STC15W408ASP10提升機板測試0.96英寸OLED程序
2022 3 28 07:00 PAST L301 CODE1439
測試顯示中文和阿拉伯數字通過
#include "reg52.h"
#include "intrins.h"
uint Value,A1,A2,A3; //個位 十位 百位
#define high 1
#define low 0
/*************Pin Define***************/
sbit SCL=P3^1;
sbit SDA=P3^0;
void Initial_LY096BG30();
void Delay_50ms(unsigned int Del_50ms);
void Delay_1ms(unsigned int Del_1ms);
void fill_picture(unsigned char fill_Data);
void Picture_1();
void Picture();
void IIC_Start();
void IIC_Stop();
void Write_IIC_Command(unsigned char IIC_Command);
void Write_IIC_Data(unsigned char IIC_Data);
bit Write_IIC_Byte(unsigned char IIC_Byte);
/***********************Initial code*********************/
Write_IIC_Command(0xAE); //display off
Write_IIC_Command(0x20); //Set Memory Addressing Mode
Write_IIC_Command(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
Write_IIC_Command(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
Write_IIC_Command(0xc8); //Set COM Output Scan Direction
Write_IIC_Command(0x00); //---set low column address
Write_IIC_Command(0x10); //---set high column address
Write_IIC_Command(0x40); //--set start line address
Write_IIC_Command(0x81); //--set contrast control register
Write_IIC_Command(0x7f);
Write_IIC_Command(0xa1); //--set segment re-map 0 to 127
Write_IIC_Command(0xa6); //--set normal display
Write_IIC_Command(0xa8); //--set multiplex ratio(1 to 64)
Write_IIC_Command(0x3F); //
Write_IIC_Command(0xa4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
Write_IIC_Command(0xd3); //-set display offset
Write_IIC_Command(0x00); //-not offset
Write_IIC_Command(0xd5); //--set display clock divide ratio/oscillator frequency
Write_IIC_Command(0xf0); //--set divide ratio
Write_IIC_Command(0xd9); //--set pre-charge period
Write_IIC_Command(0x22); //
Write_IIC_Command(0xda); //--set com pins hardware configuration
Write_IIC_Command(0x12);
Write_IIC_Command(0xdb); //--set vcomh
Write_IIC_Command(0x20); //0x20,0.77xVcc
Write_IIC_Command(0x8d); //--set DC-DC enable
Write_IIC_Command(0x14); //
Write_IIC_Command(0xaf); //--turn on oled panel
/***********************0--A字符表*************************/
unsigned char code show1[]=
0x00,0xF0,0x08,0x08,0x08,0x08,0xF0,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0X00,/*0CODE*/
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0X00,/*1CODE*/
0x00,0x70,0x08,0x08,0x08,0x08,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,/*2CODE*/
0X00,0X30,0X08,0X88,0X88,0X48,0X28,0X00,0X00,0X18,0X20,0X20,0X20,0X11,0X0E,0X00,/*3CODE*/
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,/*4CODE*/
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x18,0x21,0x20,0x20,0x11,0x0E,0x00,/*5CODE*/
0x00,0xE0,0x10,0x88,0x88,0x08,0x10,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,/*6CODE*/
0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,/*7CODE*/
0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,/*8CODE*/
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x10,0x21,0x22,0x22,0x11,0x0F,0x00,/*9CODE*/
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x1F,0x01,0x01,0x01,0x01,0x1F,0x00,/*ACODE*/
/***********測試字符表*陰碼 逆向 列行*************************/
unsigned char code show2[]=
0x80,0x64,0x2C,0x34,0x24,0x24,0xEC,0x32,0x22,0x22,0x32,0x2E,0x23,0xA2,0x60,0x00,
0x00,0x41,0x21,0x91,0x89,0x87,0x4D,0x55,0x25,0x25,0x55,0x4D,0x81,0x80,0x80,0x00,/*"愛",0*/
0x00,0x00,0xE0,0x9F,0x88,0x88,0x88,0x88,0x88,0x88,0x88,0x88,0x88,0x08,0x00,0x00,
0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x48,0x80,0x40,0x3F,0x00,0x00,0x00,/*"與",1*/
0x04,0x04,0x04,0xE4,0x24,0x24,0x25,0x26,0x24,0x24,0x24,0xE4,0x04,0x04,0x04,0x00,
0x20,0x20,0x10,0x11,0x09,0xFD,0x43,0x21,0x03,0x05,0x09,0x11,0x28,0x44,0x40,0x00,/*"哀",2*/
0x10,0x92,0x52,0x32,0xFF,0x51,0x91,0x20,0x18,0xC0,0x3F,0xC0,0x10,0x0C,0x00,0x00,
0x01,0x40,0x30,0x00,0x77,0x80,0x84,0x8A,0xB1,0x80,0xE0,0x00,0x11,0x62,0x04,0x00,/*"愁",3*/
0x20,0x20,0x24,0xA4,0xAC,0xB4,0xA5,0xA6,0xA4,0xB4,0xAC,0xA4,0x24,0x20,0x20,0x00,
0x80,0x80,0xA0,0xAF,0xAA,0xAA,0xAA,0xFF,0xAA,0xAA,0xAA,0xAF,0xA0,0x80,0x80,0x00,/*"童",4*/
0x80,0x90,0x8C,0x84,0x84,0x84,0xF5,0x86,0x84,0x84,0x84,0x84,0x94,0x8C,0x80,0x00,
0x00,0x80,0x80,0x84,0x46,0x49,0x28,0x10,0x10,0x2C,0x23,0x40,0x80,0x00,0x00,0x00,/*"安",5*/
0x10,0x10,0xD0,0xFF,0x90,0x20,0x10,0x18,0xA7,0x44,0xA4,0x14,0x0C,0x00,0x00,0x00,
0x04,0x03,0x00,0xFF,0x00,0x05,0x02,0xFD,0x44,0x44,0x44,0x45,0xFD,0x02,0x02,0x00,/*"格",6*/
/*******************IIC Start******************/
void IIC_Start()
SCL=high;
//Delay_us(1);
SDA=high;
_nop_();
SDA=low;
_nop_();_nop_();
SCL=low;
/*************IIC Stop*************************/
void IIC_Stop()
SDA=low;
_nop_();
SCL=high;
_nop_();_nop_();
SDA=high;
/*****************IIC Write byte***************/
unsigned char i;
bit Ack_Bit; //應答信號
for(i=0;i<8;i++)
if(IIC_Byte & 0x80) //1?0?
