* @file bsp_i2c_ee.c
* @author STMicroelectronics
* @version V1.0
* @date 2013-xx-xx
* @brief i2c EEPROM(AT24C02)應用函數bsp
#include "./i2c/bsp_i2c_ee.h"
#include "./usart/bsp_usart.h"
/* STM32 I2C 快速模式 */
#define I2C_Speed 400000 //*
/* 這個地址只要與STM32外接的I2C器件地址不一樣即可 */
#define I2Cx_OWN_ADDRESS7 0X0A
/* AT24C01/02每頁有8個字節 */
#define I2C_PageSize 8
/* AT24C04/08A/16A每頁有16個字節 */
//#define I2C_PageSize 16
uint16_t EEPROM_ADDRESS;
static __IO uint32_t I2CTimeout = I2CT_LONG_TIMEOUT;
static uint32_t I2C_TIMEOUT_UserCallback(uint8_t errorCode);
* @brief I2C I/O配置
* @param 無
* @retval 無
static void I2C_GPIO_Config(void)
/* 使能與 I2C 有關的時鐘 */
EEPROM_I2C_APBxClock_FUN ( EEPROM_I2C_CLK, ENABLE );
EEPROM_I2C_GPIO_APBxClock_FUN ( EEPROM_I2C_GPIO_CLK, ENABLE );
/* I2C_SCL、I2C_SDA*/
GPIO_InitStructure.GPIO_Pin = EEPROM_I2C_SCL_PIN;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD; // 開漏輸出
GPIO_Init(EEPROM_I2C_SCL_PORT, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = EEPROM_I2C_SDA_PIN;
GPIO_Init(EEPROM_I2C_SDA_PORT, &GPIO_InitStructure);
* @brief I2C 工作模式配置
* @param 無
* @retval 無
static void I2C_Mode_Configu(void)
I2C_InitTypeDef I2C_InitStructure;
/* I2C 配置 */
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
/* 高電平數據穩定,低電平數據變化 SCL 時鐘線的占空比 */
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 =I2Cx_OWN_ADDRESS7;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable ;
/* I2C的尋址模式 */
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
/* 通信速率 */
I2C_InitStructure.I2C_ClockSpeed = I2C_Speed;
/* I2C 初始化 */
I2C_Init(EEPROM_I2Cx, &I2C_InitStructure);
/* 使能 I2C */
I2C_Cmd(EEPROM_I2Cx, ENABLE);
* @brief I2C 外設(EEPROM)初始化
* @param 無
* @retval 無
void I2C_EE_Init(void)
I2C_GPIO_Config();
I2C_Mode_Configu();
/* 根據頭文件i2c_ee.h中的定義來選擇EEPROM要寫入的地址 */
#ifdef EEPROM_Block0_ADDRESS
/* 選擇 EEPROM Block0 來寫入 */
EEPROM_ADDRESS = EEPROM_Block0_ADDRESS;
#endif
#ifdef EEPROM_Block1_ADDRESS
/* 選擇 EEPROM Block1 來寫入 */
EEPROM_ADDRESS = EEPROM_Block1_ADDRESS;
#endif
#ifdef EEPROM_Block2_ADDRESS
/* 選擇 EEPROM Block2 來寫入 */
EEPROM_ADDRESS = EEPROM_Block2_ADDRESS;
#endif
#ifdef EEPROM_Block3_ADDRESS
/* 選擇 EEPROM Block3 來寫入 */
EEPROM_ADDRESS = EEPROM_Block3_ADDRESS;
#endif
* @brief 將緩沖區中的數據寫到I2C EEPROM中
* @param
* @arg pBuffer:緩沖區指針
* @arg WriteAddr:寫地址
* @arg NumByteToWrite:寫的字節數
* @retval 無
void I2C_EE_BufferWrite(u8* pBuffer, u8 WriteAddr, u16 NumByteToWrite)
u8 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0;
Addr = WriteAddr % I2C_PageSize;
count = I2C_PageSize - Addr;
NumOfPage = NumByteToWrite / I2C_PageSize;
NumOfSingle = NumByteToWrite % I2C_PageSize;
/* If WriteAddr is I2C_PageSize aligned */
if(Addr == 0)
/* If NumByteToWrite < I2C_PageSize */
if(NumOfPage == 0)
I2C_EE_PageWrite(pBuffer, WriteAddr, NumOfSingle);
I2C_EE_WaitEepromStandbyState();
/* If NumByteToWrite > I2C_PageSize */
while(NumOfPage--)
I2C_EE_PageWrite(pBuffer, WriteAddr, I2C_PageSize);
WriteAddr += I2C_PageSize;
pBuffer += I2C_PageSize;
if(NumOfSingle!=0)
/* If WriteAddr is not I2C_PageSize aligned */
if(NumOfPage== 0)
NumByteToWrite -= count;
if(count != 0)
I2C_EE_PageWrite(pBuffer, WriteAddr, count);
WriteAddr += count;
pBuffer += count;
while(NumOfPage--)
if(NumOfSingle != 0)
* @brief 寫一個字節到I2C EEPROM中
* @param
* @retval 無
uint32_t I2C_EE_ByteWrite(u8* pBuffer, u8 WriteAddr)
/* Send STRAT condition */
I2C_GenerateSTART(EEPROM_I2Cx, ENABLE);
I2CTimeout = I2CT_FLAG_TIMEOUT;
/* Test on EV5 and clear it */
while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_MODE_SELECT))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(0);
