包含Proteus仿真圖和源代碼
單片機(jī)源程序如下:
- #include<reg52.h>
- #include<intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- uint count0, count1, count2, flag, flag1; //三個(gè)定時(shí)時(shí)間 遞減計(jì)時(shí) 流水燈計(jì)時(shí) 暫停計(jì)時(shí)
- uint inx1, inx2, inx3, inx4, inx5, inx6, temp; //六根數(shù)碼管的顯示
- uchar flowlight;
- void delay(uint num); //延時(shí)函數(shù)
- void display(uchar inx1, uchar inx2, uchar inx3, uchar inx4, uchar inx5, uchar inx6); //數(shù)碼管顯示函數(shù)
- sbit Wela = P2^7; //位選端口
- sbit Dula = P2^6; //段選端口
- sbit beep = P2^3; //蜂鳴器端口
- uchar code Table[] = //段碼數(shù)組
- 0x3F,0x06,0x5B,0x4F,0x66,0x6D, //共陰極段碼 0 1 2 3 4 5
- 0x7D,0x07,0x7F,0x6F,0x77,0x7C, //共陰極段碼 6 7 8 9 A b
- 0x39,0x5E,0x79,0x71,0x73,0x3E, //共陰極段碼 C d E F P U
- 0x31,0x6E,0x76,0x38,0x00 //共陰極段碼 T y H L 滅燈
- /************延時(shí)函數(shù)***************/
- void delay(uint num) //延時(shí) num ms
- uint x, y;
- for(x=num; x>0; x--)
- for(y=110; y>0; y--);
- void main()
- temp = 765432 - 765000;
- count0 = 0;
- count1 = 0;
- count2 = 0;
- flag = 0;
- flag1 = 0;
- EA = 1;
- EX0 = 1;
- TMOD = 0x11; //設(shè)置定時(shí)器T0,T1 為工作方式1
- TH0 = (65536 - 50000) / 256;
- TL0 = (65536 - 50000) % 256;
- TH1 = (65536 - 50000) / 256;
- TL1 = (65536 - 50000) % 256;
- ET0 = 1; //開定時(shí)器T0中斷
- ET1 = 1; //開定時(shí)器T1中斷
- TR0 = 1; //打開定時(shí)器T0
- TR1 = 1; //打開定時(shí)器T1
- P1 = 0xfe;
- flowlight = P1;
- while(1)
- beep = 0;
- if(flag1 != 1)
- display(7, 6, 5, inx4, inx5, inx6);
- if(temp == 398)
- TR0 = 0;
- TR1 = 0;
- flag = 1;
- P1 = 0xff;
- TR0 = 1;
- count0 = 0;
- temp--;
- else
- display(20, 14, 21, 21, 0, 22);
- TR0 = 0;
- /***********數(shù)碼管顯示函數(shù)************/
- Wela = 1;
- P0 = 0xfe;
- Wela = 0;
- Dula = 1;
- P0 = Table[inx1];
- Dula = 0;
- delay(5);
- Wela = 1;
- P0 = 0xfd;
- Wela = 0;
- Dula = 1;
- P0 = Table[inx2];
- Dula = 0;
- delay(5);
- Wela = 1;
- P0 = 0xfb;
- Wela = 0;
- Dula = 1;
- P0 = Table[inx3];
- Dula = 0;
- delay(5);
- Wela = 1;
- P0 = 0xf7;
- Wela = 0;
- Dula = 1;
- P0 = Table[inx4];
- Dula = 0;
- delay(5);
- Wela = 1;
- P0 = 0xef;
- Wela = 0;
- Dula = 1;
- P0 = Table[inx5];
- Dula = 0;
- delay(5);
- Wela = 1;
- P0 = 0xdf;
- Wela = 0;
- Dula = 1;
- P0 = Table[inx6];
- Dula = 0;
- delay(5);
- /*********定時(shí)器T0定時(shí)**********/
- void timer0() interrupt 1 //定時(shí)器T0定時(shí)50ms
- count0++;
- if(flag != 1)
- if(count0 == 10) //流水燈延時(shí) 500ms 流動(dòng)
- beep = 1;
- flowlight = _crol_(flowlight, 1);
- P1 = flowlight;
- count0 = 0;
- else
- if(count0 % 4 == 0)
- P1 = ~P1;
- if(count0 == 60)
- flag1 = 1;
- /*********定時(shí)器T1中斷函數(shù)50ms*******/
- void timer1() interrupt 3 //定時(shí)器T1定時(shí)50ms
- count1++;
- if(count1 == 2) //數(shù)碼管以100ms遞減
- temp--;
- inx4 = temp / 100;
- inx5 = temp % 100 / 10;
- inx6 = temp % 10;
- count1 = 0;
復(fù)制代碼 新手程序,望大佬放過
所有資料51hei附件下載:
Works.rar
(95.66 KB, 下載次數(shù): 9)
2021-9-8 15:55 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
