查看: 4366|回復: 5
MSP430F5529單片機循跡小車程序
ID:1014854 發表于 2022-4-1 13:27 | 顯示全部樓層 |閱讀模式
//沒有算法,只是簡單的if選擇完成的
int  analogPinq = A0;     // potentiometer wiper (middle terminal) connected to analog pin 3
int  analogPinw = A1;// outside leads to ground and +5V
int val  = 0;           // variable to store the value read
int vak  = 0 ;
int vall = 0;           // variable to store the value read
int vakk = 0 ;
int ena = 40;
int IN1 = 39;
int IN2 = 38;
int IN3 = 37;
int IN4 = 36;
int enb = 35;
int a=1;
int b=1;
int i;
void setup()
  Serial.begin(9600);   //  setup serial
  pinMode(ena,OUTPUT);
  pinMode(enb,OUTPUT);
  pinMode(IN1,OUTPUT);
  pinMode(IN2,OUTPUT);
  pinMode(IN3,OUTPUT);
  pinMode(IN4,OUTPUT);
  digitalWrite(ena,LOW);
void loop()
  vall= digitalRead(analogPinq);
  val = analogRead(analogPinq);
  vakk= digitalRead(analogPinw);
  vak = analogRead(analogPinw) ; //read the input pin
  Serial.print(val);             // debug value
  Serial.print("\t");
  Serial.print(vall);
  Serial.print("\t");
  Serial.print(vak);
  Serial.print("\t");
  Serial.println(vakk);
/*  for(i=0;i<=255;i++)
    a=i;
    b=i;
if (vall==0 && vakk==0)
/*digitalWrite(ena,1);
  digitalWrite(enb,1);
  analogWrite(ena,a);
  analogWrite(enb,b);*/
  analogWrite(IN1,120);
  analogWrite(IN2,0);
  analogWrite(IN3,120);
  analogWrite(IN4,0);
   if (vall==0 && vakk==1)
/*  digitalWrite(ena,1);
  analogWrite(ena,a);
  analogWrite(IN1,0);
  analogWrite(IN2,0);
  analogWrite(IN4,0);
   if (vall==1 && vakk==0)
  analogWrite(ena,a);
  analogWrite(enb,b); */
  analogWrite(IN2,0);
  analogWrite(IN3,0);
  analogWrite(IN4,0);
      if (vall==1 && vakk==1)
  analogWrite(ena,a);
  digitalWrite(IN1,0);
  digitalWrite(IN2,0);
  digitalWrite(IN3,0);
  digitalWrite(IN4,0);
ID:1039079 發表于 2022-7-12 21:50 | 顯示全部樓層
這是幾路循跡,謝謝
ID:1040378 發表于 2022-7-27 16:01 | 顯示全部樓層
兩路循跡嗎
ID:1040674 發表于 2022-7-28 09:51 | 顯示全部樓層
沒用pwm波?嗎用什么驅動的?
ID:1060639 發表于 2023-1-8 09:56 | 顯示全部樓層
這是幾路循跡?
ID:1088048 發表于 2023-7-22 11:05 | 顯示全部樓層
兩路吧
