本程序芯片為STM32F103C8T6,使用HAL庫,通過官方的庫GITHUP移植而來,源代碼可以到GITHUP中搜索SCD40。
此模塊因為有速度要求,每5秒刷新一次數(shù)據(jù),所以都懂的。
單片機(jī)源程序如下:
- #include "scd4x_i2c.h"
- #include "sensirion_common.h"
- #include "sensirion_i2c.h"
- #include "sensirion_i2c_hal.h"
- #define SCD4X_I2C_ADDRESS 98
- int16_t scd4x_start_periodic_measurement() {
- int16_t error;
- uint8_t buffer[2];
- uint16_t offset = 0;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x21B1);
- error = sensirion_i2c_write_data(SCD4X_I2C_ADDRESS, &buffer[0], offset);
- if (error) {
- return error;
- sensirion_i2c_hal_sleep_usec(1000);
- return NO_ERROR;
- int16_t scd4x_read_measurement_ticks(uint16_t* co2, uint16_t* temperature,
- uint16_t* humidity) {
- int16_t error;
- uint8_t buffer[9];
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0xEC05);
- if (error) {
- return error;
- // sensirion_i2c_hal_sleep_usec(1000);
- error = sensirion_i2c_read_data_inplace(SCD4X_I2C_ADDRESS, &buffer[0], 6);
- if (error) {
- return error;
- *co2 = sensirion_common_bytes_to_uint16_t(&buffer[0]);
- *temperature = sensirion_common_bytes_to_uint16_t(&buffer[2]);
- *humidity = sensirion_common_bytes_to_uint16_t(&buffer[4]);
- return NO_ERROR;
- //需要5秒才能再次調(diào)用,傳感器的響應(yīng)時間為5秒
- int16_t scd4x_read_measurement(uint16_t* co2, int32_t* temperature_m_deg_c,
- int32_t* humidity_m_percent_rh) {
- int16_t error;
- uint16_t temperature;
- uint16_t humidity;
- error = scd4x_read_measurement_ticks(co2, &temperature, &humidity);
- if (error) {
- return error;
- #if 1
- *temperature_m_deg_c = ((21875 * (int32_t)temperature) >> 13) - 45000;
- *humidity_m_percent_rh = ((12500 * (int32_t)humidity) >> 13);
- #else
- *temperature_m_deg_c = ((175000 * (int32_t)temperature) >> 15) - 45000;
- *humidity_m_percent_rh = ((100000 * (int32_t)humidity) >> 15);
- #endif
- return NO_ERROR;
- //int16_t scd4x_stop_periodic_measurement() {
- // int16_t error;
- // uint8_t buffer[2];
- // uint16_t offset = 0;
- // offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x3F86);
- // error = sensirion_i2c_write_data(SCD4X_I2C_ADDRESS, &buffer[0], offset);
- // if (error) {
- // return error;
- // sensirion_i2c_hal_sleep_usec(500000);
- // return NO_ERROR;
- int16_t scd4x_get_temperature_offset_ticks(uint16_t* t_offset) {
- int16_t error;
- uint8_t buffer[3];
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x2318);
- if (error) {
- return error;
- error = sensirion_i2c_read_data_inplace(SCD4X_I2C_ADDRESS, &buffer[0], 2);
- if (error) {
- return error;
- *t_offset = sensirion_common_bytes_to_uint16_t(&buffer[0]);
- return NO_ERROR;
- int16_t scd4x_get_temperature_offset(int32_t* t_offset_m_deg_c) {
- int16_t error;
- uint16_t t_offset;
- error = scd4x_get_temperature_offset_ticks(&t_offset);
- if (error) {
- return error;
- *t_offset_m_deg_c = ((21875 * (int32_t)t_offset) >> 13);
- return NO_ERROR;
- int16_t scd4x_set_temperature_offset_ticks(uint16_t t_offset) {
- int16_t error;
- uint8_t buffer[5];
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x241D);
- offset = sensirion_i2c_add_uint16_t_to_buffer(&buffer[0], offset, t_offset);
- if (error) {
- return error;
- return NO_ERROR;
- int16_t scd4x_set_temperature_offset(int32_t t_offset_m_deg_c) {
- uint16_t t_offset = (uint16_t)((t_offset_m_deg_c * 12271) >> 15);
- return scd4x_set_temperature_offset_ticks(t_offset);
- int16_t scd4x_get_sensor_altitude(uint16_t* sensor_altitude) {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x2322);
- if (error) {
- return error;
- if (error) {
- return error;
- *sensor_altitude = sensirion_common_bytes_to_uint16_t(&buffer[0]);
