查看: 2819|回復(fù): 3
STM32F429IGT6單片機DMA-ADC多通道程序
ID:595030 發(fā)表于 2022-5-21 19:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
已在板子上正常運行讀取了
adc.c
  1. #include "adc.h"
  2. #include "math.h"
  3. __IO uint16_t ADC1ConvertedValue[4]={0,0,0,0};//定義的采集數(shù)據(jù)寄存數(shù)組
  4. float AD_Vaule[4] = {0};        // AD轉(zhuǎn)換值
  5. void ADC1_DMA_Config(void)
  6. {
  7.   ADC_InitTypeDef       ADC_InitStructure;
  8.   ADC_CommonInitTypeDef ADC_CommonInitStructure;
  9.   DMA_InitTypeDef       DMA_InitStructure;
  10.   GPIO_InitTypeDef      GPIO_InitStructure;
  11.         //打開ADC1,DMA2,GPIOA時鐘,DMA1不行,沒有ADC的通道,只能用DMA2
  12.   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 , ENABLE);
  13.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  14.   //通道選擇,ADC1為0和4,ADC2為2和3,ADC3為0和1,
  15.   DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  16.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  17.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  18.   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  19.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  20.   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  21.   DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //外設(shè)普通模式
  22.   DMA_InitStructure.DMA_Priority = DMA_Priority_High;//高等優(yōu)先級
  23.   DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  24.   DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  25.   DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  26.   DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  27.         // 外設(shè)基址為:ADC 數(shù)據(jù)寄存器地址
  28.   DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADCx->DR;//ADCx一律宏定義成了ADC1
  29.
  30.         // 存儲器地址
  31.   DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC1ConvertedValue;
  32.
  33.         // 緩沖區(qū)大小,應(yīng)該等于數(shù)據(jù)目的地的大小
  34.   DMA_InitStructure.DMA_BufferSize = 4;//幾個通道就寫幾
  35.
  36.         // 外設(shè)寄存器只有一個,地址不用遞增
  37.   DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  38.   DMA_Cmd(DMA2_Stream0, ENABLE);
  39.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//A4/A5/A6/A7
  40.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  41.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  42.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  43.   ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  44.   ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  45.   ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  46.   ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  47.   ADC_CommonInit(&ADC_CommonInitStructure);
  48.   ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  49.   ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  50.   ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  51.   ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
  52.         ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  53.
  54.   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  55.         ADC_InitStructure.ADC_NbrOfConversion=4;//
  56.   ADC_Init(ADCx, &ADC_InitStructure);
  57.   //一共四個通道的設(shè)置
  58.   ADC_RegularChannelConfig(ADCx, ADC_Channel_4, 1, ADC_SampleTime_3Cycles);
  59.   ADC_RegularChannelConfig(ADCx, ADC_Channel_5, 2, ADC_SampleTime_3Cycles);
  60.   ADC_RegularChannelConfig(ADCx, ADC_Channel_6, 3, ADC_SampleTime_3Cycles);
  61.   ADC_RegularChannelConfig(ADCx, ADC_Channel_7, 4, ADC_SampleTime_3Cycles);
  62.   ADC_DMARequestAfterLastTransferCmd(ADCx, ENABLE);
  63.   ADC_DMACmd(ADCx, ENABLE);
  64.   ADC_Cmd(ADCx, ENABLE);
  65. }
  66. void ADC1_GetVaule(void)
  67. {
  68.         u8  i = 0;
  69.
  70.   u32 AD[4] = {0};
  71.
  72.         for(i=0;i<30;i++)        // 進行30次轉(zhuǎn)換
  73.         {
  74.                 AD[0] =AD[0] + ADC1ConvertedValue[0];        // 求和
  75.                 AD[1] =AD[1] + ADC1ConvertedValue[1];        // 求和
  76.                 AD[2] =AD[2] + ADC1ConvertedValue[2];        // 求和
  77.                 AD[3] =AD[3] + ADC1ConvertedValue[3];        // 求和
  78.         }        // 啟動轉(zhuǎn)換
  79.                 AD[0] =AD[0]/30;//平均值更穩(wěn)定
  80.                 AD[1] =AD[1]/30;
  81.                 AD[2] =AD[2]/30;
  82.                 AD[3] =AD[3]/30;
  83. //                while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));                        //        等待轉(zhuǎn)換完畢
  84.                 AD_Vaule[0] = (float)AD[0]/4096*3.3;        // //轉(zhuǎn)換成電壓值
  85.                 AD_Vaule[1] = (float)AD[1]/4096*3.3;        // //轉(zhuǎn)換成電壓值
  86.                 AD_Vaule[2] = (float)AD[2]/4096*3.3;        // //轉(zhuǎn)換成電壓值
  87.                 AD_Vaule[3] = (float)AD[3]/4096*3.3;        // //轉(zhuǎn)換成電壓值
  88.
  89. //        AD_Vaule[0]        = AD_Vaule[0] / 30;        // 取平均值
  90. //  AD_Vaule[1]        = AD_Vaule[1] / 30;        // 取平均值
  91. //        AD_Vaule[2]        = AD_Vaule[2] / 30;        // 取平均值
  92. //        AD_Vaule[3]        = AD_Vaule[3] / 30;        // 取平均值
  93. //
  94. }
adc.h
  1. #ifndef __ADC_H
  2. #define __ADC_H
  3. #include "stm32f4xx.h"
  4. #define  ADCx ADC1
  5. /*------------------------------- AD引腳 --------------------------------*/
  6. //#define   ADC1_CH6_PIN                GPIO_Pin_6                                        // ADC1 CH6 引腳
  7. //#define         ADC1_CH6_PORT                GPIOA                                                        // ADC1 CH6 端口
  8. //#define         ADC1_CH6_CLK                RCC_AHB1Periph_GPIOA                // ADC1 CH6 時鐘
  9. /*------------------------------ 函數(shù)聲明 --------------------------------*/
  10.
  11. void ADC1_DMA_Config(void);        // 初始化ADC1
  12. void  ADC1_GetVaule(void);        // 進行AD轉(zhuǎn)換,采集電壓
  13. #endif // __ADC_H
參與人數(shù) 1黑幣 +30 收起 理由
admin + 30 共享資料的黑幣獎勵!
ID:1029703 發(fā)表于 2022-5-26 16:06 | 只看該作者
能不能發(fā)下文件啊
無效樓層,該帖已經(jīng)被刪除
ID:595030 發(fā)表于 2022-6-5 20:10 | 只看該作者
HEIBIBAIBI 發(fā)表于 2022-5-26 16:06
能不能發(fā)下文件啊
可以,已經(jīng)發(fā)了
ID:64696 發(fā)表于 2022-6-6 08:30 | 只看該作者
非常有用,有需要的可以參考
