· 1.本設(shè)計(jì)采用STC89C51/52(與AT89S51/52、AT89C51/52通用,可任選)單片機(jī)作為主控制器
· 2.數(shù)碼管顯示測(cè)量的距離,74hc573和三極管驅(qū)動(dòng)數(shù)碼管
· 3.HC-SR04超聲波模塊測(cè)距,測(cè)量范圍0.02m~5.5m以上
· 4.本設(shè)計(jì)可用作汽車的倒車?yán)走_(dá),報(bào)警距離可以用過按鍵設(shè)定和更改
· 5.附加功能:報(bào)警頻率可以隨著距離變化,距離越小頻率越快。(使用說明:
本設(shè)計(jì)共3個(gè)按鍵,一個(gè)設(shè)置鍵,一個(gè)加,一個(gè)減鍵,只有按下設(shè)置鍵的時(shí)候才可以加減。)
單片機(jī)源程序如下:
- #include <reg52.H>//器件配置文件
- #include <intrins.h>
- #include "eeprom52.h"
- //傳感器接口
- sbit RX = P2^3;
- sbit TX = P2^2;
- //按鍵聲明
- sbit S1 = P1^4;
- sbit S2 = P1^5;
- sbit S3 = P1^6;
- sbit DIAN=P0^5; //小數(shù)點(diǎn)引腳
- //蜂鳴器
- sbit Feng= P2^0;
- //變量聲明
- unsigned int time=0;
- unsigned int timer=0;
- unsigned char posit=0;
- unsigned long S=0;
- unsigned long BJS;//報(bào)警距離
- char num=0;
- //模式 0正常模式 1調(diào)整
- char Mode=0;
- bit flag=0;
- unsigned char const discode[] ={0x5F,0x44,0x9D,0xD5,0xC6,0xD3,0xDB,0x47,0xDF,0xD7,0x80}; //數(shù)碼管顯示碼0123456789-和不顯示
- unsigned char disbuff[4] ={0,0,0,0}; //數(shù)組用于存放距離信息
- unsigned char disbuff_BJ[4] ={0,0,0,0};//報(bào)警信息
- void Display(void);
- sbit W0=P2^4;
- sbit W1=P2^5;
- sbit W2=P2^6;
- sbit W3=P2^7; //數(shù)碼管的位選引腳
- /******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eeprom中******************/
- void write_eeprom()
- SectorErase(0x2000); //先清除
- byte_write(0x2000, BJS); //寫數(shù)據(jù)
- byte_write(0x2060, a_a);
- /******************把數(shù)據(jù)從單片機(jī)內(nèi)部eeprom中讀出來*****************/
- void read_eeprom()
- BJS = byte_read(0x2000);
- a_a = byte_read(0x2060);
- /**************開機(jī)自檢eeprom初始化*****************/
- void init_eeprom()
- read_eeprom(); //先讀
- if(a_a != 1) //新的單片機(jī)初始單片機(jī)內(nèi)問eeprom
- BJS = 25;
- a_a = 1;
- write_eeprom(); //保存數(shù)據(jù)
- //延時(shí)1ms(不精確)
- void delay(unsigned int x)
- unsigned int i,j;
- for(i=0;i<x;i++)
- for(j=0;j<121;j++);
- //按鍵掃描
- void Key_()
- unsigned char DIS_I;
- if(S1==0&&Mode==1)
- for(DIS_I=0;DIS_I<100;DIS_I++)
- Display(); //延時(shí)去抖
- if(S1==0)
- Feng=0;
- for(DIS_I=0;DIS_I<200;DIS_I++)
- Feng=1;
- BJS++; //報(bào)警值加
- if(BJS>=151) //最大151
- BJS=0;
- disbuff_BJ[0]=BJS%1000/100;
- disbuff_BJ[1]=BJS%1000%100/10;
- disbuff_BJ[2]=BJS%1000%10 %10;
- while(S1==0) Display();
