使用1602顯示DHT22的溫濕度,精確到小數點的后一位
// DHT21使用范例
//單片機 AT89S52 或 STC89C52RC
//功能 串口發送溫濕度數據 晶振 11.0592M 波特率 9600
//硬件 P2.0口為通訊口連接DHT22,DHT22的電源和地連接單片機的電源和地,單片機串口加MAX232連接電腦
#include <reg51.h>
#include <intrins.h>
typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無符號8位整型變量 */
typedef signed char S8; /* defined for signed 8-bits integer variable 有符號8位整型變量 */
typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無符號16位整型變量 */
typedef signed int S16; /* defined for signed 16-bits integer variable 有符號16位整型變量 */
typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無符號32位整型變量 */
typedef signed long S32; /* defined for signed 32-bits integer variable 有符號32位整型變量 */
typedef float F32; /* single precision floating point variable (32bits) 單精度浮點數(32位長度) */
typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點數(64位長度) */
#define Data_0_time 4
#define LCD1602_DB P0
sbit LCD1602_RS = P2^0;
sbit LCD1602_RW = P2^1;
sbit LCD1602_E = P2^2;
/* 等待液晶準備好 */
void LcdWaitReady()
unsigned char sta;
LCD1602_DB = 0xFF;
LCD1602_RS = 0;
LCD1602_RW = 1;
do {
LCD1602_E = 1;
sta = LCD1602_DB; //讀取狀態字
LCD1602_E = 0;
} while (sta & 0x80); //bit7等于1表示液晶正忙,重復檢測直到其等于0為止
/* 向LCD1602液晶寫入一字節命令,cmd-待寫入命令值 */
void LcdWriteCmd(unsigned char cmd)
LcdWaitReady();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_E = 1;
LCD1602_E = 0;
/* 向LCD1602液晶寫入一字節數據,dat-待寫入數據值 */
void LcdWriteDat(unsigned char dat)
LcdWaitReady();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_E = 1;
LCD1602_E = 0;
/* 設置顯示RAM起始地址,亦即光標位置,(x,y)-對應屏幕上的字符坐標 */
void LcdSetCursor(unsigned char x, unsigned char y)
unsigned char addr;
if (y == 0) //由輸入的屏幕坐標計算顯示RAM的地址
addr = 0x00 + x; //第一行字符地址從0x00起始
addr = 0x40 + x; //第二行字符地址從0x40起始
LcdWriteCmd(addr | 0x80); //設置RAM地址
/* 在液晶上顯示字符串,(x,y)-對應屏幕上的起始坐標,str-字符串指針 */
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
LcdSetCursor(x, y); //設置起始地址
while (*str != '\0') //連續寫入字符串數據,直到檢測到結束符
LcdWriteDat(*str++);
/* 打開光標的閃爍效果 */
void LcdOpenCursor()
LcdWriteCmd(0x0F);
/* 關閉光標顯示 */
void LcdCloseCursor()
LcdWriteCmd(0x0C);
/* 初始化1602液晶 */
void InitLcd1602()
LcdWriteCmd(0x38); //16*2顯示,5*7點陣,8位數據接口
LcdWriteCmd(0x0C); //顯示器開,光標關閉
LcdWriteCmd(0x06); //文字不動,地址自動+1
LcdWriteCmd(0x01); //清屏
//----------------IO口定義區--------------------//
sbit P2_0 = P2^3 ;
//----------------定義區--------------------//
U8 U8FLAG,k;
U8 U8count,U8temp;
U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8 U8comdata;
U8 outdata[5]; //定義發送的字節數
U8 indata[5];
U8 count, count_r=0;
U8 str[4];
U16 U16temp1,U16temp2;
SendData(U8 *a)
outdata[0] = a[0];
outdata[1] = a[1];
outdata[2] = a[2];
outdata[3] = a[3];
outdata[4] = a[4];
count = 1;
SBUF=outdata[0];
void Delay(U16 j)
{ U8 i;
for(;j>0;j--)
for(i=0;i<27;i++);
void Delay_10us(void)
U8 i;
i--;
i--;
i--;
i--;
i--;
i--;
void COM(void)
U8 i;
for(i=0;i<8;i++)
U8FLAG=2;
while((!P2_0)&&U8FLAG++);
Delay_10us();
Delay_10us();
Delay_10us();
U8temp=0;
if(P2_0)U8temp=1;
U8FLAG=2;
while((P2_0)&&U8FLAG++);
//超時則跳出for循環
if(U8FLAG==1)break;
//判斷數據位是0還是1
// 如果高電平高過預定0高電平值則數據位為 1
U8comdata<<=1;
U8comdata|=U8temp; //0
}//rof
//-----濕度讀取子程序 ------------
//----以下變量均為全局變量--------
//----溫度高8位== U8T_data_H------
//----溫度低8位== U8T_data_L------
//----濕度高8位== U8RH_data_H-----
//----濕度低8位== U8RH_data_L-----
//----校驗 8位 == U8checkdata-----
//----調用相關子程序如下----------
//---- Delay();, Delay_10us();,COM();
void RH(void)
//主機拉低18ms
P2_0=0;
Delay(180);
P2_0=1;
//總線由上拉電阻拉高 主機延時20us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
//主機設為輸入 判斷從機響應信號
P2_0=1;
//判斷從機是否有低電平響應信號 如不響應則跳出,響應則向下運行
if(!P2_0) //T !
