在代碼中:
\frameworks\base\services\core\java\com\android\server\power\PowerManagerService.java
判讀getScreenOffTimeoutLocked()函數(shù)下增加
int timeout = mScreenOffTimeoutSetting;
/*add mxliao,videostrong at date 20170731----*/
if (timeout < 0) {
return mMaximumScreenOffTimeoutFromDeviceAdmin;
if (isMaximumScreenOffTimeoutFromDeviceAdminEnforcedLocked()) {
timeout = Math.min(timeout, mMaximumScreenOffTimeoutFromDeviceAdmin);
同時要修改
frameworks\base\packages\SettingsProvider\res\values\default.txt文件
<integer name="def_screen_off_timeout">-1</integer> 改成-1
2、解鎖
<bool name="def_lockscreen_disabled">true</bool> 修改成true
