只需一步,快速開(kāi)始
查看: 1699|回復(fù): 0
單片機(jī)16*16點(diǎn)陣循環(huán)顯示
ID:998091 發(fā)表于 2022-1-2 15:39 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
uchar code dischar[]={
0xF,0xDF,0xF9,0xCF,0xFB,0xBF,0xC0,0x07,
0xDE,0xF7,0xC0,0x07,0xDE,0xF7,0xDE,0xF7,
0xC0,0x07,0xDE,0xF7,0xFE,0xFF,0x00,0x01,
0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,
0xFF,0xBF,0xEF,0xBF,0xEF,0xBF,0xEF,0xBB,
0xE0,0x01,0xEF,0xFF,0xEF,0xFF,0xEF,0xFF,
0xE0,0x0F,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,
0xDF,0xEF,0xDF,0xEF,0xBF,0xEF,0x7F,0xEF,
0xEF,0xFF,0xEF,0x07,0xEF,0x77,0x01,0x77,
0xEF,0x77,0xEF,0x77,0xC7,0x77,0xCB,0x77
,0xAB,0x77,0xAF,0x77,0x6E,0xF7,0xEE,0xF5,
0xED,0xF5,0xED,0xF5,0xEB,0xF9,0xEF,0xFF,
/***********端口定義*****************/
sbit A1 =P2^0;
sbit B1 =P2^1;
sbit C1 =P2^2;
sbit D1 =P2^3;
sbit EN1=P2^4;
sbit LS595_SHC=P1^0;    //SHcp   鎖存時(shí)鐘-----74HC595
sbit LS595_STC=P1^1;    //STcp   移位時(shí)鐘-----74HC595
sbit LS595_DS =P1^2;    //DSI    數(shù)據(jù)---------74HC595
/**********nms延時(shí)子程序*************/
void Delay_Nms(uint n)
        uint i,j;
        for(i=0;i<n;i++)
                for(j=0;j<20;j++)
/**********發(fā)送一字節(jié)數(shù)據(jù)*************/
void SendOneByte(uchar content)
   uchar i;
    for(i=0;i<8;i++)
        LS595_DS=(bit)(content & 0x80);      //判斷輸出數(shù)據(jù)
        LS595_SHC=0;                                     //初始化移位時(shí)鐘
        content<<=1;                                                  //更新數(shù)據(jù)
        LS595_SHC=1;
/***********主函數(shù)********************/
void main(void)
    uchar i;
        uchar j;
        uchar k;
        uchar        ycode;
        EN1=1;                 //不使能154譯碼器
    {   for(j=0;j<3;j++)
                        for(k=0;k<50;k++)
                                for(i=0;i<16;i++)
                                        LS595_STC=0;
                            SendOneByte(dischar[i*2+j*32]); //譯碼顯示
                                        SendOneByte(dischar[i*2+j*32+1]);   //譯碼顯示
                                        LS595_STC=1;              //數(shù)據(jù)已準(zhǔn)備好
                                        P2=i|0XF0;                       //開(kāi)啟掃描的行數(shù)據(jù)
                                        EN1=0;          //打開(kāi)行輸出
                            Delay_Nms(4);
                                        EN1=1;              //關(guān)閉行輸出
