
    if(FlashFlag)
     Led5 = 0x0a;
     Led6 = 0x0a;
     Led5 = Second/10;
     Led6 = Second%10;
    Led5 = Second/10;
    Led6 = Second%10;
   Led5 = Second/10;
   Led6 = Second%10;
  if(!HourAdjust)    //時調整按鍵按下
   while(!HourAdjust);  //等待松開
   HourAdjustFlag = 1;  //置位時標志位
   MinuteAdjustFlag = 0; //清除分標志位
   SecondAdjustFlag = 0; //清除秒標志位
   Second10Flag = 1;  //置位10秒標志位
  if(!MinuteAdjust)   //分調整鍵按下
   while(!MinuteAdjust);
   MinuteAdjustFlag = 1;
   HourAdjustFlag = 0;
   Second10Flag = 1;
  if(!SecondAdjust)   //秒調整鍵按下
   while(!SecondAdjust);
   SecondAdjustFlag = 1;
   HourAdjustFlag = 0;
   Second10Flag = 1;
  if(!Adjust)     //調整鍵按下
   while(!Adjust);
   if(HourAdjustFlag)  //調整時,加1
    if(Hour < 23)
     Hour++;
     Second10Count = 0;
     Hour = 0;
   if(MinuteAdjustFlag) //調整分,加1
    if(Minute < 59)
     Minute++;
     Second10Count = 0;
    else    //調整秒,清零
     Minute = 0;
    Second = 0;
//********************************延時程序************************************
Times = Times * 100;
while(Times--);
Keil代碼與Proteus8.8仿真下載:
sz4鍵時鐘.7z (67.49 KB, 下載次數: 27)
參與人數 1黑幣 +40 收起 理由
admin + 40 共享資料的黑幣獎勵!
收藏收藏4 分享淘帖 頂 踩
