查看: 2276|回復: 0
MSP430驅動NRF2401通信程序
ID:426770 發表于 2022-2-5 19:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
main。c
#include <msp430.h>
#include "NRF24L01.h"
#include "delay.h"
#define _EINT()   __bis_SR_register(GIE)
#define _DINT()   __bic_SR_register(GIE)
              MSP430內部看門狗初始化
void WDT_Init()
   WDTCTL = WDTPW + WDTHOLD;       //關閉看門狗
              MSP430鎖相環初始化
void CLK_Init()
  UCSCTL3 = SELREF_2;                       // Set DCO FLL reference = REFO
  UCSCTL4 |= SELA_2;                        // Set ACLK = REFO
  UCSCTL0 = 0x0000;                         // Set lowest possible DCOx, MODx
  // Loop until XT1,XT2 & DCO stabilizes - In this case only DCO has to stabilize
  do
    UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG);
                                            // Clear XT2,XT1,DCO fault flags
    SFRIFG1 &= ~OFIFG;                      // Clear fault flags
  }while (SFRIFG1&OFIFG);                   // Test oscillator fault flag
  __bis_SR_register(SCG0);                  // Disable the FLL control loop
  UCSCTL1 = DCORSEL_5;                      // Select DCO range 16MHz operation
  UCSCTL2 |= 121;                           // Set DCO Multiplier for 8MHz
                                            // (N + 1) * FLLRef = Fdco
                                            // (249 + 1) * 32768 = 8MHz
  __bic_SR_register(SCG0);                  // Enable the FLL control loop
  // Worst-case settling time for the DCO when the DCO range bits have been
  // changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx
  // UG for optimization.
  // 32 x 32 x 8 MHz / 32,768 Hz = 250000 = MCLK cycles for DCO to settle
  __delay_cycles(250000);
void main(void)
  WDT_Init();
  CLK_Init();     //MCLK = SMCLK = 4M
  NRF_Init();       //初始化NRF24L01
  while(NRF_Check())    //檢查NRF24L01是否在位.
    LED_L;        //LED
  LED_H;
RX_Mode();
_EINT();
    NRF_RxPacket(rx_buf);
    delay_ms(10);
Nrf2401.c
uchar TX_Address[5]={0x34,0x34,0x10,0x10,0x01};//設置發送端的地址
uchar RX_Address[5]={0x34,0x34,0x10,0x10,0x01};//設置接收端的地址
uchar tx_buf[TX_PLOAD_WIDTH]={0x00};
uchar rx_buf[RX_PLOAD_WIDTH]={0x00};
/****************************STM32程序***************************************/
//初始化24L01的IO口
void NRF_Init(void)
  P4SEL=0;
  P4DIR |= CSN + MOSI + SCK + CE;  //SOMI , IRQ INPUT
  P4OUT&=~(CSN + MOSI + SCK + CE);
  CSN_H;
  //P4IES |= IRQ;         //下降沿置標志位
  //P4IE |= IRQ;
  P1DIR |= BIT0;        //LED
  P1OUT |= BIT0;        //LED
void RX_Mode(void)
  CE_L;
  //設置端址
  //SPI_Write_Buf(WRITE_REG_NRF + TX_ADDR, TX_Address, TX_ADR_WIDTH);
  SPI_Write_Buf(WRITE_REG_NRF + RX_ADDR_P0, TX_Address, TX_ADR_WIDTH);
  //初始化配置字
  SPI_WR_Reg(WRITE_REG_NRF + EN_AA, 0x01); // Enable Auto.Ack:Pipe0
  SPI_WR_Reg(WRITE_REG_NRF + EN_RXADDR, 0x01); // Enable Pipe0
  SPI_WR_Reg(WRITE_REG_NRF + SETUP_AW,0x03);
  SPI_WR_Reg(WRITE_REG_NRF + SETUP_RETR,0x1a);
  SPI_WR_Reg(WRITE_REG_NRF + RF_CH, 40);
  SPI_WR_Reg(WRITE_REG_NRF + RX_PW_P0, TX_PLOAD_WIDTH);
  SPI_WR_Reg(WRITE_REG_NRF + RF_SETUP, 0x0f);
  //PWR_UP、TX_DS、IRQ、EN CRC、rX
  SPI_WR_Reg(WRITE_REG_NRF + CONFIG, 0x0f); // Set PWR_UP bit, enable CRC(2 bytes)& Prim:RX. RX_DR enabled..
