查看: 2606|回復: 0
學習筆記—STM32F103獲取DHT11溫濕度,串口輸出 程序
ID:600558 發表于 2021-12-28 12:49 | 顯示全部樓層 |閱讀模式
(一)查閱DHT11數據數據手冊
(二) 為了使用printf打印函數 需要進行修改。
usart.h增加:int fputc(int ch, FILE *f);
usart.c增加:
USART_SendData(USART1, (uint8_t) ch);
while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
return ch;
(三)DHT11函數代碼
dht11.h文件:
#ifndef __DHT11_H__
#define __DHT11_H__
#include "stm32f10x_gpio.h"
#define DHT11_GPIO_TYPE  GPIOB
#define DHT11_GPIO_PIN   GPIO_Pin_8
#define DHT11_RCC        RCC_APB2Periph_GPIOB
#define DHT11_OUT_H GPIO_SetBits(DHT11_GPIO_TYPE, DHT11_GPIO_PIN)
#define DHT11_OUT_L GPIO_ResetBits(DHT11_GPIO_TYPE, DHT11_GPIO_PIN)
#define DHT11_IN    GPIO_ReadInputDataBit(DHT11_GPIO_TYPE, DHT11_GPIO_PIN)
void dht11_gpio_input(void);
void dht11_gpio_output(void);
u16 dht11_scan(void);
u16 dht11_read_bit(void);
u16 dht11_read_byte(void);
u16 dht11_read_data(u8 buffer[4]);
#endif
dht11.c文件
#include "dht11.h"
#include "delay.h"
u8 checksum;
{    GPIO_InitTypeDef g;
    RCC_APB2PeriphClockCmd(DHT11_RCC, ENABLE);
    g.GPIO_Pin = DHT11_GPIO_PIN;
    g.GPIO_Speed = GPIO_Speed_50MHz;
    g.GPIO_Mode = GPIO_Mode_IN_FLOATING; //
    GPIO_Init(DHT11_GPIO_TYPE, &g);
    g.GPIO_Mode = GPIO_Mode_Out_PP; //
void dht11_reset(void)
    dht11_gpio_output();
    DHT11_OUT_L;
    delay_us(19000);
    DHT11_OUT_H;
    delay_us(30);
    dht11_gpio_input();
    return DHT11_IN;
    while (DHT11_IN == RESET);
    delay_us(40);
    if (DHT11_IN == SET)
        while (DHT11_IN == SET);
        return 1;
        return 0;
    u16 i;
    u16 data = 0;
    for (i = 0; i < 8; i++)
        data <<= 1;
        data |= dht11_read_bit();
    return data;
u16 dht11_read_data(u8 buffer[5])
    u16 i = 0;
    dht11_reset();
    if (dht11_scan() == RESET)
        //檢測到DHT11響應
        while (dht11_scan() == RESET);
        while (dht11_scan() == SET);
        for (i = 0; i < 5; i++)
            buffer[ i] = dht11_read_byte();[ i]
        DHT11_OUT_H;
        checksum = buffer[0] + buffer[1] + buffer[2] + buffer[3];
        if (checksum != buffer[4])
            // checksum error
            return 1;
    return 0;
(三)主函數main.c代碼
[ i]
#include "stm32f10x.h"
#include "delay.h"
#include "digital.h"
#include "usart.h"
#include "dht11.h"
int main (void){
  SMG_Init();//
USART1_Config();
while(1){
u8 buffer[5];
  double hum;
double temp;
UART1SendByte(1);
  if (dht11_read_data(buffer) == 0)
            hum = buffer[0] + buffer[1] / 10.0;
            temp = buffer[2] + buffer[3] / 10.0;
  Display_N(buffer[3]);//
        printf("___{\"temperature\": %.2f, \"humidness\": %.2f}___\n", temp, hum);
        delay_us(200000);
參與人數 1黑幣 +30 收起 理由
admin + 30 共享資料的黑幣獎勵!