- else if(S2==0&&Mode==1)
- if(S2==0)
- Feng=0;
- Feng=1;
- BJS--; //報(bào)警值減
- if(BJS<=1) //最小1
- BJS=150;
- while(S2==0) Display();
- //功能
- else if(S3==0) //設(shè)置鍵
- if(S3==0)
- Feng=0;
- Feng=1;
- Mode=!Mode; //模式加
- num=0;
- Feng=1;
- while(S3==0) Display();
- if(Mode==0)
- //掃描數(shù)碼管
- //正常顯示
- if(Mode==0) //正常測(cè)距模式
- num++; //計(jì)數(shù)切換不同顯示數(shù)碼管
- if(num==1) //第一個(gè)數(shù)碼管
- W3=1; //關(guān)閉第二位
- W0=1; //關(guān)閉第二位
- P0=~discode[disbuff[0]]; //顯示整數(shù)位,因?yàn)槎未a數(shù)組為共陰數(shù)碼管碼表,所以在使用時(shí)要取反
- DIAN=0; //點(diǎn)亮小數(shù)點(diǎn)
- W1=0; //打開位
- else if(num==2) //第二位
- W1=1; //關(guān)閉第一位
- P0=~discode[disbuff[1]]; //顯示小數(shù)點(diǎn)后一位
- W2=0; //打開第二位
- else if(num>=3) //第三個(gè)位置
- W2=1; //關(guān)閉第二位
- P0=~discode[disbuff[2]]; //顯示小數(shù)點(diǎn)后二位
- W3=0; //打開第三位
- num=0; //清零
- //報(bào)警顯示
- else
- num++;
- if(num==1)
- W3=1;
- P0=~0xCE; //11001110 顯示字母H
- W0=0;
- else if(num==2)
- W0=1;
- P0=~discode[disbuff_BJ[0]]; //顯示報(bào)警值
- DIAN=0;
- W1=0;
- else if(num==3)
- W1=1;
- P0=~discode[disbuff_BJ[1]];
- W2=0;
- else if(num>=4)
- W2=1;
- P0=~discode[disbuff_BJ[2]];
- W3=0;
- num=0;
- //計(jì)算
- void Conut(void)
- time=TH0*256+TL0; //讀出T0的計(jì)時(shí)數(shù)值
- TH0=0;
- TL0=0; //清空計(jì)時(shí)器
- S=(time*1.7)/100; //算出來是CM
- //聲音的速度是340m/s,時(shí)間的單位是us,計(jì)算到秒需要將時(shí)間數(shù)據(jù)/1000000,
- //長(zhǎng)度=速度*時(shí)間,340*time/1000000,長(zhǎng)度數(shù)據(jù)單位是m轉(zhuǎn)換成cm需要乘以100得到340*time/10000,
- //小數(shù)點(diǎn)都向左移兩位得到3.4*time/100,因?yàn)槌暡ㄊ峭盗耍栽俪?,得到距離數(shù)據(jù)(time*1.7)/100
- if(Mode==0) //非設(shè)置狀態(tài)時(shí)
- if((S>=700)||flag==1) //超出測(cè)量范圍顯示“-”
- Feng=0; //蜂鳴器報(bào)警
- flag=0;
- disbuff[0]=10; //“-”
- disbuff[1]=10; //“-”
- disbuff[2]=10; //“-”
- else
- //距離小于報(bào)警距
- if(S<=BJS)
- Feng=0; //報(bào)警
- else //大于
- Feng=1; //關(guān)閉報(bào)警
- disbuff[0]=S%1000/100; //將距離數(shù)據(jù)拆成單個(gè)位賦值
- disbuff[1]=S%1000%100/10;
- disbuff[2]=S%1000%10 %10;
- else
- Feng=1;
- //定時(shí)器0
- void zd0() interrupt 1 //T0中斷用來計(jì)數(shù)器溢出,超過測(cè)距范圍
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
Keil程序下載:
程序原理圖.7z
(257.67 KB, 下載次數(shù): 52)
2021-12-5 04:46 上傳
點(diǎn)擊文件名下載附件
keil程序源文件
評(píng)分
查看全部評(píng)分
