查看: 2613|回復: 2
單片機數字時鐘
#include<reg51.h>
#define uChar unsigned char
#define uInt unsigned int
uChar a[10] = { 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f };
uChar b[8] = { 0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f };
uChar second = 50, minute = 59, hour = 12, year = 18, month = 07, day = 21, count;
sbit Key1 = P3 ^ 0; //計時停止
sbit Key2 = P3 ^ 1; //調位
sbit Key3 = P3 ^ 2; //加一
sbit Key4 = P3 ^ 3; //切換
sbit Buzzer = P1 ^ 1;
/*********************延遲函數********************/
void Delay(uInt t)
    while (t)
        t--;
/*********************時分秒顯示函數*******************/
void Dispaly1(uChar second, uChar minute, uChar hour)
    /*********************第一位數碼管*********************/
    P2 = b[0];
    P0 = a[hour / 10];
    Delay(10);
    /*********************第二位數碼管*********************/
    P2 = b[1];
    P0 = a[hour % 10];
    Delay(10);
    /*********************第三位數碼管*********************/
    P2 = b[2];
    P0 = 0x40;
    Delay(10);
    /*********************第四位數碼管*********************/
    P2 = b[3];
    P0 = a[minute / 10];
    Delay(10);
    /*********************第五位數碼管*********************/
    P2 = b[4];
    P0 = a[minute % 10];
    Delay(10);
    /*********************第六位數碼管*********************/
    P2 = b[5];
    P0 = 0x40;
    Delay(10);
    /*********************第七位數碼管*********************/
    P2 = b[6];
    P0 = a[second / 10];
    Delay(10);
    /*********************第八位數碼管*********************/
    P2 = b[7];;
    P0 = a[second % 10];
    Delay(10);
/*********************年月日顯示函數********************/
void Dispaly2(uChar day, uChar month, uChar year)
    P2 = b[0];
    P0 = a[day / 10];
    Delay(10);
    P2 = b[1];
    P0 = a[day % 10];
    Delay(10);
    P2 = b[2];
    P0 = 0x40;
    Delay(10);
    P2 = b[3];
    P0 = a[month / 10];
    Delay(10);
    P2 = b[4];
    P0 = a[month % 10];
    Delay(10);
    P2 = b[5];
    P0 = 0x40;
    Delay(10);
    P2 = b[6];
    P0 = a[year / 10];
    Delay(10);
    P2 = b[7];
    P0 = a[year % 10];
    Delay(10);
/*********************時鐘按鍵掃描函數*********************/
void Keyscan1()
    static uChar i = 0, j = 0;
    if (Key1 == 0)
        Delay(10); //消抖
        if (Key1 == 0)
            while (!Key1); //等待按鍵彈
        i++;
    /*時鐘暫停功能*/
    if (i % 2 == 1)
        TR0 = 0;/*如果是奇數次按鍵自然關閉定時器0*/
    if (i % 2 == 0)
        TR0 = 1;/*如果是偶數次按鍵則打開定時器0*/
    /*時鐘調位和數值加一功能*/
    if (Key2 == 0)
        Delay(10);
        if (Key2 == 0)
            while (!Key2);
        j++;
    if (j % 4 == 1)
        if (Key3 == 0)
            Delay(10);
            if (Key3 == 0)
                while (!Key3);
            second++;
            if (second == 60)
                second = 0;
    if (j % 4 == 2)
        if (Key3 == 0)
            Delay(10);
            if (Key3 == 0)
                while (!Key3);
            minute++;
            if (minute == 60)
                minute = 0;
    if (j % 4 == 3)
        if (Key3 == 0)
            Delay(10);
            if (Key3 == 0)
                while (!Key3);
            hour++;
            if (hour == 24)
                hour = 0;
/*日期按鍵掃描函數*/
void Keyscan2()
    static uChar m = 0, n = 0;
    if (Key1 == 0)
        Delay(10);
        if (Key1 == 0)
            while (!Key3);
        m++;
    if (m % 2 == 1)
        TR0 = 0;/*奇數次按鍵則關閉定時器0*/
    if (m % 2 == 0)
        TR0 = 1;/*偶數次按鍵則打開定時器0*/
    if (Key2 == 0)
        Delay(10);
        if (Key2 == 0)
            while (!Key2);
        n++;
    /*日期調位和日期加一功能*/
    if (n % 4 == 1)
        if (Key3 == 0)
            Delay(10);
            if (Key3 == 0)
                while (!Key3);
            day++;
            if (day == 30)
                day = 0;
    if (n % 4 == 2)
        if (Key3 == 0)
            Delay(10);
            if (Key3 == 0)
                while (!Key3);
            month++;
            if (month == 12)
                month = 0;
    if (n % 4 == 3)
        if (Key3 == 0)
            Delay(10);
            if (Key3 == 0)
                while (!Key3);
            year++;
            if (year == 99)
                year = 0;
/***************主函數***************************/
    TMOD = 0x01;      /*定時器以方式一工作*/
    TH0 = (65536 - 10000) / 256;
    TL0 = (65536 - 10000) % 256;/*10ms計時*/
    EA = 1;
    ET0 = 1;/*允許定時器0中斷*/
    TR0 = 1;/*打開定時器0*/
    while (1)
        static uChar h = 0;
        /*時鐘和日期切換功能*/
        if (Key4 == 0)
            Delay(10);
            if (Key4 == 0)
                while (!Key4);
            h++;
        if (h % 2 == 0)/*如果按鍵偶數次則顯示時鐘*/
            Dispaly1(second, minute, hour);
            Keyscan1();
        if (h % 2 == 1)/*如果按鍵奇數次則顯示日期*/
            Dispaly2(year, month, day);
            Keyscan2();
/**********************中斷函數**************************/
void time0_int(void) interrupt 1
    count++;
    if (count == 100)/*10ms??ê±£???100′??ò??o?1s*/
        count = 0;
        second++;
        if (second == 60)
            second = 0;
            minute++;
            if (minute == 60)
                minute = 0;
                hour++;
                if (hour == 24)
                    hour = 0;
                    day++;
                    if (day == 30)
                        day = 0;
                        month++;
                        if (month == 12)
                            month = 0;
                            year++;
                            if (year == 99)
                                year = 0;
    /*判斷整點提醒*/
    if (second == 00 && minute == 00)
        Buzzer = 0;
        Buzzer = 1;
ID:991555 發表于 2021-12-15 16:14 來自觸屏版 | 只看該作者
為什么顯示有點問題
ID:987076 發表于 2022-1-4 14:53 | 只看該作者
這個是不是有問題 弄出來顯示不了。 請樓主看一下加急