U8FLAG=2;
//判斷從機是否發出 80us 的低電平響應信號是否結束
U8FLAG=2;
//判斷從機是否發出 80us 的高電平,如發出則進入數據接收狀態
//數據接收狀態
COM();
U8RH_data_H_temp=U8comdata;
COM();
U8RH_data_L_temp=U8comdata;
COM();
U8T_data_H_temp=U8comdata;
COM();
U8T_data_L_temp=U8comdata;
COM();
U8checkdata_temp=U8comdata;
P2_0=1;
//數據校驗
U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
if(U8temp==U8checkdata_temp)
U8RH_data_H=U8RH_data_H_temp;
U8RH_data_L=U8RH_data_L_temp;
U8T_data_H=U8T_data_H_temp;
U8T_data_L=U8T_data_L_temp;
U8checkdata=U8checkdata_temp;
}//fi
}//fi
//main()功能描述: AT89C51 11.0592MHz 串口發
//送溫濕度數據,波特率 9600
U16 wendu = 0;
U16 shidu = 0;
U8 wendu_zu[4];
U8 shidu_zu[4];
//uchar str[6]={"RS232"};
/* 系統初始化 */
TMOD = 0x20; //定時器T1使用工作方式2
TH1 = 253; // 設置初值
TL1 = 253;
TR1 = 1; // 開始計時
SCON = 0x50; //工作方式1,波特率9600bps,允許接收
ES = 1;
EA = 1; // 打開所以中斷
TI = 0;
RI = 0;
SendData(str) ; //發送到串口
Delay(10); //延時100US(12M晶振)
InitLcd1602();
//調用溫濕度讀取子程序
RH();
//串口顯示程序
wendu = (((U16)U8RH_data_H<<8)|(U16)U8RH_data_L);
shidu = (((U16)U8T_data_H<<8)|(U16)U8T_data_L);
wendu_zu[3]=wendu%10 + '0';
wendu_zu[2]='.';
wendu_zu[1]=(wendu/10)%10+ '0';
wendu_zu[0]=wendu/100+ '0';
shidu_zu[3] = shidu%10 + '0';
shidu_zu[2] = '.';
shidu_zu[1] = (shidu/10)%10+ '0';
shidu_zu[0] = shidu/100 + '0';
LcdShowStr(0,0,wendu_zu);
LcdShowStr(0,1,shidu_zu);
//讀取模塊數據周期不宜小于 2S
Delay(2000);
}//elihw
}// main
//void RSINTR() interrupt 4 using 2
// U8 InPut3;
// if(TI==1) //發送中斷
// TI=0;
// if(count!=5) //發送完5位數據
// SBUF= outdata[count];
// count++;
// if(RI==1) //接收中斷
// InPut3=SBUF;
// indata[count_r]=InPut3;
// count_r++;
// RI=0;
// if (count_r==5)//接收完4位數據
// //數據接收完畢處理。
// count_r=0;
// str[0]=indata[0];
// str[1]=indata[1];
// str[2]=indata[2];
// str[3]=indata[3];
// str[4]=indata[4];
// P0=0;
