查看: 3589|回復: 1
W25Q128驅動程序
ID:130230 發表于 2021-10-28 16:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#define W25Q128_NUM       0xEF4018 /* FALSH型號 */
#define W25CMD_JEDEC_ID      0x9F
#define W25CMD_WERITE_ENABLE 0x06
#define W25CMD_READ_STATUS   0x05 /* 讀狀態寄存器 用來判斷busy */
#define W25CMD_SECTOR_ERASE  0x20
#define W25CMD_PAGE_PROGRAM  0x02
#define W25_PAGE_SIZE        256
static void W25Q128WriteEnable(void);
static u8 WaitW25Idle(void);
static void AlignmentWrite (u8 *buff, u32 addr, u16 len);
/* 讀取芯片ID */
u32 W25Q128ReadId(void)
    u8 tempH, tempM, tempL;
    SPI2_CSN_SELECT();
    (void)Spi2WriteByte(W25CMD_JEDEC_ID);
    (void)Spi2ReadByte(&tempH);
    (void)Spi2ReadByte(&tempM);
    (void)Spi2ReadByte(&tempL);
    SPI2_CSN_RELASE();
    return (U32)((tempH << 16) | (tempM << 8) | tempL);
/* 扇區擦除 */
void W25EraseSector(u32 addr)
    W25Q128WriteEnable();
    (void)WaitW25Idle();
    SPI2_CSN_SELECT();
    (void)Spi2WriteByte(W25CMD_SECTOR_ERASE);
    (void)Spi2WriteByte((u8)(addr >> 16));
    (void)Spi2WriteByte((u8)(addr >> 8));
    (void)Spi2WriteByte((u8)addr);
    SPI2_CSN_RELASE();
/* 按頁寫入 */
void W25PageWrite( u8 *buff, u32 addr, u16 len)
    SPI2_CSN_SELECT();
    (void)Spi2WriteByte(W25CMD_PAGE_PROGRAM);
    while(len--)
        (void)Spi2WriteByte(*buff);
        buff++;
    SPI2_CSN_RELASE();
/* 對齊寫入一定長度的數據 */
    u8 numOfPage   = len / W25_PAGE_SIZE;
    u8 numOfLeave  = len % W25_PAGE_SIZE;
    if (numOfPage == 0) /* 數據長度不滿1頁 */
        W25PageWrite(buff, addr, W25_PAGE_SIZE);
        return ;
    while(numOfPage--)
        buff += W25_PAGE_SIZE;
        addr += W25_PAGE_SIZE;
    if (numOfLeave == 0)
        return;
    W25PageWrite(buff, addr, numOfLeave);
/* 非對齊寫入一定長度的數據 */
static void UnAlignmentWrite (u8 *buff, u32 addr, u16 len)
    u8 unAlignmentLen = W25_PAGE_SIZE - (addr % W25_PAGE_SIZE); /* 寫完這個長度的數據之后就可以對齊寫入了*/
    if (numOfPage == 0)
        if (numOfLeave > unAlignmentLen)
            W25PageWrite(buff, addr, unAlignmentLen);
            buff += unAlignmentLen;
            addr += unAlignmentLen;
            W25PageWrite(buff, addr, numOfLeave - unAlignmentLen);
            W25PageWrite(buff, addr, len);
        return ;
    W25PageWrite(buff, addr, unAlignmentLen); /* 寫入不對齊的部分 */
    len -= unAlignmentLen;
    AlignmentWrite(buff, addr, len);
/* 寫使能 */
    SPI2_CSN_SELECT();
    (void)Spi2WriteByte(W25CMD_WERITE_ENABLE);
    SPI2_CSN_RELASE();
等待芯片空閑
return : 0失敗 1成功
    u8 temp;
    u8 retryCnt = 0;
    SPI2_CSN_SELECT();
    do {
        (void)Spi2WriteByte(W25CMD_READ_STATUS);
        (void)Spi2ReadByte(&temp);
        if (++retryCnt == 250)
            return 0;
    }while(temp & 0x01);
    SPI2_CSN_RELASE();
    return 1;
參與人數 1黑幣 +30 收起 理由
admin + 30 共享資料的黑幣獎勵!
收藏收藏3 分享淘帖 頂 踩
ID:38683 發表于 2023-3-15 10:39 | 只看該作者
剛好用到,先謝了!
