查看: 5091|回復: 8
STM32單片機智能窗簾控制系統程序Proteus仿真圖
液晶顯示High,表示光強太強
液晶顯示OK,表示光強合適
液晶顯示Low,表示光強太弱
備注:通過ARM內部的ADC采集光敏電阻電壓,判斷電壓值
電壓值低于設定的值,表示光強太弱,打開窗簾
電壓大于設定的參考電壓值,表示光強太強,關閉窗簾
光強合適,顯示OK,電機不轉,表示窗簾不動
光強太弱,表示光線不好,應該開窗
光強太強,表示光線強,關窗
光敏電阻,對光照強度不同,阻值不同
電壓是模擬量,所以使用AD采集,AD值模擬量轉數字量,這樣ARM就可以知道當前電壓值
  1. #include "stm32f10x.h"
  2. #include "bsp-lcd1602.h"
  3. #include "delay.h"
  4. #include "sys.h"
  5. #include "adc.h"
  6. void L298_GPIO( void )
  7. {
  8.         GPIO_InitTypeDef GPIO_InitStructure;
  9.
  10.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  11.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
  12.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  13.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  14.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  15. }
  16. void OPEN(void)        //left moto is runing, but right moto is brake
  17. {
  18.         GPIO_SetBits(GPIOC,GPIO_Pin_5);
  19.         GPIO_ResetBits(GPIOC,GPIO_Pin_4);
  20.         GPIO_ResetBits(GPIOC,GPIO_Pin_3);
  21.         GPIO_ResetBits(GPIOC,GPIO_Pin_2);
  22.         GPIO_SetBits(GPIOC,GPIO_Pin_1);
  23.         GPIO_SetBits(GPIOC,GPIO_Pin_0);
  24. }
  25. void CLOSE(void)        //right moto is runing, but left moto is brake
  26. {
  27.         GPIO_ResetBits(GPIOC,GPIO_Pin_5);
  28.         GPIO_ResetBits(GPIOC,GPIO_Pin_4);
  29.         GPIO_SetBits(GPIOC,GPIO_Pin_3);
  30.         GPIO_ResetBits(GPIOC,GPIO_Pin_2);
  31.         GPIO_SetBits(GPIOC,GPIO_Pin_1);
  32.         GPIO_SetBits(GPIOC,GPIO_Pin_0);
  33. }
  34. void STOP(void)        //right moto is runing, but left moto is brake
  35. {
  36.         GPIO_SetBits(GPIOC,GPIO_Pin_5);
  37.         GPIO_SetBits(GPIOC,GPIO_Pin_4);
  38.         GPIO_SetBits(GPIOC,GPIO_Pin_3);
  39.         GPIO_SetBits(GPIOC,GPIO_Pin_2);
  40.         GPIO_SetBits(GPIOC,GPIO_Pin_1);
  41.         GPIO_SetBits(GPIOC,GPIO_Pin_0);
  42. }
  43. int main(void)
  44. {
  45. int a,b,c,d;
  46.         float temp;
  47.
  48.         delay_init();                     //延時函數初始化
  49.         LCD1602_Init();
  50.     ADC1_GPIO_Config();
  51.         L298_GPIO();
  52.     ADC_Config();
  53.         LCD1602_ShowStr(0,0,"  Auto curtain ",15);
  54.         LCD1602_ShowStr(0,1,"Light:",6);
  55.
  56.         while(1)
  57.         {
  58.                 b=ADC_GetConversionValue(ADC1);
  59.                 temp=b*(3.4/4096)*10;
  60.                 //表示光線太弱
  61.                 if( temp < 8 )
  62.                 {
  63.                         LCD1602_ShowStr(7,1,"open ",4);
  64.                         OPEN();
  65.                 }
  66.                 else
  67.                 {
  68.                         if( temp < 25)                                //光線合適
  69.                         {
  70.                                 LCD1602_ShowStr(7,1,"OK  ",4);
  71.                                 STOP();
  72.                         }
  73.                         else                                                //光線太強
  74.                         {
  75.                                 LCD1602_ShowStr(7,1,"close",4);
  76.                                 CLOSE();
  77.                         }
  78.                 }
  79. //                a=temp/1;
  80. //                c=temp*10;
  81. //                d=c%10;
  82. //                LCD_ShowNum(11,0,a);
  83. //                LCD_ShowNum(13,0,d);
  84.         }
  85. }
Keil5代碼,仿真用Proteus8.8版本,附件下載:
仿真程序.7z (286.8 KB, 下載次數: 197)
收藏收藏6 分享淘帖 頂 踩
ID:110875 發表于 2021-12-5 21:57 | 只看該作者
不錯,優化部分:應該由一個電機控制正反轉
ID:899319 發表于 2021-12-7 18:36 來自觸屏版 | 只看該作者
為啥我打開之后液晶不顯示呢
ID:262 發表于 2021-12-7 20:12 | 只看該作者
shuaike 發表于 2021-12-7 18:36
為啥我打開之后液晶不顯示呢
用Proteus8.8 親測ok
ID:440028 發表于 2021-12-30 14:58 | 只看該作者
再加上個雨水感應會更好一些
ID:1016139 發表于 2022-4-6 15:51 | 只看該作者
heicad 發表于 2021-12-7 20:12
用Proteus8.8 親測ok
我用8.9運行之后只顯示高,不變化
ID:738160 發表于 2022-4-20 17:24 | 只看該作者
Proteus8.11 打開后完全沒反應,想問一下可能是啥情況
ID:262 發表于 2022-4-21 04:39 | 只看該作者
sen666 發表于 2022-4-20 17:24
8.11不行的 要8.8
ID:228452 發表于 2022-4-21 18:55 | 只看該作者
8.12 sp0 can't work too
