查看: 1524|回復: 0
單片機液晶24秒倒計時可暫停繼續重置
ID:998091 發表于 2021-12-29 09:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#include <intrins.h>
sbit RS=P0^7;
sbit RW=P0^6;
sbit E=P0^5;
sbit S2=P3^3;
unsigned char count=0;
unsigned char s=24;
unsigned char m=0;
unsigned char h=0;
void lcd_w_cmd(unsigned char com);
void lcd_w_dat(unsigned char dat);
unsigned char lcd_r_start();
void lcd_int();
void delay(unsigned int i);
void delay1();
void int_1() interrupt 2{
        if(S2==0){
                delay(1200);
                if(S2==0){
                        s=24;
                        count=0;
                        TH1=(65536-50000)/256;
                        TL1=(65536-50000)%256;
                        TR1=1;
        bit b=0;
        void int_0() interrupt 0
        {if(b==0)
        {TR1=0;b=1;P1=0xfe;}
                else{b=0;TR1=1;P1=0xff;}
                void timer_1() interrupt 3{
                        count++;
                        if(count==20){
                                count=0;
                                s--;
                                if(s==0){
                                        s=24;
void delay1(){
  _nop_();
  _nop_();
  _nop_();
void lcd_int(){
  lcd_w_cmd(0x3c);
  lcd_w_cmd(0x0c);
  lcd_w_cmd(0x01);
  lcd_w_cmd(0x06);
  lcd_w_cmd(0x80);
unsigned char lcd_r_start(){
  unsigned char s;
  RW=1;
  delay1();
  RS=0;
  delay1();
  E=1;
  delay1();
  s=P2;
  delay1();
  E=0;
  delay1();
  RW=0;
  delay1();
  return(s);
void lcd_w_cmd(unsigned char com){
  unsigned char i;
  do{
    i=lcd_r_start();
    i=i&0x80;
    delay(2);
     }while(i!=0);
  RW=0;
  delay1();
  RS=0;
  delay1();
  E=1;
  delay1();
  P2=com;
  delay1();
  E=0;
  delay1();
  RW=1;
  delay(255);
void lcd_w_dat(unsigned char dat){
  unsigned char i;
  do{
    i=lcd_r_start();
    i=i&0x80;
    delay(2);
      }while(i!=0);
  RW=0;
  delay1();
  RS=1;
  delay1();
  E=1;
  delay1();
  P2=dat;
  delay1();
  E=0;
  delay1();
  RW=1;
  delay(255);
void main(){
        unsigned char lcd[]="0123456789";
  unsigned char i;
        TMOD=0x10;
        ET1=1;
        EX0=1;
        IT0=1;
        EX1=1;
        IT1=1;
        EA=1;
        TR1=1;
        P2=0xff;
        lcd_int();
        delay(255);
        lcd_w_cmd(0x84);
        delay(255);
        while(1){
                for(i=0;i<9;i++){
                        switch(i){
                                case 0:lcd_w_dat(lcd[h/10]);break;
                                case 1:lcd_w_dat(lcd[h%10]);break;
                                case 2:lcd_w_dat(':');break;
                                case 3:lcd_w_dat(lcd[m/10]);break;
                                case 4:lcd_w_dat(lcd[m%10]);break;
                                case 5:lcd_w_dat(':');break;
                                case 6:lcd_w_dat(lcd[s/10]);break;
                                case 7:lcd_w_dat(lcd[s%10]);break;
                                case 8:lcd_w_cmd(0x84);break;
void delay(unsigned int i){
  unsigned int k;
        for(k=0;k<i;k++);
