查看: 2672|回復(fù): 2
單片機4*4矩陣鍵盤接口電路程序 Proteus仿真圖
ID:449849 發(fā)表于 2022-4-8 10:00 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
設(shè)計一個單片機鍵盤接口電路,實現(xiàn)4*4矩陣鍵盤,用數(shù)碼管顯示相應(yīng)按鍵內(nèi)容,當(dāng)指定某一個按鍵連續(xù)被按三次時,顯示“口”字符號,按鍵有去抖動功能,數(shù)碼管可以通過清零鍵清零。
  1. //0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71 共陰
  2. //0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E 共楊
  3. #include <reg52.h>
  4. #define GPIO_DIG    P0   //段選數(shù)碼管
  5. #define GPIO_KEY     P2      //矩陣按鍵
  6. sbit led = P1^0;
  7. typedef unsigned char uchar;
  8. typedef unsigned int uint;
  9. uint keynum = 0;
  10. uint count=0;
  11. uchar code table[]={0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71};
  12. uchar code table0[]={0x5c};
  13. void delay( uchar i ){
  14.     while( i-- );
  15. }
  16. void key44scan(void)//鍵盤掃描函數(shù)
  17. {
  18. //                uint count=0;
  19.     uint t;
  20.     P2=0xfe;
  21.     t=P2;
  22.     t=t&0xf0;
  23.                 if(t!=0xf0){
  24.                         delay(100);
  25.                         if(t!=0xf0)
  26.                         {
  27.
  28.                                         t=P2;
  29.                                         count++;
  30.                                         switch(t)
  31.                                         {
  32.        case 0xee:keynum=1; break;
  33.        case 0xde:keynum=5; break;
  34.        case 0xbe:keynum=9; break;
  35.        case 0x7e:keynum=13; break;
  36.                                         }
  37.                                         P0=table[keynum];
  38.                                         while(t!=0xf0)
  39.                                         {
  40.                                                          t=P2;
  41.                                                          t=t&0xf0;
  42.                                         }
  43.                         }
  44.                 }
  45.
  46.                 P2=0xfd;
  47.                 t=P2;
  48.                 t=t&0xf0;
  49.                 if(t!=0xf0){
  50.                         delay(100);
  51.                         if(t!=0xf0)
  52.                         {
  53.
  54.                                         t=P2;
  55.                                         count++;
  56.                                         switch(t)
  57.                                         {
  58.        case 0xed:keynum=2; break;
  59.        case 0xdd:keynum=6; break;
  60.        case 0xbd:keynum=10; break;
  61.        case 0x7d:keynum=14; break;
  62.                                         }
  63.                                         P0=table[keynum];
  64.                                         while(t!=0xf0)
  65.                                         {
  66.                                                          t=P2;
  67.                                                          t=t&0xf0;
  68.                                         }
  69.                         }
  70.                 }
  71.                 P2=0xfb;
  72.                 t=P2;
  73.                 t=t&0xf0;
  74.                 if(t!=0xf0){
  75.                         delay(100);
  76.                         if(t!=0xf0)
  77.                         {
  78.
  79.                                         t=P2;
  80.                                         count++;
  81.                                         switch(t)
  82.                                         {
  83.        case 0xeb:keynum=3; break;
  84.        case 0xdb:keynum=7; break;
  85.        case 0xbb:keynum=11; break;
  86.        case 0x7b:keynum=15; break;
  87.                                         }
  88.                                         P0=table[keynum];
  89.                                                         while(t!=0xf0)
  90.                                         {
  91.                                                          t=P2;
  92.                                                          t=t&0xf0;
  93.                                         }
  94.                         }
  95.                 }
  96.                 P2=0xf7;
  97.                 t=P2;
  98.                 t=t&0xf0;
  99.                 if(t!=0xf0){
  100.                         delay(100);
  101.                         if(t!=0xf0)
  102.                         {
  103.
  104.                                         t=P2;
  105.                                         count++;
  106.                                         switch(t)
  107.                                         {
  108.        case 0xe7:keynum=4; break;
  109.        case 0xd7:keynum=8; break;
  110.        case 0xb7:keynum=12; break;
  111.        case 0x77:keynum=0; break;
  112.                                         }
  113.                                         P0=table[keynum];
  114.                                         while(t!=0xf0)
  115.                                         {
  116.                                                          t=P2;
  117.                                                          t=t&0xf0;
  118.                                         }
  119.                         }
  120.                 }
  121. //                        if(count==3){
  122. //                                                count = 0;
  123. //                                                led =~ led;
  124. //                                                P0=table0[0];
  125. //                                                delay(1000);
  126. //                                        }
  127.
  128. }
  129. void main (){
  130.                 led = 0;
  131.     while(1) {
  132.                                         key44scan();
  133.
  134.                                         if(count==3){
  135.                                                 //count = 0;
  136.                                                 led =~ led;
  137.                                                 P0=table0[0];
  138.                                         //        delay(1000);
  139.                                         }
  140.                                         if(count==4){
  141.                                                 count = 0;
  142.                                                 led =~ led;
  143.                                                 P0=table[0];
  144.                                         //        delay(1000);
  145.                                         }
  146.     }
  147. }
Keil代碼與Proteus仿真下載:
實驗2.7z (65.26 KB, 下載次數(shù): 48)
參與人數(shù) 1黑幣 +10 收起 理由
admin + 10 共享資料的黑幣獎勵!
收藏收藏3 分享淘帖 頂1 踩
ID:930389 發(fā)表于 2022-7-1 00:00 | 只看該作者
請問一下那個排阻需要多大的?10k 還是 1k
ID:278457 發(fā)表于 2025-5-20 03:11 | 只看該作者
kiki2314 發(fā)表于 2022-7-1 00:00
1K就行
