查看: 3076|回復: 0
基于51單片機智能門鎖代碼 輸入密碼時以*號代替,連續輸錯三次蜂鳴器響,LED燈閃
輸入密碼時以*號代替,連續輸入錯誤三次蜂鳴器響,LED燈閃爍。
制作出來的實物圖如下:
  1. #include<reg52.h>
  2. sbit AS=P2^2;
  3. sbit LED=P1^0;
  4. sbit Buzz=P1^1;
  5. bit enBuzz=0;
  6. bit enLED=0;
  7. extern void LCDshowstr(unsigned char x,unsigned char y,unsigned char *str);
  8. extern void E2read(unsigned char *buf,unsigned char addr,unsigned char len);
  9. extern void E2write(unsigned char *buf,unsigned char addr,unsigned char len);
  10. extern void keydriver();
  11. extern void LCDwritedat(unsigned char dat);
  12. extern void InitLCD1602();
  13. extern void keyscan();
  14. extern void LCDwritecmd(unsigned char cmd);
  15. void configtimer0(unsigned char ms);
  16. void keyaction(unsigned char keycode);
  17. void oprtkey(unsigned char number);
  18. unsigned char T0RH=0;
  19. unsigned char T0RL=0;
  20. unsigned char pw_num;
  21. unsigned char PassWord_Length=6;
  22. unsigned char result_flag=0;
  23. unsigned char Tad[10];
  24. unsigned char buf[6]={6,6,6,6,6,6};
  25. unsigned char step;
  26. unsigned char keynumbers;
  27. unsigned char Error_Num=0;
  28. bit Input_suc_flag=0;
  29. bit fanhui=0;
  30. bit List1=0;
  31. bit keynumber=0;
  32. bit key0=0;
  33. bit key1=0;
  34. bit key2=0;
  35. bit key3=0;
  36. bit key4=0;
  37. bit key5=0;
  38. bit key6=0;
  39. bit key7=0;
  40. bit key8=0;
  41. bit key9=0;
  42. bit start=0;
  43. unsigned char baojing=0;
  44. unsigned char step5=0;
  45. void step_0();
  46. void step_1();
  47. void step_2();
  48. void step_3();
  49. void step_4();
  50. void step_5();
  51. void step5_0();
  52. void step5_1();
  53. void step5_2();
  54. void step5_3();
  55. void step5_4();
  56. void step5_5();
  57. void step_6();
  58. void input_password(bit m);
  59. void CipherComparison();
  60. void delay(unsigned long i)
  61. {
  62. while(i--);
  63. }
  64. void main()
  65. {
  66.         EA=1;
  67.         InitLCD1602();
  68.         E2write(buf,0x00,sizeof(buf));
  69.         //InitLCD1602();
  70.         configtimer0(1);
  71.         step=0;
  72.         while(1)
  73.         {  keydriver();
  74.         switch(step)
  75.         {
  76.                 case 0:{step_0();
  77.                                 if(keynumber==0)
  78.                                 step=0;
  79.                                 else
  80.                                 {keynumber=0;
  81.                                 step=1;                 }
  82.                                 break;}
  83.                 case 1:step_1();break;
  84.                 case 2:step_2();break;
  85.                 case 3:step_3();break;
  86.                 case 4:step_4();break;
  87.                 case 5:step_5();break;
  88.                 case 6:step_6();break;
  89.         }
  90.         }
  91.         }
  92. void step_0()
  93. {
  94.         LCDshowstr(0,0,"Pechin Science");
  95.         LCDshowstr(1,1,"welcome");
  96.         }
  97. void step_1()
  98. {
  99.         LCDwritecmd(0x01);
  100.     LCDshowstr(0,0,"Unlock");
  101.         LCDshowstr(15,0,"<");
  102.         LCDshowstr(0,1,"ChangePassword");
  103.     step=2;
  104.         }
  105. void step_2()
  106. {
  107. if(start==0)
  108.                 {
  109.                                         if((key1==1) ||( key9==1))                    //1鍵或9鍵按下
  110.                                         {
  111.        key1=0;
  112.        key9=0;
  113.        List1=~List1;                           //Change Password
  114.        if(List1==0)
  115.        {
  116.        LCDshowstr(15,0,"<");                           // Unlock            <
  117.        LCDshowstr(15,1," ");                                  // Change Password
  118.        }
  119.        else
  120.        {
  121.        LCDshowstr(15,0," ");                           // Unlock
  122.        LCDshowstr(15,1,"<");                                  // Change Password   <
  123.        }
  124.                                         }
  125.                 }
  126.         else                                                           //確認鍵按下
  127.         {                 start=0;
  128.                                         if(List1==0)
  129.                                         {step=3;}
  130.                                         else
  131.                                         {step=5;List1=0;}
  132.         }}
  133.
