查看: 2388|回復: 0
STM32F0位帶操作
ID:302293 發表于 2022-3-25 17:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#ifndef __sys_H
#define __sys_H
#include "stm32f0xx.h"
typedef struct _16_Bits_Struct
    uint16_t bit0 : 1;//占一個bit
    uint16_t bit1 : 1;
    uint16_t bit2 : 1;
    uint16_t bit3 : 1;
    uint16_t bit4 : 1;
    uint16_t bit5 : 1;
    uint16_t bit6 : 1;
    uint16_t bit7 : 1;
    uint16_t bit8 : 1;
    uint16_t bit9 : 1;
    uint16_t bit10 : 1;
    uint16_t bit11 : 1;
    uint16_t bit12 : 1;
    uint16_t bit13 : 1;
    uint16_t bit14 : 1;
    uint16_t bit15 : 1;
} Bits_16_TypeDef;
//結構體和端口結合,輸出
#define BITS_PORT_B_OUT    ((Bits_16_TypeDef *)(&(GPIOB->ODR)))  //結構體結合到GPIOB->ODR
#define LED_5V             (BITS_PORT_B_OUT->bit6)               //LED接在GPIOB->ODR->bit6
#define OLED_SCL           (BITS_PORT_B_OUT->bit1)
#define OLED_SDA           (BITS_PORT_B_OUT->bit10)
#define OLED_RST           (BITS_PORT_B_OUT->bit12)
#define OLED_DC            (BITS_PORT_B_OUT->bit14)
#define BITS_PORT_A_OUT    ((Bits_16_TypeDef *)(&(GPIOA->ODR)))  //結構體結合到GPIOA->ODR
#define OLED_nCS           (BITS_PORT_A_OUT->bit8)              //OLED_nCS接在GPIOC->ODR->bit13
#define BITS_PORT_C_OUT    ((Bits_16_TypeDef *)(&(GPIOC->ODR)))  //結構體結合到GPIOC->ODR
#define LED_3V             (BITS_PORT_C_OUT->bit13)              //LED接在GPIOC->ODR->bit13
//結構體和端口結合,輸入
#define BITS_PORT_B_IN    ((Bits_16_TypeDef *)(&(GPIOB->IDR)))  //結構體結合到GPIOB->IDR
#define IN_B_5             (BITS_PORT_B_IN->bit5)               //輸入端口接在GPIOB->IDR->bit5
#endif
