本文出自:zhishi-zhishi點(diǎn)net
在開(kāi)發(fā)板上試驗(yàn)了GPIO點(diǎn)亮LED,串口中斷和定時(shí)器。
- #include "stm32f10x.h"
- GPIO :
- PC.14 PC.15 <---> LED
- PB.7 <---> Button
- PA.9 PA.10 <---> USART
- #define RCC_APB2ENR *(uint32_t*)(0x40021000+0x18)
- #define RCC_APB1ENR *(uint32_t*)(0x40021000+0x1C)
- #define GPIOC_CRH *(uint32_t*)(0x40011000+0x04)
- #define GPIOC_ODR *(uint32_t*)(0x40011000+0x0C)
- #define GPIOB_CRL *(uint32_t*)(0x40010C00+0x00)
- #define GPIOB_ODR *(uint16_t*)(0x40010C00+0x0C)
- #define GPIOB_BSRR *(uint16_t*)(0x40010C00+0x10)
- #define SETENA_ISER0 *(uint32_t*)(0xe000E100+0x00)
- #define EXTI_IMR *(uint32_t*)(0x40010400+0x00)
- #define EXTI_RTSR *(uint32_t*)(0x40010400+0x08)
- #define EXTI_FTSR *(uint32_t*)(0x40010400+0x0C)
- #define EXTI_PR *(uint32_t*)(0x40010400+0x14)
- #define AFIO_EXTICR2 *(uint32_t*)(0x40010000+0x0C)
- #define GPIOA_IDR *(uint32_t*)(0x40010800+0x08)
- #define GPIOA_ODR *(uint32_t*)(0x40010800+0x0C)
- #define GPIOA_CRH *(uint32_t*)(0x40010800+0x04)
- #define SETENA_ISER1 *(uint32_t*)(0xe000E100+0x04)
- //#define USART1_BASE *(uint32_t*)(0x40013800+0x00) //bug : redefinition
- #define USART1_SR *(uint32_t*)(0x40013800+0x00)
- #define USART1_DR *(uint32_t*)(0x40013800+0x04)
- #define USART1_BRR *(uint32_t*)(0x40013800+0x08)
- #define USART1_CR1 *(uint32_t*)(0x40013800+0x0C)
- #define USART1_CR2 *(uint32_t*)(0x40013800+0x10)
- #define USART1_CR3 *(uint32_t*)(0x40013800+0x14)
- #define TIM1_CR1 *(uint32_t*)(0x40012c00+0x00)
- #define TIM1_DIER *(uint32_t*)(0x40012c00+0x0C)
- #define TIM1_SR *(uint32_t*)(0x40012c00+0x10)
- #define TIM1_PSC *(uint32_t*)(0x40012c00+0x28)
- #define TIM1_ARR *(uint32_t*)(0x40012c00+0x2C)
- #define TIM3_CR1 *(uint32_t*)(0x40000400+0x00)
- #define TIM3_DIER *(uint32_t*)(0x40000400+0x0C)
- #define TIM3_SR *(uint32_t*)(0x40000400+0x10)
- #define TIM3_PSC *(uint32_t*)(0x40000400+0x28)
- #define TIM3_ARR *(uint32_t*)(0x40000400+0x2C)
- #if 1
- int m = 0;
- void EXTI9_5_IRQHandler(void)
- EXTI_PR = 0x1 << 7;
- m++;
- if(m%2 == 1)
- GPIOC_ODR = 0x0 << 14;
- else if(m%2 == 0)
- GPIOC_ODR = 0x3 << 14;
- #endif
- char test_str[128];
- char* p;
- int i;
- volatile int mm = 0;
- volatile int old_mm = 0;
- char recv_buf[64];
- int num = 0;
- int is_one_line = 0;
- void USART1_IRQHandler(void)
- USART_ClearITPendingBit(USART1, USART_IT_RXNE);
- mm += 10;
- recv_buf[num++] = USART1_DR;
- if(num >= 64)
- num = 0;
- if(recv_buf[num-1] == 0x0a && recv_buf[num-2] == 0x0d)
- is_one_line = 1;
- int time1_out = 0;
- int old_time1_out= 0;
- #if 1
- void TIM1_UP_IRQHandler(void)
- TIM_ClearITPendingBit(TIM1, TIM_FLAG_Update);
- time1_out++;
- #else
- void TIM3_IRQHandler(void)
- TIM_ClearITPendingBit(TIM3, TIM_FLAG_Update);
- time1_out++;
- #endif
- int main()
- RCC_APB2ENR = 0x1 << 4 | 0x1 << 3 | 0x1 << 0 | 0x1 << 2 | 0x1 << 14 /*| 0x1 << 11 */ ; //p53
- GPIOC_CRH = 0x03 << 28 | 0x03 << 24; //p68
- GPIOB_CRL = 0x00 <<28 | /*0x01*/ /*0x10 --bug */0x02 << 30;
- GPIOC_ODR = 0x3 << 14; //p69
- EXTI_IMR = 0x01 << 7;
- //EXTI_RTSR = 0x01 << 7;
- EXTI_FTSR = 0x01 << 7;
- AFIO_EXTICR2 = 0x01 << 12;
- GPIOA_ODR = 0x1 << 9;
- GPIOA_CRH = 0x3 << 4 | 0x2 << 6 | 0x0 << 8 | 0x1 << 10;
- SETENA_ISER0 = 0x1 << 23;
- SETENA_ISER1 = 0x1 << 5;
- USART1_BRR = 0x0271;
- USART1_CR1 |= 0x03 << 2; //TE/RE
- USART1_CR1 |= 0x1 << 5 /* | 0x1 <<7*/;
- USART1_CR1 |= 0x1 << 13;
- #if 1
- RCC_APB2ENR |= (0x1 << 11);
- TIM1_CR1 |= 0x1 << 0; //CEN
- TIM1_DIER |= 0x1 << 0; //UIE
- TIM1_SR &= 0xFFFE; //UIF
- TIM1_PSC = 7199;
- TIM1_ARR = 9999;
- SETENA_ISER0 |= 0x01 << 25;
- #else
- RCC_APB1ENR |= 0x1 << 1;
- TIM3_CR1 |= 0x1 << 0; //CEN
- TIM3_DIER |= 0x1 << 0; //UIE
- TIM3_SR &= 0xFFFE; //UIF
- TIM3_PSC = 7199;
- TIM3_ARR = 9999;
- SETENA_ISER0 |= 0x01 << 29;
- #endif
- while(1)
- if(is_one_line == 1)
- memset(test_str, 0, sizeof(test_str));
- sprintf( test_str, "%s", recv_buf);
- p = test_str;
- while((*p)!='\0')
- USART_SendData(USART1, *(p++));
- for(i=0; i < 1000; i++)
- num = 0;
- is_one_line = 0;
- memset(recv_buf, 0, sizeof(recv_buf));
- if(old_time1_out == time1_out)
- else
- sprintf( test_str, "old: %d, time1_out:%d", old_time1_out, time1_out);
- p = test_str;
- while((*p)!='\0')
- old_time1_out = time1_out;
- return 0;
復(fù)制代碼 至此試驗(yàn)就告完成。用過(guò)仿真軟件Proteus(后來(lái)好象串口COMPIM失效了。)和編譯器Keil MDK5,表示謝意。
源文件打包在此:
test_timer.7z
(268.11 KB, 下載次數(shù): 8)
2021-9-8 15:57 上傳
點(diǎn)擊文件名下載附件
本文出自:www點(diǎn)zhishi-zhishi點(diǎn)net/working/stm32_timer.html
評(píng)分
查看全部評(píng)分
