2021-11-17 10:47 上傳
1.串口使用
- private fun openSerialPort(){
- serialPortFinder = SerialPortFinder()
- serialHelper = object : SerialHelper() {
- override fun onDataReceived(comBean: ComBean) {
- runOnUiThread {
- // Toast.makeText(
- // baseContext,
- // FuncUtil.ByteArrToHex(comBean.bRec),
- // Toast.LENGTH_SHORT
- // ).show()
- * TODO 將獲取的數(shù)據(jù)進(jìn)行列表適配
- map = HashMap()
- (map as HashMap<String, Any>)["Value"] =comBean.sRecTime + ": " +
- ByteUtil.hexStringToString(ByteUtil.bytesToHexString(comBean.bRec))
- list.add(map as HashMap<String, Any>)
- Handler(Looper.getMainLooper()).postDelayed({
- * 列表數(shù)據(jù)的溢處理已經(jīng)適配
- if (list.size>12){
- map = list[0]
- list.remove(map)
- initAdapter()
- }, 300)
- //獲取串口地址
- val ports = serialPortFinder!!.allDevicesPath
- //設(shè)置波特率地址
- val botes = arrayOf(
- "0",
- "50",
- "75",
- "110",
- "134",
- "150",
- "200",
- "300",
- "600",
- "1200",
- "1800",
- "2400",
- "4800",
- "9600",
- "19200",
- "38400",
- "57600",
- "115200",
- "230400",
- "460800",
- "500000",
- "576000",
- "921600",
- "1000000",
- "1152000",
- "1500000",
- "2000000",
- "2500000",
- "3000000",
- "3500000",
- "4000000"
- val spAdapter = SpAdapter(this)
- * TODO 適配下拉列表(串口地址)
- spAdapter.setDatas(ports)
- binding.spSerial.adapter = spAdapter
- binding.spSerial.onItemSelectedListener = object : OnItemSelectedListener {
- override fun onItemSelected(
- parent: AdapterView<*>?,
- view: View,
- position: Int,
- id: Long
- serialHelper?.close()
- serialHelper?.port = ports[position]
- binding.EditText1.setText(ports[position])
- binding.open.text = "關(guān)閉串口"
- override fun onNothingSelected(parent: AdapterView<*>?) {}
- * TODO 適配下拉列表(波特率地址)
- val spAdapter2 = SpAdapter(this)
- spAdapter2.setDatas(botes)
- binding.spBote.adapter = spAdapter2
- binding.spBote.onItemSelectedListener = object : OnItemSelectedListener {
- view: View,
- position: Int,
- id: Long
- serialHelper?.setBaudRate(botes[position])
- binding.EditText2.setText(botes[position])
- override fun initListener() {
- //打開(kāi)串口
- binding.open.setOnClickListener{
- try {
- serialHelper?.open()
- binding.open.text = "打開(kāi)成功"
- showToast("打開(kāi)成功")
- } catch (e: IOException) {
- e.printStackTrace()
- //發(fā)送消息
- binding.send.setOnClickListener{
- if (binding.radioGroup.getCheckedRadioButtonId() == R.id.radioButton1) {
- if (binding.SendText.text.toString().isNotEmpty()) {
- if (serialHelper!!.isOpen) {
- serialHelper!!.sendTxt(binding.SendText.text.toString())
- } else {
- showToast("搞毛啊,串口都沒(méi)打開(kāi)")
- } else {
- showToast("填數(shù)據(jù)吧")
- } else {
- if (binding.SendText.text.toString().length > 0) {
- serialHelper!!.sendHex(binding.SendText.text.toString())
- } else {
- } else {
- //toolbar返回按鈕監(jiān)聽(tīng)
- binding.toolbar.setNavigationOnClickListener { finish() }
項(xiàng)目地址:HTTPS ://gitee.com/herui12/教MVAndroidchart
評(píng)分
查看全部評(píng)分
