查看: 4232|回復(fù): 4
帶溫度補(bǔ)償?shù)膯纹瑱C(jī)超聲波測距儀程序原理圖PCB文件
ID:971955 發(fā)表于 2021-10-18 22:11 | 顯示全部樓層 |閱讀模式
制作出來的實(shí)物圖如下:
單片機(jī)源程序如下:
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. #define ulong unsigned long
  5. sbit we0=P2^0; //                數(shù)碼管位定義
  6. sbit we1=P2^1; //
  7. sbit we2=P2^2; //
  8. sbit we3=P2^3;
  9. sbit fasong=P1^0;                 //超生波發(fā)送接口
  10. sbit jieshou=P3^2;                 //超聲波接受接口
  11. sbit k1=P3^6;                         //開關(guān)鍵
  12. sbit k2=P3^7;                         //溫度距離顯示切換鍵
  13. sbit ds=P1^4;                         //溫度傳感數(shù)據(jù)接口
  14. uchar timers,mi,fenmi,limi,num2,num1,shi,ge,shifen,shengsu;
  15. bit flag,kaiflag,temflag;         //定義各種標(biāo)志位
  16. ulong t,s;                                         //接收時(shí)間和距離
  17. uint temp,num;
  18. float n;                                         //18b20讀取數(shù)據(jù)時(shí)用
  19. uchar code table[]=                         //數(shù)碼管顯示編碼(不帶小數(shù)點(diǎn)and帶)
  20. {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
  21. 0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
  22. void init();                                 //聲明初始化函數(shù)
  23. void delay100us()                         //超聲波避盲區(qū)延時(shí)函數(shù)
  24. {
  25.         uchar i,j;
  26.         for(i=40;i>0;i--)
  27.                 for(j=248;j>0;j--);
  28. }
  29. void delay(uchar a)                           //短暫延時(shí)函數(shù)(用于18B20)
  30. {
  31.          while(a>0)
  32.          a--;
  33. }
  34. void shijian(uint x)                        //一毫秒延時(shí)函數(shù)
  35. {
  36.         uint i,j;
  37.         for(i=x;i>0;i--)
  38.                  for(j=110;j>0;j--);
  39. }
  40. void reset()                                    //18B20復(fù)位
  41. {
  42.         ds=0;
  43.         delay(103);
  44.         ds=1;
  45.         delay(4);
  46. }
  47. void write(uchar date)                    //18B20寫一字節(jié)數(shù)據(jù)
  48. {
  49.          uchar temp,i;
  50.          uint j;
  51.          temp=date;
  52.          for(i=0;i<8;i++)
  53.          {
  54.                   temp=temp>>1;
  55.                  if(CY)                   //寫1
  56.                  {
  57.                          ds=0;
  58.                 j++;j++;
  59.                         ds=1;
  60.                         delay(8);
  61.                  }
  62.                  else
  63.                  {
  64.                          ds=0;
  65.                         delay(8);
  66.                         ds=1;
  67.                         j++;j++;
  68.                  }
  69.          }
  70. }
  71. uchar read()                                        //18B20讀一字節(jié)數(shù)據(jù)
  72. {
  73.         uchar j,dat;
  74.         for(j=0;j<8;j++)
  75.         {
  76.                 ds=0;
  77.                 dat>>=1;
  78.                 ds=1;
  79.                 delay(1);
  80.                 if(ds)
  81.                 dat|=0x80;
  82.                 delay(8);
  83.         }
  84.         return(dat);
  85. }
  86. uint get()                                                 //從溫度傳感器獲取數(shù)值
  87. {
  88.         uchar gao,di;
  89.         reset();
  90.         shijian(1);
  91.         write(0xcc);
  92.         write(0x44);
  93.         reset();
  94.         shijian(1);
  95.         write(0xcc);
  96.         write(0xbe);
  97.         di=read();
  98.         gao=read();
  99.         temp=gao<<8;
  100.         temp=temp|di;
  101.         n=temp*0.065+0.5;
  102.         temp=n*10;
  103.         return(temp);
  104. }
  105. void send()                                           //超聲波發(fā)送函數(shù)
  106. {
  107.         uchar i;
  108.         while(TF0==0)
  109.         {         we0=0;
  110.                  timers++;
  111.                  fasong=~fasong;
  112.                  for(i=12;i>0;i--);          //40hz延時(shí)
  113.                  if(timers==4)                  //連續(xù)發(fā)送兩個(gè)超聲波脈沖
  114.                  break;
  115.         }
  116.         we0=1;