  //清除標志位
  uchar sta=SPI_RD_Reg(STATUS);  //讀取狀態寄存器的值
  SPI_WR_Reg(WRITE_REG_NRF+STATUS,sta); //清除TX_DS,RX_DR或MAX_RT中斷標志
  //CE_H; // Set CE pin high to enable RX device
void TX_Mode(void)
  CE_L;
   //設置發送端的地址
  SPI_Write_Buf(WRITE_REG_NRF+TX_ADDR,TX_Address,TX_ADR_WIDTH);//寫TX節點地址
  SPI_Write_Buf(WRITE_REG_NRF+RX_ADDR_P0, RX_Address,RX_ADR_WIDTH); //設置TX節點地址,主要為了使能ACK
   //初始化配置字
  SPI_WR_Reg(WRITE_REG_NRF + EN_AA, 0x01); // Enable Auto.Ack:Pipe0//
  SPI_WR_Reg(WRITE_REG_NRF + SETUP_RETR, 0x1a); // 500us + 86us, 10 retrans...
  SPI_WR_Reg(WRITE_REG_NRF + RF_CH, 40); // Select RF channel 2.45G
  SPI_WR_Reg(WRITE_REG_NRF + RF_SETUP, 0x0f); // TX_PWR:0dBm, Datarate:2Mbps,LNA:HCURR
  SPI_WR_Reg(WRITE_REG_NRF + CONFIG, 0x0e); // Set PWR_UP bit, enable CRC(2 bytes)& Prim:TX. MAX_RT & TX_DS enabled..//
  //清除TX_DS標志位
  SPI_WR_Reg(WRITE_REG_NRF+STATUS,sta); //清除TX_DS或MAX_RT中斷標志
  //CE_H;
//檢測24L01是否存在
//返回值:0,成功;1,失敗
uchar NRF_Check(void)
    uchar buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
    uchar i;
    SPI_Write_Buf(WRITE_REG_NRF+TX_ADDR,buf,5);//寫入5個字節的地址.
    SPI_Read_Buf(TX_ADDR,buf,5); //讀出寫入的地址
    for(i=0;i<5;i++)if(buf[i]!=0XA5)break;
    if(i!=5)return 1;//檢測24L01錯誤
    return 0;                 //檢測到24L01
uchar NRF_TxPacket(uchar *txbuf)
    uchar sta;
    CE_L;
    SPI_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//寫數據到TX BUF  32個字節
    CE_H;//啟動發送
    delay_us(10);
    while((P2IN&IRQ)!=0);//等待發送完成
    if(sta&MAX_TX!=0)//達到最大重發次數
      SPI_WR_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器
      return MAX_TX;
    if(sta&TX_OK)//發送完成
      LED_J;
      return TX_OK;
    return 0xff;//其他原因發送失敗
uchar NRF_RxPacket(uchar *rxbuf)
  uchar sta;
  CE_H;       //CE 高電平>=130us,接收模式
  delay_us(130);
  if(sta&RX_OK)
    CE_L;
    LED_J;
    SPI_Read_Buf(RD_RX_PLOAD,rx_buf,RX_PLOAD_WIDTH);//讀取數據
    SPI_WR_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器
    return 0;
  else return 1;
/***************************spi程序**************************/
uchar SPI_RW(uchar data)
  uchar bit;
  for(bit=0;bit<8;bit++)
  {                           //先高位,后低位
    if(data & BIT7) MOSI_H;
    else MOSI_L;
    delay_us(2);  //數據建立時間 1us
    SCK_H;
    delay_us(2);
    data <<= 1;     //一條指令的時間
    if(SPI_IN) data |= BIT0; // capture current MISO bit
    else data &=~BIT0;
    SCK_L;
    delay_us(1);
  delay_us(1);
  return(data); // return read data
uchar SPI_WR_Reg(uchar reg, uchar value)
  uchar status;
  CSN_L; // CSN low, init SPI transaction
  status = SPI_RW(reg); // select register
  SPI_RW(value); // ..and write value to it..
