修改頭文件和硬件連接。
#include <iom128v.h>
#include <macros.h>
//DO數(shù)據(jù)
uchar scan[9]={0x01,0x42,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
//存放DI數(shù)據(jù)
uchar re_code[9];
uint m;
//共陰數(shù)碼管段碼
uchar ddd[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
//位碼
uchar www[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
void port_init(void)
DDRE=0xff;
PORTE=0x00; //段選
DDRB=0xff;
PORTB=0xff; //位選
//PD0->DAT輸入;PD1->CMD輸出;PD2->CS輸出;PD3->CLK輸出
DDRD =(0<<PD0)|(1<<PD1)|(1<<PD2)|(1<<PD3) ;
PORTD =0;
void delay(uint n)
uint i;
for(i=0;i<n;i++);
uchar scanout(uchar command) //向手柄發(fā)送命令并接受反饋的子程序
uchar i,j=1;
uchar res=0;
for(i=0;i<8;i++) //逐位接收
if(command&0x01) cmd_set;
else cmd_clr;
command=command>>1;
delay(1);
clk_clr;
delay(1); //這里延時(shí)很關(guān)鍵,太多了手柄就反應(yīng)遲鈍了
if(PIND&0x01) res=res+j; //這里就開始同步接收DI值了
j=j<<1;
clk_set;
delay(2);
return res;
void Read_PS2(void) //向手柄發(fā)送DO并將反饋DI存入re_code[ ]中
uchar i;
cs_clr;
for(i=0;i<9;i++) re_code=scanout(scan);
cs_set;
void main(void)
port_init();
delay(50);
Read_PS2();
delay(200);
m=re_code[3]*256+re_code[4];
PORTE=ddd[m/256/16];
PORTB=www[3];
delay(50);
PORTE=ddd[m/256%16];
PORTB=www[2];
delay(50);
PORTE=ddd[m%256/16];
PORTB=www[1];
delay(50);
PORTE=ddd[m%256%16];
PORTB=www[0];
delay(50);
PORTE=ddd[out[7]/16];
PORTB=www[7];
delay(50);
PORTE=ddd[out[7]%16];
PORTB=www[6];
delay(50);
PORTE=ddd[out[8]/16];
PORTB=www[5];
delay(50);
PORTE=ddd[out[8]%16];
PORTB=www[4];
delay(50);
評(píng)分
查看全部評(píng)分