  117.         timers=0;                                  //將發(fā)送次數(shù)歸零
  118.         TH0=0X00;                                  //定時(shí)器裝初值
  119.         TL0=0X32;                                  //裝0x32是因?yàn)榘l(fā)送時(shí)也占用了時(shí)間
  120.         TR0=1;                                          //打開計(jì)時(shí)器
  121.         EX0=1;                                          //打開外部中斷等待接收返回聲波
  122.         delay100us();                          //避盲延時(shí)
  123.         delay100us();
  124.         delay100us();
  125. //        delay100us();
  126. //        delay100us();
  127. }
  128. void keyscan()                                   //鍵盤掃描
  129. {
  130.         if(k1==0)                                   //開關(guān)鍵按下
  131.         {
  132.                 shijian(10);
  133.                 if(k1==0)
  134.                 kaiflag=~kaiflag;           //開關(guān)標(biāo)志位取反
  135.                 while(k1==0);                   //等待按鍵釋放
  136.         }
  137.         if(k2==0)                                  //k2按下
  138.         {
  139.                 shijian(10);
  140.                 if(k2==0)
  141.                 temflag=~temflag;          //溫度距離標(biāo)志位取反
  142.                 while(k2==0);                  //等待按鍵釋放
  143.         }
  144. }
  145. void temdisplay()                          //溫度顯示函數(shù)
  146. {
  147.         num=get();                                  //讀取當(dāng)前溫度值
  148.         shi=num/100;                          //分離出十位值
  149.         ge=num%100/10;                          //分離出個(gè)位值
  150.         shifen=num%10;                          //分離出十分位值
  151.                 P0=table[shi];                  //十位顯示
  152.                 we1=0;
  153.                 we0=1;
  154.                 we2=1;
  155.                 we3=1;
  156.                 shijian(6);
  157.                 P0=table[ge+10];          //個(gè)位顯示
  158.                 we1=1;
  159.                 we0=1;
  160.                 we2=0;
  161.                 we3=1;
  162.                 shijian(6);
  163.                 P0=table[shifen];          //十分位顯示
  164.                 we3=0;
  165.                 we1=1;
  166.                 we0=1;
  167.                 we2=1;
  168.                 shijian(1);
  169. }
  170. void init()                                          //初始化函數(shù)
  171. {
  172.         TMOD=0x21;           //定時(shí)器1為8位自動(dòng)重裝模式,
  173.                                    //定時(shí)器0為十六位計(jì)數(shù)器
  174.         TH0=0X00;           //定時(shí)器0裝初值
  175.         TL0=0X32;
  176.         TH1=0x00;           //定時(shí)器裝空值
  177.         TL1=0x00;
  178.         TR1=0;                   //關(guān)閉顯示定時(shí)
  179.         TR0=0;                   //關(guān)閉定時(shí)器0計(jì)時(shí)
  180.         EA=1;                   //打開總中斷
  181.         ET0=1;                   //打開計(jì)時(shí)中斷
  182.         ET1=1;                   //打開定時(shí)器1中斷
  183.         EX0=1;                   //打開外部中斷
  184.         IT0=1;                   //外部中斷選擇下降沿觸發(fā)
  185.         P2=0xff;
  186.         P0=0xff;           //關(guān)閉數(shù)碼管段選
  187.         kaiflag=0;           //開標(biāo)志位置0
  188.         temflag=0;           //溫度距離標(biāo)志位置0
  189. }
  190. void main()                   //主函數(shù)
  191. {
  192.         init();                   //進(jìn)行初始化
  193.         while(1)
  194.         {
  195.                 keyscan();        //鍵盤掃描
  196.                 if((kaiflag==1)&&(temflag==1))//如果打開并且選擇測溫
  197.                 {
  198.                         temdisplay();                          //進(jìn)行溫度顯示
  199.                         TR1=0;                                          //將定時(shí)器都關(guān)閉
  200.                     TR0=0;
  201.                         EX0=0;
  202.                 }
  203.                 if((kaiflag==1)&&(temflag==0)) //如果打開并選擇測距
  204.                 {
  205.                         send();                                           //發(fā)送脈沖
  206.                         num=get();                                   //讀取溫度值