  134. void step_3()
  135. {
  136.         step=4;
  137.         pw_num=0;
  138.     InitLCD1602();
  139.     LCDshowstr(0,0,"Pass Word:  ");
  140.         }
  141. void step_4()
  142. {
  143.            input_password(0);
  144.            if(Input_suc_flag==1){step=6;}
  145.       Input_suc_flag=0;
  146. }
  147. void step_5()  //修改密碼
  148. {
  149.         switch(step5)
  150.         {
  151.
  152.                         case 0: {step5_0();}  break;
  153.                         case 1: {step5_1();}  break;
  154.                         case 2: {step5_2();}  break;
  155.                         case 3: {step5_3();}  break;
  156.                     case 4: {step5_4();}  break;
  157.                         case 5:        {step5_5();}  break;
  158.         }
  159. }
  160. void step5_0()
  161. {
  162.         LCDwritecmd(0x01);
  163.         LCDshowstr(0,0,"Input PassWord:");
  164.         step5=1;
  165.         pw_num=0;
  166.           }
  167. void step5_1()
  168. {
  169.                 input_password(0);
  170.                 if(Input_suc_flag==1)
  171.                         {
  172.                                 step5=2;
  173.                                 Input_suc_flag=0;
  174.                         }
  175. }
  176. void step5_2()
  177. {
  178.      CipherComparison();
  179.            step5=3;
  180. }
  181. void step5_3()
  182. {
  183.     if(result_flag==0)
  184.                                 {
  185.                                                         if(Error_Num<=3)
  186.                                                         {
  187.        Error_Num++;
  188.        InitLCD1602();
  189.        LCDshowstr(0,0,"Error 01");
  190.        delay(50000);
  191.        step5=0;
  192.                                                         }
  193.                                                         else
  194.                                                         {
  195.        Error_Num=0;
  196.        step=0;
  197.                                                         }
  198.
  199.                                 }
  200.                 else
  201.                                 {
  202.                                         InitLCD1602();
  203.                                         LCDshowstr(0,0,"New PassWord:");
  204.                                         pw_num=0;
  205.                                         step5=4;
  206.                                 }
  207.
  208.
  209. }
  210. void step5_4()
  211. {
  212.                 input_password(1);
  213.                 if(Input_suc_flag==1)
  214.                         {
  215.                                 step5=5;
  216.                                 Input_suc_flag=0;
  217.                                 LCDwritecmd(0x01);
  218.               LCDshowstr(0,0,"OK!nice!");
  219.                   delay(500000);
  220.                         }
  221. }
  222. void step5_5()
  223. {
  224.         unsigned char x;
  225.         PassWord_Length=pw_num;
  226.
  227.         for(x=0;x<pw_num;x++)
  228.         {
  229.                 buf[x]=Tad[x];
  230.                 }
  231.         E2write(buf,0x00,PassWord_Length);
  232.         step5=0;
  233.         step=0;
  234. }
  235. void step_6()
  236. {
  237.         static unsigned char k=1; //錯誤次數
  238.         static unsigned char n=30;
  239.         unsigned char numberbuf[2];
  240.         CipherComparison();
  241.         if(result_flag==1)         //密碼正確
  242.                 {                k=0;
  243.                                 InitLCD1602();
  244.                                 LCDshowstr(0,0,"    WELCOME!");
  245.                                 AS=0;                                         //開繼電器
  246.                                 delay(60000);
  247.                                 delay(60000);
  248.                                 AS=1;                                                //關繼電器
  249.                 }
  250.         else                                                //密碼錯誤
  251.                 {
  252.                                 if(k<3)
  253.                                 {        k++;
  254.                                 InitLCD1602();                                   //
  255.                                 LCDshowstr(0,0,"Error 01!");   //
  256.                                 delay(100000);
  257.                                 }
  258.                                 else
  259.                                 {
  260.                                    while(n>0)
  261.                                            {
  262.                                         InitLCD1602();
  263.                                         numberbuf[0]=(n/10)+0x30;
  264.                                         numberbuf[1]=(n%10)+0x30;
  265.                                         LCDshowstr(12,1,numberbuf);
  266.                                          enBuzz=1;                                //
  267.                                 enLED=1;
  268.                                         if(baojing==1)
  269.                                         {
  270.                                     baojing=0;
  271.                                     n--;
  272.                                          }}
  273.                                          n=30;
  274.                                          enLED=0;
  275.                                          enBuzz=0;
  276.                                 /*  enBuzz=1;                                //
  277.                               enLED=1;                          //
  278.                                   delay(600000);           //
  279.                                    enLED=0;                          //
  280.                                     enBuzz=0; */
  281.                                         }                  //
  282.                 }
  283.
