51單片機(jī):在動(dòng)態(tài)顯示數(shù)字8051基礎(chǔ)上,按鍵按一下數(shù)碼管數(shù)字+1
要求:
數(shù)碼管一直在動(dòng)態(tài)刷新,數(shù)碼管的初值為8051,利用外部中斷實(shí)現(xiàn)按鍵按一下數(shù)碼管示數(shù)加一
代碼如下:
(寫的不好僅供參考)
//利用外部中斷實(shí)現(xiàn)開(kāi)關(guān)按一下,數(shù)碼管數(shù)字在8051的基礎(chǔ)上+1
#include<reg52.h>
unsigned char code DSY_CODE[] ={0xC0,0xF9,0xA4,
0xB0,0x99,0x92,
0x82,0xF8,0x80,0x90}; //共陽(yáng)極數(shù)碼管
typedef unsigned char uchar;
typedef unsigned int uint;
uint cnt = 8051,i = 0,a = 0x10;
void DelayMS(unsigned int x); //延時(shí)函數(shù)
uchar LED_Play[4]; //個(gè)十百千位顯示
IT0 = 1;
IE = 0X81;//使用外部中斷0
LED_Play[0] = cnt/1000; //千位
LED_Play[1] = cnt/100%10; //百位
LED_Play[2] = cnt/10%10; //十位
LED_Play[3] = cnt%10; //個(gè)位
if(i > 3)
i = 0;
a = 0x10;
P2 = 0x00;
P0 = DSY_CODE[LED_Play[i++]];
P2 = a;
DelayMS(2);
a = a<<1;//左移位
void EX0_INT(void) interrupt 0//外部中斷0,實(shí)現(xiàn)計(jì)數(shù)+1
cnt++;
void DelayMS(unsigned int x) //延時(shí)函數(shù)
unsigned int i;
while(x--)
for(i=0;i<120;i++);
仿真結(jié)果:
2021-11-23 21:26 上傳
2021-11-23 21:26 上傳
評(píng)分
查看全部評(píng)分
