查看: 4065|回復: 2
STC8H單片機I2C驅動MPU6050三軸加速度+三軸角速度檢測模塊
ID:912806 發表于 2022-1-22 16:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
使用FwLib_STC8封裝庫
  1. // Copyright 2021 IOsetting
  2. /***
  3. * Demo: MPU6050, 3-axis gyroscope + 3-axis accelerometer + Digital Motion Processor™ (DMP™)
  4. * Board: STC8H8K64U
  5. *
  6. *              P32   -> SCL
  7. *              P33   -> SDA
  8. *              GND   -> GND
  9. *              3.3V  -> VCC
  10. */
  11. #include "fw_hal.h"
  12. #include "mpu6050.h"
  13. #include <stdio.h>
  14. void I2C_Init(void)
  15. {
  16.     // Master mode
  17.     I2C_SetWorkMode(I2C_WorkMode_Master);
  18.     /**
  19.      * I2C clock = SYSCLK / 2 / (__prescaler__ * 2 + 4)
  20.      * MPU6050 works with i2c clock up to 400KHz
  21.      *
  22.      * 44.2368 / 2 / (26 * 2 + 4) = 0.39 MHz
  23.     */
  24.     I2C_SetClockPrescaler(0x1A);
  25.     // Switch alternative port
  26.     I2C_SetPort(I2C_AlterPort_P32_P33);
  27.     // Start I2C
  28.     I2C_SetEnabled(HAL_State_ON);
  29. }
  30. void GPIO_Init(void)
  31. {
  32.     // SDA
  33.     GPIO_P3_SetMode(GPIO_Pin_3, GPIO_Mode_InOut_QBD);
  34.     // SCL
  35.     GPIO_P3_SetMode(GPIO_Pin_2, GPIO_Mode_Output_PP);
  36. }
  37. int main(void)
  38. {
  39.     uint8_t i;
  40.     uint16_t buf[7];
  41.     SYS_SetClock();
  42.     GPIO_Init();
  43.     UART1_Config8bitUart(UART1_BaudSource_Timer1, HAL_State_ON, 115200);
  44.     I2C_Init();
  45.     MPU6050_Init();
  46.     while(1)
  47.     {
  48.         for (i = 0; i < 100; i++)
  49.         {
  50.             if (i == 0)
  51.             {
  52.                 MPU6050_EnableLowPowerMode(MPU6050_Wakeup_Freq_1p25Hz);
  53.             }
  54.             else if (i == 50)
  55.             {
  56.                 MPU6050_DisableLowPowerMode();
  57.             }
  58.             MPU6050_ReadAll(buf);
  59.             printf("ax:%6d, ay:%6d, az:%6d, tp:%6d, gx:%6d, gy:%6d, gz:%6d\r\n",
  60.                 buf[0], buf[1], buf[2], (int16_t)buf[3] / 34 + 365, buf[4], buf[5], buf[6]);
  61.             SYS_Delay(100);
  62.         }
  63.     }
  64. }
代碼說明
https://www.cnblogs.com/milton/p/15832869.html
完整代碼
Github  https://github.com/IOsetting/FwLib_STC8/tree/master/demo/i2c/mpu6050
Gitee https://gitee.com/iosetting/fw-lib_-stc8/tree/master/demo/i2c/mpu6050
收藏收藏7 分享淘帖 頂2 踩
ID:81918 發表于 2024-1-6 13:07 | 只看該作者
剛好有需要,謝謝
ID:774081 發表于 2024-1-8 14:01 | 只看該作者
摘菜、洗菜、準備調料、整理灶臺,選擇合適火源、水源,等一切就緒了,炒土豆絲就那么翻炒幾下出鍋了。有沒有一家這樣的店,我想自己炒土豆絲,其他我都不需要準備,出點錢店家就給我準備好了一切環境,我最多就是在幾個選項里選擇一下炒土豆絲的特殊選項,就能很快炒好土豆絲?
現在的編程環境可謂惡劣、原始!程序員的大部分精力花在不屬于項目本身的事情上。看了樓主的庫開發資料,我寫下了這段文字。
