功能描述:
1、采用51單片機作為主控單元芯片;
2、采用PT100熱電偶檢測溫度;
3、采用AD623作為信號放大電路;
4、采用MAX1240對信號進行模數轉換;
5、采用LCD1602作為顯示模塊;
6、可通過按鍵修改ADC運算周期;
二、 操作說明
KEY1:進入ADC運算周期設置模式;
KEY2: 退出ADC運算周期設置模式;
KEY3:ADC運算周期時間加;
KEY4:ADC運算周期時間減;
點擊器件上的按鈕,可以調節參數;
- #include <reg52.h>
- #include <string.h>
- #include <math.h>
- #include "intrins.h"
- #define ROW1 0x80
- #define ROW2 0xC0
- #define Ts_CONST 1 //AD采樣時間系數,采樣時間為0.1xTs_CONST(s)
- #define NOACT 0
- #define FC 1
- #define Start_AD 2
- #define Cal_Temperature 3
- #define Kpt 0.02732644 //AD芯片max1240的采樣值到溫度值的轉化系數
- void LCD_Init(void);
- void ClearDisp(unsigned char Row);
- void Display(unsigned char Addr, unsigned char *pstr);
- void DecToASC(unsigned int Dec,unsigned char *p, unsigned char n);
- void Disp_Initize(void);
- void Write_CMD(unsigned char CMD);
- unsigned int AD_MAX1240(void);
- sbit RS=P2^2;
- sbit RW=P2^1;
- sbit E=P2^0;
- sbit SDA=P1^5;
- sbit SCL=P1^6;
- sbit CS=P1^7;
- sbit Key=P3^5;
- sbit up=P3^6;
- sbit down=P3^7;
- unsigned char DispBuf[16];
- unsigned char RunState=NOACT;
- unsigned int AD_Reslut,tsflag,ts=1;
- float fz,tmp,tmp1,Pt;
- void delay(unsigned int j)//延時jms
- unsigned int m,n;
- for(n=0;n<j;n++)
- for(m=0;m<120;m++);
- void main(void)
- { LCD_Init();
- ClearDisp(ROW1);
- Disp_Initize();
- CS=1;
- SDA=1;
- SCL=0;
- TMOD=0x11;
- TF0=0; //開始程序前先延時65ms,等待max1240上電,以保證AD采樣準確
- TH0=0;
- TL0=0;
- TR0=1;
- while(!TF0);
- TF0=0;
- TR0=0;
- TH0=0x3C; //12M晶振時延時50ms
- TL0=0xB0;
- ET0=1;
- TR0=1;
- EX1=1;
- IT1=1;
- EA=1;
- while(1)
- switch(RunState)
- { case NOACT:
- break;
- case FC: //F0計算及顯示
- fz=pow(10,(tmp-121.0000)/10);
- DecToASC(fz,DispBuf,1);
- DispBuf[1]='.';
- DecToASC((fz-(unsigned int)fz)*1000,DispBuf+2,3);
- DispBuf[5]='\0';
- Display(0x80+11,DispBuf);
- RunState=NOACT;
- break;
- case Start_AD: //開始AD采樣
- AD_Reslut=AD_MAX1240();
- RunState=Cal_Temperature;
- break;
- case Cal_Temperature: //將AD值轉化為溫度并進行線性化
- Pt=AD_Reslut*Kpt;
- Pt+=100; //溫度值
- tmp=Pt/100;
- tmp=1-tmp;
- tmp=2.31e-6L*tmp;
- tmp+=1.527480889e-5L;
- tmp=sqrt(tmp);
- tmp+=-3.9083e-3L;
- tmp/=-1.155e-6L;//AD采樣值線性化修正
- tmp1=tmp;
- tmp=(tmp+tmp1)/2;//取平均溫度
- tmp=((float)((unsigned int)(tmp*10)))/10 ;
- DecToASC(tmp,DispBuf,3);
- DispBuf[3]='.';
- DecToASC((tmp-(unsigned int)tmp)*10,DispBuf+4,1);
- DispBuf[5]='\0';
- Display(0xC0+2,DispBuf); //顯示函數
- RunState=NOACT;
- break;
- unsigned int AD_MAX1240(void) //讀取AD,AD芯片為串口數據形式
- { unsigned int adtmp=0;
- unsigned char i;
- CS=0;
- while(!SDA);
- SCL=1;
- adtmp<<=1;
- SCL=0;
- for(i=0;i<12;i++)
- { SCL=1;
- adtmp<<=1;
- if(SDA==1)adtmp++;
- SCL=0;
- CS=1;
- return adtmp;
- void Disp_Initize(void) //LCD初始化,將Ts,F0,t等提示字符顯示在屏幕上
- { //unsigned char *p;
- DispBuf[0]='T';
- DispBuf[1]='s';
- DispBuf[2]='=';
- DecToASC(ts,DispBuf+3,2);
- DispBuf[5]='s';
- DispBuf[8]='f' ;
- DispBuf[9]='0' ;
- DispBuf[10]='=' ;
- DispBuf[16]='\0';
- Display(0x80,DispBuf);
- DispBuf[0]='t';
- DispBuf[1]='=';
- DispBuf[2]='\0';
- Display(0xc0,DispBuf);
- void INT1_ISR(void) interrupt 2 //切換采樣時間的中斷函數,用于開關量識別和改變Ts(采樣時間)
- EA=0;
- TR0=0;
- ET0=0;
- strcpy(DispBuf," ");
- while(1)
- if(up==0)
- delay(100);
- if(up==0)
- ts++;
- if(down==0)
- { delay(100);
- if(down==0)
- ts--;
- if(ts>60)
- ts=1;
- if(ts<=0)
- ts=60;
- DecToASC(ts,DispBuf,2);
- DispBuf[2]='s';
- DispBuf[3]='\0';
- Display(0x80+3,DispBuf);
- if(Key==0)
- break;
- EA=1;
- TR0=1;
- ET0=1;
- void T0_ISR(void) interrupt 1 //定時中斷程序
- { static unsigned char T0_CNT=Ts_CONST;
- //static bit Flag=0;
- TH0=0x3C;
- TL0=0xB0;
- //Flag=!Flag;
- //if(Flag)return;
- T0_CNT--;
- tsflag++;
- if(!T0_CNT)
- { T0_CNT=Ts_CONST;
- RunState=Start_AD; //AD采樣
- if(tsflag>=ts*20)
- tsflag=0;
- RunState =FC; //Ts到時進行F0值運算
- void DecToASC(unsigned int Dec,unsigned char *p, unsigned char n) //將Dec變量編程可以在1602上直接顯示的ASICII值
- { unsigned char i;
- p+=n;
- p--;
- for(i=0;i<n;i++)
- { *p=Dec%10+0x30;
- p--;
- Dec/=10;
- /*LCD顯示*******************************************************************************/
- void Check_Busy(void)
- {// return;
- do
- { P0=0xFF;
- E=0;
- RS=0;
- RW=1;
- E=1;
- _nop_();
- }while(P0&0x80);
- E=0;
- Check_Busy();
- E=0;
- RS=0;
- RW=0;
- P0=CMD;
- E=1;
- _nop_();
復制代碼 所有資料51hei附件下載(含仿真代碼等):
熱電偶測溫-仿真設計(51+PT100+MAX1240+1602+KEY4).7z
(9.27 MB, 下載次數: 174)
2022-2-23 03:39 上傳