  CSN_H; // CSN high again
  return(status); // return nRF24L01 status byte
uchar SPI_RD_Reg(uchar reg)
  uchar reg_val;
  CSN_L; // CSN low, initialize SPI communication
  SPI_RW(reg); // Select register to read from..
  reg_val = SPI_RW(0); // ..then read registervalue
  CSN_H; // CSN high, terminate SPI communication
  return(reg_val); // return register value
/*接收緩沖區訪問函數:主要用來在接收時讀取FIFO 緩沖區中的值。
基本思路就是通過READ_REG 命令把數據從接收FIFO(RD_RX_PLOAD)中讀出并存到數組里面去。*/
uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar bytes)
  uchar status,byte_ctr;
  CSN_L; // Set CSN low, init SPI tranaction
  status = SPI_RW(reg); // Select register to write to and read status byte
  for(byte_ctr=0;byte_ctr<bytes;byte_ctr++)
    pBuf[byte_ctr] = SPI_RW(0); // Perform SPI_RW to read byte from nRF24L01
  CSN_H; // Set CSN high again
/*發射緩沖區訪問函數:主要用來把數組里的數放到發射FIFO 緩沖區中。
基本思路就是通過WRITE_REG 命令把數據存到發射FIFO(WR_TX_PLOAD)中去。*/
uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bytes)
  delay_us(1);
  for(byte_ctr=0; byte_ctr<bytes; byte_ctr++) // then write all byte in buffer(*pBuf)
    SPI_RW(*pBuf++);
/***************************中斷程序**************************/
#pragma vector=PORT2_VECTOR
__interrupt void p2(void)
  LED_J;  //LED
  P2IFG =0;
NRF2401。h
#ifndef NRF24L01_H
#define NRF24L01_H
#include "msp430f5529.h"
#include "delay.h"
//POW_UP通過配置子寫入
#define CSN  BIT2  //每次SPI前一個下降沿,SPI后上升沿
#define MOSI BIT0
#define MISO BIT1
#define SCK  BIT2
#define CE   BIT4
#define IRQ  BIT5
#define CSN_H P2OUT |= CSN
#define CSN_L P2OUT &=~CSN
#define CE_H  P3OUT |= CE
#define CE_L  P3OUT &=~CE
#define SCK_H P3OUT |= SCK
#define SCK_L P3OUT &=~SCK
#define MOSI_H P3OUT |= MOSI
#define MOSI_L P3OUT &=~MOSI
#define SPI_IN P3IN&MISO
//SPI(NRF24L01)寄存器地址
#define CONFIG          0x00  //配置寄存器地址;bit0:1接收模式,0發射模式;bit1:電選擇;bit2:CRC模式;bit3:CRC使能;
                              //bit4:中斷MAX_RT(達到最大重發次數中斷)使能;bit5:中斷TX_DS使能;bit6:中斷RX_DR使能
#define EN_AA           0x01  //使能自動應答功能  bit0~5,對應通道0~5
#define EN_RXADDR       0x02  //接收地址允許,bit0~5,對應通道0~5
#define SETUP_AW        0x03  //設置地址寬度(所有數據通道):bit1,0:00,3字節;01,4字節;02,5字節;
#define SETUP_RETR      0x04  //建立自動重發;bit3:0,自動重發計數器;bit7:4,自動重發延時 250*x+86us
#define RF_CH           0x05  //RF通道,bit6:0,工作通道頻率;
#define RF_SETUP        0x06  //RF寄存器;bit3:傳輸速率(0:1Mbps,1:2Mbps);bit2:1,發射功率;bit0:低噪聲放大器增益
#define STATUS          0x07  //狀態寄存器;bit0:TX FIFO滿標志;bit3:1,接收數據通道號(最大:6);bit4,達到最多次重發
                              //bit5:數據發送完成中斷;bit6:接收數據中斷;
