* 3個IO接識別22鍵測試程序 *
* MCU: AT89C2051 *
* OSC: 12M cysytel *
* 程序設計:Cowboy *
* 程序版本:V1.0 *
#include <reg52.h>
//================== IO口線連接 ==================
sbit Bus = P1^0;
sbit IO_a = P1^4;
sbit IO_b = P1^3;
sbit IO_c = P1^2;
//================== 變量聲明 ====================
unsigned char Disp_buf[3];
unsigned char Dig;
unsigned char Key_count;
unsigned char bdata Key_state;
sbit KB0 = Key_state^0;
sbit KB1 = Key_state^1;
sbit KB2 = Key_state^2;
sbit KB3 = Key_state^3;
sbit KB4 = Key_state^4;
sbit KB5 = Key_state^5;
//================== 表格數據 ====================
code unsigned char LED_font[24]=
0x84,0x9f,0xa2,0x8a,0x99,0xc8,0xc0,0x9e,0x80, //012345678
0x88,0x90,0xc1,0xe4,0x83,0xe0,0xf0,0xff,0xfb, //9abcdef -
code unsigned char Key_tab[64]= //鍵碼映射表
{// 0 1 2 3 4 5 6 7 8 9
22, 0, 2, 0, 0, 0, 0, 0, 4, 0, //0
0, 0, 0, 0, 0,18, 0, 0, 0, 0, //1X
0, 0, 0, 0, 0, 0, 3,14, 0, 0, //2X
20,10, 6, 0, 0, 0, 0, 0, 1,19, //3X
0, 5, 0, 0, 0,15, 0,11, 0, 0, //4X
0,17, 0, 0,13, 8, 0,21, 0, 9, //5X
16,12, 7, 0 //6X
//=============== 檢測按鍵 =================
void Key_scan()
unsigned char i;
Key_count --; //掃描次序
Key_count &= 3;
switch (Key_count) //按次序處理
case 2: //第一輪掃描
KB0 = IO_b;
KB1 = IO_c;
IO_a = 1;
IO_b = 0;
break;
case 1: //每二輪掃描
KB2 = IO_c;
KB3 = IO_a;
IO_b = 1;
IO_c = 0;
break;
case 0: //每三輪掃描
KB4 = IO_a;
KB5 = IO_b;
IO_c = 1;
break;
default: //每四輪掃描
if (!IO_a) KB0 = 0;
if (!IO_b) KB2 = 0;
if (!IO_c) KB4 = 0;
IO_a = 0;
//======更新顯示緩沖區=======
i = Key_tab[Key_state];
if (i == 0)
Disp_buf[2] = 0x11; //顯示三橫
Disp_buf[1] = 0x11;
Disp_buf[0] = 0x11;
Disp_buf[2] = 0x0c; //字符"C"
Disp_buf[1] = i / 10; //鍵碼十位
Disp_buf[0] = B;于 //鍵碼個位
Key_state = 0;
ONE WIRE 顯示總線驅動程序
//=============== 發送一位 =================
void Send_bit(bit Dat)
unsigned char i = 3;
if (!Dat) Bus = 0;
Bus = 0;
Bus = 1;
while(--i); //延時8us
Bus = 1;
//=============== 總線驅動 =================
void Bus_drive()
unsigned char i = 0;
unsigned char Sdat;
Send_bit(1); //Bit6消隱
do Bus = 1; while(--i); //延時768us
do Bus = 0; while(--i); //延時768us
Bus = 1;
Sdat = LED_font[Disp_buf[Dig++]]; //獲取顯示數據
Send_bit(Sdat & 0x01); //發送位0
Send_bit(Sdat & 0x02); //發送位1
Send_bit(Sdat & 0x04); //發送位2
Send_bit(Sdat & 0x08); //發送位3
Send_bit(Sdat & 0x10); //發送位4
Send_bit(Sdat & 0x20); //發送位5
Send_bit(Dig & 0x01); //發送位選1
Send_bit(Dig & 0x02); //發送位選2
while(--i); //延時512us
Send_bit(Sdat & 0x40); //發送位6
for (i = 7;i> 0;i--) Send_bit(1); //位6移至Dout
if (Dig == 3) Dig = 0;
延時 5ms 程序
void Delay_5ms()
while(!TF1);
TF1 = 0;
TH1 = (- 5000) / 256;
TL1 = (- 5000) % 256;
主程序
TMOD = 0x10; //定時器1,16位模式
TCON = 0xc0; //TR1=1;TF1=1;
while(1) //主循環
Bus_drive(); //顯示總線驅動
Key_scan(); //檢測按鍵
Delay_5ms(); //延時5MS