- return NO_ERROR;
- int16_t scd4x_set_sensor_altitude(uint16_t sensor_altitude) {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x2427);
- sensor_altitude);
- if (error) {
- return error;
- return NO_ERROR;
- int16_t scd4x_set_ambient_pressure(uint16_t ambient_pressure) {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0xE000);
- ambient_pressure);
- if (error) {
- return error;
- return NO_ERROR;
- int16_t scd4x_perform_forced_recalibration(uint16_t target_co2_concentration,
- uint16_t* frc_correction) {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x362F);
- target_co2_concentration);
- if (error) {
- return error;
- sensirion_i2c_hal_sleep_usec(400000);
- if (error) {
- return error;
- *frc_correction = sensirion_common_bytes_to_uint16_t(&buffer[0]);
- return NO_ERROR;
- int16_t scd4x_get_automatic_self_calibration(uint16_t* asc_enabled) {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x2313);
- if (error) {
- return error;
- if (error) {
- return error;
- *asc_enabled = sensirion_common_bytes_to_uint16_t(&buffer[0]);
- return NO_ERROR;
- int16_t scd4x_set_automatic_self_calibration(uint16_t asc_enabled) {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x2416);
- offset =
- sensirion_i2c_add_uint16_t_to_buffer(&buffer[0], offset, asc_enabled);
- if (error) {
- return error;
- return NO_ERROR;
- int16_t scd4x_start_low_power_periodic_measurement() {
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x21AC);
- return sensirion_i2c_write_data(SCD4X_I2C_ADDRESS, &buffer[0], offset);
- int16_t scd4x_get_data_ready_status(uint16_t* data_ready) {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0xE4B8);
- if (error) {
- return error;
- if (error) {
- return error;
- *data_ready = sensirion_common_bytes_to_uint16_t(&buffer[0]);
- return NO_ERROR;
- int16_t scd4x_persist_settings() {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x3615);
- if (error) {
- return error;
- sensirion_i2c_hal_sleep_usec(800000);
- return NO_ERROR;
- int16_t scd4x_get_serial_number(uint16_t* serial_0, uint16_t* serial_1,
- uint16_t* serial_2) {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x3682);
- if (error) {
- return error;
- if (error) {
- return error;
- *serial_0 = sensirion_common_bytes_to_uint16_t(&buffer[0]);
- *serial_1 = sensirion_common_bytes_to_uint16_t(&buffer[2]);
- *serial_2 = sensirion_common_bytes_to_uint16_t(&buffer[4]);
- return NO_ERROR;
- int16_t scd4x_perform_self_test(uint16_t* sensor_status) {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x3639);
- if (error) {
- return error;
- sensirion_i2c_hal_sleep_usec(10000000);
- if (error) {
- return error;
- *sensor_status = sensirion_common_bytes_to_uint16_t(&buffer[0]);
- return NO_ERROR;
- int16_t scd4x_perform_factory_reset() {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x3632);
- if (error) {
- return error;
- return NO_ERROR;
- int16_t scd4x_reinit() {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x3646);
- if (error) {
- return error;
- sensirion_i2c_hal_sleep_usec(20000);
- return NO_ERROR;
- int16_t scd4x_measure_single_shot() {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x219D);
- if (error) {
- return error;
- sensirion_i2c_hal_sleep_usec(5000000);
- return NO_ERROR;
- int16_t scd4x_measure_single_shot_rht_only() {
- int16_t error;
- offset = sensirion_i2c_add_command_to_buffer(&buffer[0], offset, 0x2196);
- if (error) {
- return error;
- sensirion_i2c_hal_sleep_usec(50000);
- return NO_ERROR;
以上11個文件下載,請自行加入到您的工程中:
SCD4xco2.zip
(24.32 KB, 下載次數(shù): 131)
2022-1-11 16:51 上傳