#define OBSERVE_TX      0x08  //發送檢測寄存器,bit7:4,數據包丟失計數器;bit3:0,重發計數器
#define CD              0x09  //載波檢測寄存器,bit0,載波檢測;
#define RX_ADDR_P0      0x0A  //數據通道0接收地址,最大長度5個字節,低字節在前
#define RX_ADDR_P1      0x0B  //數據通道1接收地址,最大長度5個字節,低字節在前
#define RX_ADDR_P2      0x0C  //數據通道2接收地址,最低字節可設置,高字節,必須同RX_ADDR_P1[39:8]相等;
#define RX_ADDR_P3      0x0D  //數據通道3接收地址,最低字節可設置,高字節,必須同RX_ADDR_P1[39:8]相等;
#define RX_ADDR_P4      0x0E  //數據通道4接收地址,最低字節可設置,高字節,必須同RX_ADDR_P1[39:8]相等;
#define RX_ADDR_P5      0x0F  //數據通道5接收地址,最低字節可設置,高字節,必須同RX_ADDR_P1[39:8]相等;
#define TX_ADDR         0x10  //發送地址(低字節在前),ShockBurstTM模式下,RX_ADDR_P0與此地址相等
#define RX_PW_P0        0x11  //接收數據通道0有效數據寬度(1~32字節),設置為0則非法
#define RX_PW_P1        0x12  //接收數據通道1有效數據寬度(1~32字節),設置為0則非法
#define RX_PW_P2        0x13  //接收數據通道2有效數據寬度(1~32字節),設置為0則非法
#define RX_PW_P3        0x14  //接收數據通道3有效數據寬度(1~32字節),設置為0則非法
#define RX_PW_P4        0x15  //接收數據通道4有效數據寬度(1~32字節),設置為0則非法
#define RX_PW_P5        0x16  //接收數據通道5有效數據寬度(1~32字節),設置為0則非法
#define NRF_FIFO_STATUS 0x17  //FIFO狀態寄存器;bit0,RX FIFO寄存器空標志;bit1,RX FIFO滿標志;bit2,3,保留
                              //bit4,TX FIFO空標志;bit5,TX FIFO滿標志;bit6,1,循環發送上一數據包.0,不循環;
//24L01發送接收數據寬度定義
#define TX_ADR_WIDTH    5           //5字節的地址寬度
#define RX_ADR_WIDTH    5           //5字節的地址寬度
#define TX_PLOAD_WIDTH  32          //32字節的用戶數據寬度
#define RX_PLOAD_WIDTH  32          //32字節的用戶數據寬度
//NRF24L01寄存器操作命令
#define READ_REG_NRF        0x00  //讀配置寄存器,低5位為寄存器地址
#define WRITE_REG_NRF       0x20  //寫配置寄存器,低5位為寄存器地址
#define RD_RX_PLOAD     0x61  //讀RX有效數據,1~32字節
#define WR_TX_PLOAD     0xA0  //寫TX有效數據,1~32字節
#define FLUSH_TX        0xE1  //清除TX FIFO寄存器.發射模式下用
#define FLUSH_RX        0xE2  //清除RX FIFO寄存器.接收模式下用
#define REUSE_TX_PL     0xE3  //重新使用上一包數據,CE為高,數據包被不斷發送.
#define NOP             0xFF  //空操作,可以用來讀狀態寄存器
#define MAX_TX                  0x10  //達到最大發送次數中斷
#define TX_OK                   0x20  //TX發送完成中斷
#define RX_OK                   0x40  //接收到數據中斷
extern uchar tx_buf[TX_PLOAD_WIDTH];
extern uchar rx_buf[RX_PLOAD_WIDTH];
void TX_Mode(void);
void RX_Mode(void);
uchar SPI_RW(uchar data);
uchar SPI_WR_Reg(uchar reg, uchar value);
uchar SPI_RD_Reg(uchar reg);
uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar bytes);
uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bytes);
void NRF_Init(void);
uchar NRF_Check(void);
uchar NRF_TxPacket(uchar *txbuf);
uchar NRF_RxPacket(uchar *rxbuf);
/****************LED指示燈*********************/
#define LED_J P1OUT ^= BIT0
#define LED_H P1OUT |= BIT0
#define LED_L P1OUT &=~BIT0
#endif
