查看: 1996|回復: 0
單片機LED點陣流動程序
ID:979573 發表于 2022-1-16 18:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <STC89C5xRC.H>
#include "intrins.h"
sbit RCK=P3^5;                //RCLK
sbit SCK=P3^6;                //SRCLK
sbit SER=P3^4;    //SER
sbit k1=P3^1;
typedef unsigned int u16;
typedef unsigned char u8;
unsigned char code Animation[]={
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
        0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0xFF,
        0xA8,0xA8,0xA8,0xFF,0x00,0x00,0x1E,0x32,
  0x4A,0x8E,0x00,0x00,0x7E,0x52,0x52,0x7E,
unsigned char code day[]={
        0x22,0x46,0x8A,0x92,0x62,0x00,0x00,0xFE,
        0x82,0x82,0x82,0xFE,0x00,0x00,0x22,0x46,
  0x8A,0x92,0x62,0x00,0x00,0x22,0x46,0x8A,
        0x92,0x62,0x00,0x00,0x00,0x00,0x00,0x00
void delay(unsigned int xms)
        unsigned char i;
        while(xms--)
        _nop_();
        _nop_();
        _nop_();
        _nop_();
void _74H595(u8 bate)
        u8 i;
        RCK=0;
        SCK=0;
        for(i=0;i<8;i++)
                SER=bate>>7;
                bate=bate<<1;
                SCK=1;
                SCK=0;
        RCK=1;
        RCK=0;
void worite(u8 Colum,Data)
        _74H595(Data);
        P0=~(0x80>>Colum);
        delay(1);
        P0=0xFF;
        u8 i,offset=0,count=0;
        u8 k=0;
                if(k1==0)
                        delay(20);
                        while(!k1);
                        k=!k;
         if(k==0)
                for(i=0;i<20;i++)
                    worite(i,Animation[i+offset]);
                        if(k1==0)break;
                count++;
                if(count>10)
                        count=0;
                        offset++;
                        if(offset>30)
                                offset=0;
        else if(k==1)
                for(i=0;i<20;i++)
                    worite(i,day[i+offset]);
                        if(k1==0)break;
                count++;
                if(count>10)
                        count=0;
                        offset++;
                        if(offset>30)
                                offset=0;