/* Send EEPROM address for write */
I2C_Send7bitAddress(EEPROM_I2Cx, EEPROM_ADDRESS, I2C_Direction_Transmitter);
/* Test on EV6 and clear it */
while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(1);
/* Send the EEPROM's internal address to write to */
I2C_SendData(EEPROM_I2Cx, WriteAddr);
/* Test on EV8 and clear it */
while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(2);
/* Send the byte to be written */
I2C_SendData(EEPROM_I2Cx, *pBuffer);
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(3);
/* Send STOP condition */
I2C_GenerateSTOP(EEPROM_I2Cx, ENABLE);
return 1;
* @brief 在EEPROM的一個寫循環中可以寫多個字節,但一次寫入的字節數
* 不能超過EEPROM頁的大小,AT24C02每頁有8個字節
* @param
* @retval 無
uint32_t I2C_EE_PageWrite(u8* pBuffer, u8 WriteAddr, u8 NumByteToWrite)
while(I2C_GetFlagStatus(EEPROM_I2Cx, I2C_FLAG_BUSY))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(4);
/* Send START condition */
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(5);
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(6);
while(! I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(7);
/* While there is data to be written */
while(NumByteToWrite--)
/* Send the current byte */
/* Point to the next byte to be written */
pBuffer++;
while (!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(8);
return 1;
* @brief 從EEPROM里面讀取一塊數據
* @param
* @arg pBuffer:存放從EEPROM讀取的數據的緩沖區指針
* @arg WriteAddr:接收數據的EEPROM的地址
* @arg NumByteToWrite:要從EEPROM讀取的字節數
* @retval 無
uint32_t I2C_EE_BufferRead(u8* pBuffer, u8 ReadAddr, u16 NumByteToRead)
//*((u8 *)0x4001080c) |=0x80;
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(9);
//*((u8 *)0x4001080c) &=~0x80;
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(10);
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(11);
/* Clear EV6 by setting again the PE bit */
I2C_SendData(EEPROM_I2Cx, ReadAddr);
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(12);
/* Send STRAT condition a second time */
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(13);
/* Send EEPROM address for read */
I2C_Send7bitAddress(EEPROM_I2Cx, EEPROM_ADDRESS, I2C_Direction_Receiver);
while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(14);
/* While there is data to be read */
while(NumByteToRead)
if(NumByteToRead == 1)
/* Disable Acknowledgement */
I2C_AcknowledgeConfig(EEPROM_I2Cx, DISABLE);
/* Send STOP Condition */
/* Test on EV7 and clear it */
while(I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_RECEIVED)==0)
/* Read a byte from the EEPROM */
*pBuffer = I2C_ReceiveData(EEPROM_I2Cx);
/* Point to the next location where the byte read will be saved */
pBuffer++;
/* Decrement the read bytes counter */
NumByteToRead--;
/* Enable Acknowledgement to be ready for another reception */
I2C_AcknowledgeConfig(EEPROM_I2Cx, ENABLE);
return 1;
* @brief Wait for EEPROM Standby state
* @param 無
* @retval 無
void I2C_EE_WaitEepromStandbyState(void)
vu16 SR1_Tmp = 0;
do
/* Read I2C1 SR1 register */
SR1_Tmp = I2C_ReadRegister(EEPROM_I2Cx, I2C_Register_SR1);
}while(!(I2C_ReadRegister(EEPROM_I2Cx, I2C_Register_SR1) & 0x0002));
/* Clear AF flag */
I2C_ClearFlag(EEPROM_I2Cx, I2C_FLAG_AF);
/* STOP condition */
* @brief Basic management of the timeout situation.
* @param errorCode:錯誤代碼,可以用來定位是哪個環節出錯.
* @retval 返回0,表示IIC讀取失敗.
/* Block communication and all processes */
EEPROM_ERROR("I2C 等待超時!errorCode = %d",errorCode);
return 0;
/*********************************************END OF FILE**********************/
