查看: 3333|回復: 1
單片機數碼管電子鐘程序以及Proteus仿真
寫的電子鐘程序,里面包含了程序文件,proteus仿真電路圖,程序語言上有些不足,僅供參考。
  1. 程序如下:
  2. #include<reg51.h>
  3. unsigned char dat[6]={0};
  4. unsigned char duan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  5. unsigned char wei[6]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
  6. unsigned char num=0;
  7. unsigned char s=0;
  8. unsigned char m=0;
  9. unsigned char h=0;
  10. sbit button1=P3^0;
  11. sbit button2=P3^2;
  12. sbit button3=P3^5;
  13. sbit button4=P3^7;
  14. sbit bee = P1^0;
  15. void delay()
  16. {
  17.         unsigned int i;
  18.         for(i=0;i<100;i++);
  19. }
  20. void Bee()
  21. {
  22.                 bee = 1;
  23.                 delay();
  24.                 bee = 0;
  25.                 delay();
  26. }
  27. void KEY_scan()
  28. {
  29.         if(button1 == 0)
  30.         {
  31.                 h++;
  32.                 while(button1 == 0);
  33.          }
  34.         if(button2 == 0)
  35.         {
  36.                 h--;
  37.                 while(button2 == 0);
  38.         }
  39.         if(button3 == 0)
  40.         {
  41.                 m++;
  42.                 while(button3 == 0);
  43.         }
  44.         if(button4 == 0)
  45.         {
  46.                 m--;
  47.                 while(button4 == 0);
  48.         }
  49. }
  50. void display()
  51. {
  52.         static        unsigned char i = 0;
  53.         dat[0]=h/10;
  54.         dat[1]=h%10;
  55.         dat[2]=m/10;
  56.         dat[3]=m%10;
  57.         dat[4]=s/10;
  58.         dat[5]=s%10;
  59.         {
  60.                 P2=wei[i];
  61.                 P0=duan[dat[i]];
  62.                 i++;
  63.                 if(i>=6)
  64.                 i = 0;
  65.         }
  66. }
  67. unsigned char dz_js(void)
  68. {
  69.         num++;
  70.         if(num==100)
  71.         {
  72.                   num=0;
  73.                   s++;
  74.                   if(s>=60)
  75.                   {
  76.                           s = 0;
  77.                           m++;
  78.                   }
  79.                   if(m>=60)
  80.                   {
  81.                           m = 0;
  82.                         h++;
  83.                         }
  84.                   if(h>=24)
  85.                         h=0;
  86.         }
  87.         return(s,m,h);
  88. }
  89. void T1_svr() interrupt 3
  90. {
  91.         TH1=(65536-10000)/256;
  92.         TL1=(65536-10000)%256;
  93.         dz_js();
  94.         display();
  95. }
  96. void main()
  97. {
  98.         TMOD=0x10;
  99.         TH1=(65536-10000)/256;
  100.         TL1=(65536-10000)%256;
  101.
  102.         ET1 = 1;
  103.         EA = 1;
  104.         TR1 = 1;
  105.         while(1)
  106.         {
  107.                 bee = 0;
  108.                 KEY_scan();
  109.                    if(m == 59)
  110.                 Bee();
  111.         }
  112. }
Keil代碼與Proteus仿真下載: 電子鐘.7z (60.06 KB, 下載次數: 36)
參與人數 1黑幣 +30 收起 理由
admin + 30 共享資料的黑幣獎勵!
收藏收藏2 分享淘帖 頂1 踩
ID:1063002 發表于 2023-2-15 15:58 | 只看該作者
初學者的學習好資料,收下謝謝了!