SDA=high;
SDA=low;
//Delay_us(1);
SCL=high;
_nop_();_nop_();
SCL=low;
//Delay_us(1);
IIC_Byte<<=1; //loop
SDA=high; //釋放IIC SDA總線為主器件接收從器件產生應答信號
_nop_();_nop_();
SCL=high; //第9個時鐘周期
_nop_();_nop_();
Ack_Bit=SDA; //讀取應答信號
SCL=low;
return Ack_Bit;
/*************IIC Write Command*****************/
IIC_Start();
Write_IIC_Byte(0x78); //Slave address,SA0=0
Write_IIC_Byte(0x00); //write command
Write_IIC_Byte(IIC_Command);
IIC_Stop();
/****************IIC Write Data*****************/
IIC_Start();
Write_IIC_Byte(0x40); //write data
Write_IIC_Byte(IIC_Data);
IIC_Stop();
/*******************fill_Picture*****************/
unsigned char m,n;
for(m=0;m<8;m++)
Write_IIC_Command(0xb0+m); //page0-page1
Write_IIC_Command(0x00); //low column start address
Write_IIC_Command(0x10); //high column start address
for(n=0;n<128;n++)
Write_IIC_Data(fill_Data);
/********************picture**********************/
void cleardisp()
unsigned char x,y;
for(y=0;y<8;y++)
Write_IIC_Command(0xb0+y);
for(x=0;x<128;x++) //橫向像素
Write_IIC_Data(0X00);
void picture_1()
unsigned char x,y;
unsigned int i=0;
for(y=0;y<2;y++)
Write_IIC_Command(0xb0+y); //豎向第一行 童
Write_IIC_Command(0x12); //橫向第一個字
for(x=0;x<16;x++) //橫向像素
Write_IIC_Data(show2[x+y*16+128]);
for(y=0;y<2;y++)
Write_IIC_Command(0xb0+y); //豎向第一行 安
Write_IIC_Command(0x13); //橫向第二個字
Write_IIC_Data(show2[x+y*16+160]);
for(y=0;y<2;y++)
Write_IIC_Command(0xb0+y); //豎向第一行 格
Write_IIC_Command(0x14); //橫向第二個字
Write_IIC_Data(show2[x+y*16+192]);
for(y=0;y<2;y++) //愛
Write_IIC_Command(0xb2+y); //豎向第二行
Write_IIC_Data(show2[x+y*16]);
for(y=0;y<2;y++) //與
Write_IIC_Data(show2[x+y*16+32]);
for(y=0;y<2;y++) //哀
Write_IIC_Command(0x14); //橫向第一個字
Write_IIC_Data(show2[x+y*16+64]);
for(y=0;y<2;y++) //愁
Write_IIC_Command(0x15); //橫向第二個字
Write_IIC_Data(show2[x+y*16+96]);
/***************以上顯示中文”測試”兩字“************/
for(Value=0;Value<1000;Value++)
A1=Value/100;
A2=(Value-A1*100)/10;
A3=Value-A1*100-A2*10;
for(y=0;y<2;y++) //百位顯示
Write_IIC_Command(0XB5+y); //縱向頁
Write_IIC_Command(00); //橫向離左部邊緣開始的距離
Write_IIC_Command(0X13); //橫向第四個字
for(x=0;x<8;x++) //橫向像素
Write_IIC_Data(show1[x+y*8+A1*16]);
for(y=0;y<2;y++) //十位顯示
Write_IIC_Command(0XB5+y);//縱向頁
Write_IIC_Command(0X14); //橫向第五個字
Write_IIC_Data(show1[x+y*8+A2*16]);
for(y=0;y<2;y++) //個位顯示
Write_IIC_Command(0X15); //橫向第六個字
Write_IIC_Data(show1[x+y*8+A3*16]);
Delay_50ms(3);
/**************Delay*******************************/
void Delay_50ms(unsigned int Del_50ms) //
unsigned int m;
for(;Del_50ms>0;Del_50ms--)
for(m=62450;m>0;m--);
/**************Delay_1ms***************************/
void Delay_1ms(unsigned int Del_1ms) //
unsigned char j;
while(Del_1ms--)
for(j=0;j<123;j++);
/*******************************Main*******************************/
void main(void) // Value,A1,A2;
Initial_LY096BG30(); //初始化顯示屏
Delay_1ms(5);
Value=0;
cleardisp();
fill_picture(0xff); //全部填充顯示屏
Delay_50ms(40);
cleardisp();
fill_picture(0x02); //全部填充顯示屏
Delay_50ms(40);
cleardisp();
Picture_1(); //
} //L301 CODE1439 2022 3 28提升機板測試0.96 inch OLED