  207.                         TR1=1;                                           //打開測距顯示中斷
  208.                 }
  209.                 if(kaiflag==0)                                   //如果處于關(guān)閉狀態(tài)
  210.                 {
  211.                         TR1=0;
  212.                         TR0=0;                                                //測距顯示關(guān)閉
  213.                         init();                                                //進(jìn)行初始化
  214.                 }
  215.         }
  216. }
  217. /*******************對(duì)下面用到的中斷的解釋************
  218. 1.外部中斷0用來接收返回的脈沖,當(dāng)接收到以后進(jìn)行中斷處理,優(yōu)先級(jí)最高;
  219. 2.定時(shí)器0用來計(jì)時(shí),選擇的是十六位定時(shí)模式;用來計(jì)算超聲波脈沖
  220.   從發(fā)射到接受所用的時(shí)間。
  221. 3.定時(shí)器1用來作為測試距離的顯示定時(shí)。每中斷一次就掃描一位數(shù)碼管
  222. *********************************************************/
  223. void IN0() interrupt 0                                        //超聲波接收中斷(外部)
  224. {
  225.         TR0=0;        //關(guān)閉設(shè)計(jì)時(shí)器
  226.         EX0=0;        //停止接收返回脈沖
  227.     if(num<=50)                                          //根據(jù)當(dāng)前溫度值來調(diào)整聲速
  228.         {
  229.                 shengsu=165;
  230.         }
  231.         else if(num<=100)
  232.         {
  233.                 shengsu=169;
  234.         }
  235.         else if(num<=200)
  236.         {
  237.                 shengsu=172;
  238.         }
  239.         else if(num<=300)
  240.         {
  241.                 shengsu=175;
  242.         }
  243.         else if(num<=500)
  244.         {
  245.                 shengsu=180;
  246.         }
  247.         t=TH0*256+TL0;                                //計(jì)算從發(fā)射到接收用時(shí)(單位us)
  248.         s=t*shengsu/10000;                                        //根據(jù)時(shí)間計(jì)算距離
  249.         mi=s/100;                                                        //分離出米
  250.         fenmi=s%100/10;                                                //……分米
  251.         limi=s%10;                                                        //……厘米
  252.         EX0=1;                                                //計(jì)算完畢允許接收下個(gè)脈沖
  253. }
  254. void timer0() interrupt 1
  255. {
  256.         TR0=0;
  257.         TH0=0;
  258.         TL0=0;
  259. }
  260. void timer1() interrupt 3                 //顯示測距距離中斷
  261. {
  262.         TH1=0x00;                                         //裝初值
  263.         TL1=0x00;
  264.         num1++;
  265.         if(num1==5)                                         //如果經(jīng)過1250us,顯示一位
  266.         {
  267.                 num1=0;
  268.                 shijian(2);
  269.                 num2++;
  270.                 if(num2==4)
  271.                 num2=0;
  272.         }
  273.         if(temflag==0)
  274.         {
  275.                 if(num2==0)
  276.                 {
  277.                         P0=table[mi+10];
  278.                         we1=0;
  279.                         we0=1;
  280.                         we2=1;
  281.                         we3=1;
  282.                 }
  283.                 if(num2==2)
  284.                 {
  285.                         P0=table[fenmi];
  286.                         we1=1;
  287.                         we0=1;
  288.                         we2=0;
  289.                         we3=1;
  290.                 }
  291.                 if(num2==3)
  292.                 {
  293.                         P0=table[limi];
  294.                         we3=0;
  295.                         we1=1;
  296.                         we0=1;
  297.                         we2=1;
  298.                 }
  299.         }
  300. }
所有資料51hei附件下載:
原理圖和pcb.7z (156.28 KB, 下載次數(shù): 95)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
ID:372579 發(fā)表于 2022-2-24 07:44 來自觸屏版 | 顯示全部樓層
這個(gè)很不錯(cuò)哦
ID:893997 發(fā)表于 2022-2-24 21:22 | 顯示全部樓層
可以但不建議都寫在一個(gè)文件
ID:1086127 發(fā)表于 2023-6-27 10:34 | 顯示全部樓層
請問有那個(gè)仿真圖嗎
ID:480664 發(fā)表于 2023-11-22 16:25 | 顯示全部樓層
這個(gè)很不錯(cuò)了,詳盡啊!
