基于51單片機(jī)的溫度控制器設(shè)計(jì)
功能較為完善
單片機(jī)源程序如下:
- #include "reg52.h"
- #include "ct107.h"
- #include "iic.h"
- #include "EEPROM.H"
- #include "18b20.h"
- #include "i2c.h"
- bit flag_get,keyflag; //定義采集溫度標(biāo)志位和按鍵標(biāo)志位
- sbit PWM=P3^4; //定義脈沖端口
- sbit LED1=P0^0;
- sbit LED2=P0^1;
- sbit LED3=P0^2;
- sbit LED4=P0^3;
- sbit LED5=P0^4;
- sbit LED6=P0^5;
- sbit LED7=P0^6;
- sbit LED8=P0^7;
- unsigned char code smg_du[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; //數(shù)碼管段選“0~9”
- unsigned char code smg_we[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //數(shù)碼管位選
- unsigned char UpT,DoT,NowT; //上限溫度,下限溫度,目前溫度
- unsigned int temp; //定義中間變量
- unsigned char dat[8]; //定義顯示數(shù)組
- unsigned int Ad_data;
- void key(); //按鍵函數(shù)
- void diswork(); //顯示處理函數(shù)
- void Write_byte(unsigned char add,unsigned char dat); //向EEPROM寫(xiě)一個(gè)字節(jié)
- unsigned char read_byte(unsigned char add); //從EEPROM讀一個(gè)字節(jié)
- unsigned int ReadTemperature(void); //讀當(dāng)前溫度
- void deplay_50us(unsigned char t); //50us延時(shí)函數(shù)
- void work(); //判斷采用何種措施函數(shù)
- void Ad_read(void); //電壓讀取
- main() //主函數(shù)
- ct107_init(); //初始化板(關(guān)蜂鳴器,繼電器,LED等)
- TMOD=0X12; //定義定時(shí)器1為16位,定時(shí)器0為8位重載定時(shí)器
- TH1=(65536-2000)/256; //定時(shí)2ms
- TL1=(65536-2000)%256;
- TH0=256-100; //定時(shí)0.1ms
- TL0=256-100;
- TR1=1; //開(kāi)定時(shí)器T1
- ET1=1; //開(kāi)定時(shí)器T1中斷
- TR0=1; //開(kāi)定時(shí)器T0
- EA=1; //開(kāi)總中斷
- while(1)
- key();
- if(flag_get==1) //定時(shí)讀取當(dāng)前溫度
- Ad_read();
- temp=ReadTemperature();
- NowT=temp>>4; //讀溫度整數(shù)部分
- flag_get=0;
- UpT=read_byte(0x00); //從EEPROM讀出上限溫度
- DoT=read_byte(0x01); //從EEPROM讀出下限溫度
- work();
- diswork();
- 判斷采用何種措施函數(shù)
- void work()
- if(NowT>UpT) //當(dāng)目前溫度高于上限溫度是開(kāi)T0中斷,產(chǎn)生1KHz占空比為30%的方波
- ET0=1;
- LED1=0;
- LED2=1;
- LED3=1;
- LED4=1;
- LED5=1;
- LED6=1;
- LED7=1;
- LED8=1;
- P2|=Y4C;
- P2&=0x1f;
- else
- if(NowT>DoT) //溫度在上下限之間時(shí),關(guān)中斷,P3^4口保持高電平
- ET0=0;
- PWM=1;
- LED1=1;
- LED2=0;
- LED3=1;
- LED4=1;
- LED5=1;
- LED6=1;
- LED7=1;
- LED8=1;
- P2|=Y4C;
- P2&=0x1f;
- if(NowT<DoT) //溫度低于下限溫度時(shí)開(kāi)繼電器,關(guān)蜂鳴器避免干擾
- P2&=0x1f;
- BUZZ=0;
- RELAY=1;
- P2|=Y5C;
- P2&=0x1f;
- LED1=1;
- LED2=1;
- LED3=0;
- LED4=1;
- LED5=1;
- LED6=1;
- LED7=1;
- LED8=1;
- P2|=Y4C;
- P2&=0x1f;
- else
- P2&=0x1f;
- BUZZ=0;
- RELAY=0;
- P2|=Y5C;
- P2&=0x1f;
- 按鍵掃描函數(shù)
- void key()
- if((P3&0x0f)!=0x0f)
- if(!keyflag)
- deplay_50us(200);
- keyflag=1;
- switch(P3&0x0f)
