查看: 3000|回復: 0
一個計數鬧鈴單片機時鐘程序與Proteus仿真
1.使用定時器T0,動態顯示數碼管數字,
   T0 到達則顯示一個數字
2.對秒信號計數方式來計時,而且不使用外部中斷。
3.對外引腳脈沖計數,也不使用外部中斷
這樣可以避免按鍵時阻塞進程,使動態顯示分時不均
  1. #include "reg52.h"  //包含stc15w401單片機的頭文件
  2. #include "defType.h"
  3. #define MOD_NORMAL 0
  4. #define MOD_COUNT 1
  5. #define MOD_SETALARM 2
  6. //the set BUTTON
  7. #define P_LED  P1
  8. #define P_WEI  P3
  9. sbit P_MINUTE_UP   =P3^0;
  10. sbit P_HOUR_UP     =P3^1;
  11. sbit P_SEC         =P3^2;
  12. sbit P_CNT         =P3^3;
  13. sbit P_MOD         =P2^0;
  14. sbit P_ALARM  =P2^1;
  15. //p3.0- p3.7 to link to LED‘s a to h,0-9
  16. u8 code segCode[17]={0xC0,0xF9,0xA4,0xB0,0x99,
  17.                0x92,0x82,0xF8,0x80,0x90,0xff,//
  18.                0xa7,0xab,0x87,//cnt, counter mode
  19.                                                          0x88,0xc7,0x88};//ala,set alarm mode
  20.
  21. #define SET_M_BUF(m) dspBuf[0]= m%10; \
  22.                   dspBuf[1]= m/10
  23. #define SET_H_BUF(h) if(h<10) \
  24.                      { dspBuf[2]= h;dspBuf[3]= 10;} \
  25.                      else \
  26.                      { dspBuf[2]= h%10;dspBuf[3]= h/10;}
  27. #define UP_MINUTE(m) m++; \
  28.           if(m>59) m= 0; \
  29.                                   SET_M_BUF(m)
  30. #define UP_HOUR(h)  h++;  \
  31.          if(h>23) h=0;         \
  32.                                  SET_H_BUF(h)
  33. #define ZERO_BUF dspBuf[0]= 0; \
  34.                  dspBuf[1]= 0; \
  35.        dspBuf[2]= 0; \
  36.        dspBuf[3]= 0
  37. //current time and alarm time
  38. u8 minute= 3, hour=2;
  39. u8 a_minute=0, a_hour=0;
  40. ///////////////////////////////
  41. u8 dspBuf[4];
  42. u8 i= 0, mode= MOD_NORMAL;
  43. u16 sec=0, count=0;
  44. u8  oldSec=0, oldCnt=0;
  45. u8  sec5=0; //when setting alarm, if no key down for 5 sec,alarm is seted
  46. bool alarmSeted = 0;
  47. void flashDot()
  48. {
  49.          if(P_SEC)
  50.                  P_LED&= 0x7f;
  51. }
  52. void modeDisplay()
  53. {
  54.         if(mode== MOD_NORMAL)
  55.         {
  56.                 SET_M_BUF(minute);
  57.                 SET_H_BUF(hour);
  58.         }
  59.         else
  60.         {
  61.          dspBuf[0]= 10; //no display
  62.          dspBuf[1]= 10+3*mode; // '-'
  63.          dspBuf[2]= 9+3*mode;
  64.          dspBuf[3]= 8+3*mode; //  '-'
  65.         }
  66. }
  67. void counting()
  68. {
  69.         if(oldCnt== P_CNT)
  70.                  return;
  71.         count++; \
  72.   if(count>9999) count= 0;
  73.         SET_M_BUF(count%100); \
  74.   SET_H_BUF(count/100);
  75.         oldCnt= P_CNT;
  76. }
  77. void timing() //INT0_INTERRUPT using 0
  78. {
  79.          if(oldSec== P_SEC)
  80.                  return;
  81.                 oldSec= P_SEC;
  82.