  284.                 step=0;
  285.
  286. }
  287. void input_password(bit m)
  288. {
  289.         unsigned char j;
  290.         if(start==0)                                      //ok鍵沒有按下
  291.                 {
  292.                         if((key0==1)||(key1==1)||(key2==1)||(key3==1)||(key4==1)||(key5==1)||(key6==1)||(key7==1)||(key8==1)||(key9==1))                               //1-9按下
  293.                         {
  294.
  295.                                                 key0=0,key1=0,key2=0,key3=0,key4=0,key5=0,key6=0,key7=0,key8=0,key9=0;
  296.                                                    Tad[pw_num]=keynumbers;
  297.                                    pw_num++;
  298.                                                    LCDwritecmd(0xc0);
  299.                                                  for(j=0;j<pw_num;j++)
  300.        {
  301.        if(m==0)
  302.        {LCDwritedat('*');        }                        //密碼隱藏
  303.        else
  304.        {LCDwritedat(Tad[j]+0x30);}         //顯示密碼
  305.        }}
  306.                                         if(fanhui!=0)                              //返回鍵按下
  307.                                         {
  308.                                                 fanhui=0;
  309.                                                 if(pw_num!=0)
  310.                                                 {pw_num--;}
  311.                                                 else
  312.                                                 {step=0;}
  313.                                         // ShowString (0x00,"Pass Word:");
  314.                                         LCDwritecmd(0x01);
  315.                                         LCDshowstr(0,0,"Pass Word:  ");
  316.                     LCDwritecmd(0xc0);
  317.        for(j=0;j<pw_num;j++)
  318.        {
  319.        if(m==0) {LCDwritedat('*');        }                        //密碼隱藏
  320.        else     {LCDshowstr(0,1,Tad);}    //顯示密碼
  321.        }
  322.        //LCDwritedat(' ');
  323.                                         }
  324.                 }
  325.         else                          //ok鍵按下
  326.           {
  327.                        start=0;
  328.                         if(pw_num==0)
  329.                                         {
  330.                                                         step=0;
  331.                                                   LCDwritecmd(0x01);
  332.                                                  LCDshowstr(0,0,"Error 02!");
  333.                                                         delay(600000);
  334.                                         }
  335.
  336.                         else{
  337.                                                         Input_suc_flag=1;
  338.                                         }
  339.                                          //AS=0;
  340.                 }
  341. }
  342. void keyaction(unsigned char keycode)
  343. {
  344.         if((keycode>=0x30)&&(keycode<=0x39))
  345.         {
  346.                 keynumbers=keycode-0x30;
  347.                  }
  348.
  349.
  350.         }
  351.
  352.
  353. void oprtkey(unsigned char number)
  354. {
  355.         if(number==1)
  356.         keynumber=1;
  357.         else if(number==2)
  358.         key1=1;
  359.         else if(number==3)
  360.         key9=1;
  361.         else if(number==4)
  362.         start=1;
  363.         else if(number==5)
  364.         key2=1;
  365.         else if(number==6)
  366.         key3=1;
  367.         else if(number==7)
  368.         key4=1;
  369.         else if(number==8)
  370.         key5=1;
  371.         else if(number==9)
  372.         key6=1;
  373.         else if(number==10)
  374.         key7=1;
  375.         else if(number==11)
  376.         key8=1;
  377.         else if(number==12)
  378.         key0=1;
  379.         else if(number==13)
  380.         fanhui=1;
  381.         }
  382. void CipherComparison()
  383. {
  384.                 unsigned char i=0,j=0;
  385.         if(PassWord_Length==pw_num)                       //密碼長度比對
  386.         {
  387.                 for(i=0;i<PassWord_Length;i++)                  //密碼比對
  388.                 {
  389.
  390.                                 if(buf[i]!=Tad[i])
  391.                                         {
  392.                                                 result_flag=0;break;                     //密碼錯誤
  393.                                         }
  394. ……………………
  395. …………限于本文篇幅 余下代碼請從51黑下載附件…………
Keil代碼下載:
智能門鎖代碼.7z (39.88 KB, 下載次數: 38)
收藏收藏3 分享淘帖 頂1 踩1