- case 0x07:if(UpT<99)UpT++;break;
- case 0x0b:if(DoT<UpT-1)DoT++;break;
- case 0x0d:if(UpT-1>DoT)UpT--;break;
- case 0x0e:if(DoT>0)DoT--;break;
- default:break;
- if(UpT<=DoT|UpT>99|DoT<0) //保護(hù)程序,一旦存儲(chǔ)數(shù)據(jù)出錯(cuò)可以使數(shù)據(jù)回到設(shè)定值,使系統(tǒng)穩(wěn)定
- UpT=30;
- DoT=0;
- Write_byte(0x00,UpT); //將數(shù)據(jù)寫(xiě)入EEPROM
- deplay_50us(18);
- Write_byte(0x01,DoT);
- deplay_50us(18);
- else
- keyflag=0;
- 顯示數(shù)據(jù)處理函數(shù)
- void diswork()
- dat[0]=UpT/10;
- dat[1]=UpT%10;
- dat[2]=DoT/10;
- dat[3]=DoT%10;
- dat[4]=Ad_data/10;
- dat[5]=Ad_data%10;
- dat[6]=NowT/10;
- dat[7]=NowT%10;
- 寫(xiě)入內(nèi)存一個(gè)字節(jié)
- ET1=0;
- init_iic(); //可以不初始化,函數(shù)已有嚴(yán)格的時(shí)序控制
- Start(); //起始信號(hào)
- Send(AddWr); //器件地址
- Ack(); //應(yīng)答
- Send(add); //存放地址
- Ack();
- Send(dat); //存放數(shù)據(jù)
- Ack();
- Stop(); //停止信號(hào)
- ET1=1;
- 讀內(nèi)存一個(gè)字節(jié)
- unsigned char rdat;
- ET1=0;
- Send(AddWr); //發(fā)送寫(xiě)器件地址
- Ack();
- Send(add);
- Ack();
- Send(AddRd); //讀器件地址
- Ack();
- rdat=Read(); //讀數(shù)據(jù)
- NoAck(); //好像是告訴器件接收完畢
- ET1=1;
- return rdat;
- 讀取溫度
- unsigned char a=0;
- unsigned int b=0;
- unsigned int t=0;
- Init_DS18B20();
- WriteOneChar(0xCC); // 跳過(guò)讀序號(hào)列號(hào)的操作
- WriteOneChar(0x44); // 啟動(dòng)溫度轉(zhuǎn)換
- delay(50);
- Init_DS18B20();
- EA=0;
- WriteOneChar(0xCC); //跳過(guò)讀序號(hào)列號(hào)的操作
- WriteOneChar(0xBE); //讀取溫度寄存器等(共可讀9個(gè)寄存器) 前兩個(gè)就是溫度
- a=ReadOneChar(); //低位
- b=ReadOneChar(); //高位
- b<<=8;
- t=a+b;
- EA=1;
- return(t);
- 定時(shí)器0中斷,產(chǎn)生1Khz占空比為30%的方波
- void tm0_isr() interrupt 1
- static j;
- if(j<3)
- PWM=1;
- else
- PWM=0;
- j++;
- if(j==10)
- j=0;
- 定時(shí)器中斷
- void tm1_isr() interrupt 3 //定時(shí)掃描數(shù)碼管和溫度
- static i,k;
- unsigned char com[8]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff}; //用于控制數(shù)碼管的亮滅
- TH1=(65536-1800)/256;
- TL1=(65536-1800)%256;
- if(i==4)
- P2&=0x1f;
- P0=0xff;
- P2=Y7C;
- P2&=0x1f;
- P0=smg_we[i]&com[i];
- P2=Y6C;
- P2&=0x1f;
- P0=smg_du[dat[i]]+0x80;
- P2=Y7C;
- P2&=0x1f;
- i++;
- else
- P2&=0x1f;
- P0=0xff;
- P2=Y7C;
- P2&=0x1f;
- P2=Y6C;
- P2&=0x1f;
- P0=smg_du[dat[i]];
- P2=Y7C;
- P2&=0x1f;
- i++;
- if(i==8)
- i=0;
- k++;
- if(k==25)
- k=0;
- flag_get=1;//標(biāo)志位有效
- 大約50us的延時(shí)函數(shù)
- unsigned char j;
- for(;t>0;t--)
- for(j=19;j>0;j--);
- Ad_data=adc_pcf8591(0);
- Ad_data=Ad_data*50/256;
Keil代碼下載:
溫度.zip
(91.34 KB, 下載次數(shù): 13)
2021-11-4 09:22 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