  83.                 //seting alarm,
  84.                 //if no button press over 5 second
  85.                 //alarm is seted
  86.                 //else alarm will cancle
  87.                 if( mode == MOD_SETALARM )
  88.                 {
  89.                          sec5++;
  90.                          if(sec5> 10)
  91.                          {
  92.                                  alarmSeted= 1;
  93.                                  mode= MOD_NORMAL;
  94.                                  modeDisplay();
  95.                                  sec5=0;
  96.                          }
  97.                 }
  98.
  99.                 sec++;
  100.                 if(sec> 119)
  101.                 {
  102.                          sec= 0;
  103.                          minute++;
  104.                         if(minute> 59)
  105.                         {
  106.                                  minute= 0;
  107.                                  hour++;
  108.          if(hour>23) hour=0;
  109.          if(mode== MOD_NORMAL) //normal mod or is alarm mod
  110.                            {
  111.                               SET_H_BUF(hour);
  112.                            }
  113.
  114.                          }
  115.
  116.                                 //check alarm every minute
  117.                                 P_ALARM= 0;
  118.                                 if( alarmSeted && (minute== a_minute ) && (hour==a_hour) )
  119.                                         P_ALARM= 1;
  120.
  121.                                 if(mode== MOD_NORMAL)
  122.                                 {
  123.                                          SET_M_BUF(minute);
  124.                                 }
  125.
  126.                 }
  127.
  128. }
  129. void display() T0_INTERRUPT using 0
  130. {
  131.    T0_Stop;
  132.
  133.          P3&= 0x0f;
  134.    P_WEI |=(0x10<<i);
  135.          P_LED= segCode[dspBuf[i] ];
  136.
  137.          if(i==2)
  138.          {
  139.       if(mode== MOD_NORMAL)
  140.                           flashDot();
  141.       if(mode==MOD_SETALARM)
  142.                                 P_LED&= 0x7f;
  143.                 }
  144.          i++;
  145.          if(i>3)
  146.          {
  147.                  i=0;
  148.                  timing();
  149.                  if(mode== MOD_COUNT)
  150.         counting();
  151.          }
  152.          T0_Load(4000);
  153.          T0_Run;
  154. }
  155. void main(void)
  156. {
  157. //T0 use to display
  158.    T0_16bit;
  159.    T0_Load(5000);
  160.          T0_PolityHigh;
  161.    T0_Enable;
  162.    T0_Run; //
  163.
  164.          //
  165.          EnableAllInt;
  166.          SET_H_BUF(hour);
  167.          SET_M_BUF(minute);
  168.          P_ALARM= 0;
  169.    while(1)
  170.    {
  171.
  172.                   KeyPress(P_MOD,{
  173.                mode++;
  174.                if(mode> MOD_SETALARM)
  175.                                  {
  176.                                          alarmSeted=0;
  177.                                          P_ALARM= 0;
  178.                                          mode= MOD_NORMAL;
  179.                                  }
  180.                modeDisplay();
  181.                         });
  182.       KeyPress(P_MINUTE_UP,
  183.             {
  184.                switch(mode){
  185.                            case MOD_NORMAL:
  186.                                          SET_H_BUF(hour);
  187.                              UP_MINUTE(minute);
  188.            break;
  189.          case MOD_SETALARM:
  190.                                          UP_MINUTE(a_minute);
  191.                                          SET_H_BUF(a_hour);
  192.                                          if(i==2) P_LED&= 0x7f;//disply dot
  193.                                          sec5= 0;
  194.            break;
  195.          case MOD_COUNT:
  196.            count= 0;
  197.                                          ZERO_BUF;
  198.
  199.            break;
  200.           }
  201.                          });
  202.             KeyPress(P_HOUR_UP , {
  203.                                 switch(mode){
  204.                            case MOD_NORMAL:
  205.                                          SET_M_BUF(minute);
  206.                              UP_HOUR(hour);
  207.            break;
  208.          case MOD_SETALARM:
  209.                                          SET_M_BUF(a_minute);
  210.                                          UP_HOUR(a_hour);
  211.
  212.                                          sec5= 0;
  213.            break;
  214.
  215.           }
  216.                          });
  217.    }
  218. }
仿真Keil代碼下載,請大家多多指教:
cnttm.rar (30.65 KB, 下載次數: 11)
收藏收藏2 分享淘帖 頂 踩
