已經調好,mini板,用即可
- #include "key4_4.h"
- #include "delay.h"
- #include "sys.h"
- //平臺:STM32F103
- //實驗名稱:不連續I/O矩陣鍵盤實驗
- //使用說明:矩陣鍵盤所用引腳都已經用宏定義定義好了,移植只需根據實際需要在key4_4.c中修改對應的時鐘、引腳和端口即可,其余都不用修改。
- //矩陣鍵盤所用的8個引腳可連續可不連續,看實際需要和個人愛好自己定義。
- int main(void)
- uart_init(9600);
- Key_Init();
- delay_init();
- printf("不連續I/O口矩陣鍵盤測試\r\n");
- while(1)
- Key_Test();
復制代碼- /*****接口如下
- C1---B9;C2-C4----B6 ;R1---B5;2----15;3---12;4---11
- #include "sys.h"
- //8個引腳 4個為行 4個為列
- //行輸出端口定義
- #define X1_GPIO_PORT GPIOA
- #define X2_GPIO_PORT GPIOA
- #define X3_GPIO_PORT GPIOA
- #define X4_GPIO_PORT GPIOB
- //列輸入端口定義
- #define Y1_GPIO_PORT GPIOB
- #define Y2_GPIO_PORT GPIOB
- #define Y3_GPIO_PORT GPIOB
- #define Y4_GPIO_PORT GPIOB
- //行輸出引腳定義
- #define X1_GPIO_PIN GPIO_Pin_11
- #define X2_GPIO_PIN GPIO_Pin_12
- #define X3_GPIO_PIN GPIO_Pin_15
- #define X4_GPIO_PIN GPIO_Pin_5
- //列輸入引腳定義
- #define Y1_GPIO_PIN GPIO_Pin_6
- #define Y2_GPIO_PIN GPIO_Pin_7
- #define Y3_GPIO_PIN GPIO_Pin_8
- #define Y4_GPIO_PIN GPIO_Pin_9
- //行輸出時鐘定義
- #define X1_RCC RCC_APB2Periph_GPIOA
- #define X2_RCC RCC_APB2Periph_GPIOA
- #define X3_RCC RCC_APB2Periph_GPIOA
- #define X4_RCC RCC_APB2Periph_GPIOB
- //列輸入時鐘定義
- #define Y1_RCC RCC_APB2Periph_GPIOB
- #define Y2_RCC RCC_APB2Periph_GPIOB
- #define Y3_RCC RCC_APB2Periph_GPIOB
- #define Y4_RCC RCC_APB2Periph_GPIOB
- //移植代碼只需要修改上面的端口和引腳和時鐘即可,下面的代碼不用修改。
- unsigned char Y1,Y2,Y3,Y4;
- void Key_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(X1_RCC|X2_RCC|X3_RCC|X4_RCC|Y1_RCC|Y2_RCC|Y3_RCC|Y4_RCC|RCC_APB2Periph_AFIO, ENABLE);
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
- // RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
- ////開啟AFIO時鐘
- //GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable,ENABLE);
- ////改變指定管腳的映射 GPIO_Remap_SWJ_Disable SWJ 完全禁用(JTAG+SW-DP)
- //GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
- ////改變指定管腳的映射 GPIO_Remap_SWJ_JTAGDisable ,JTAG-DP 禁用 + SW-DP 使能
- /*****************************4行輸出*********************************************/
- GPIO_InitStructure.GPIO_Pin = X1_GPIO_PIN ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(X1_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = X2_GPIO_PIN ;
- GPIO_Init(X2_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = X3_GPIO_PIN ;
- GPIO_Init(X3_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = X4_GPIO_PIN ;
- GPIO_Init(X4_GPIO_PORT, &GPIO_InitStructure);
- /**************************************4列輸入*************************************/
- GPIO_InitStructure.GPIO_Pin = Y1_GPIO_PIN ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
- GPIO_Init(Y1_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = Y2_GPIO_PIN ;
- GPIO_Init(Y2_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = Y3_GPIO_PIN ;
- GPIO_Init(Y3_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = Y4_GPIO_PIN;
- GPIO_Init(Y4_GPIO_PORT, &GPIO_InitStructure);
- int Key_Scan(void)
- uchar KeyVal;
- GPIO_SetBits(X1_GPIO_PORT,X1_GPIO_PIN); //先讓X1輸出高
- GPIO_SetBits(X2_GPIO_PORT,X2_GPIO_PIN); //先讓X2輸出高
- GPIO_SetBits(X3_GPIO_PORT,X3_GPIO_PIN); //先讓X3輸出高
- GPIO_SetBits(X4_GPIO_PORT,X4_GPIO_PIN); //先讓X4輸出高
- if((GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN)|GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN)|GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN)|GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN))==0x0000)
- return -1; //如果X1到X4全為零則沒有按鍵按下
- else
- delay_ms(5); //延時5ms去抖動
- return -1;
- GPIO_ResetBits(X1_GPIO_PORT,X1_GPIO_PIN);
- GPIO_ResetBits(X2_GPIO_PORT,X2_GPIO_PIN);
- GPIO_ResetBits(X3_GPIO_PORT,X3_GPIO_PIN);
- Y1=GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN);Y2=GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN);
- Y3=GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN);Y4=GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN);
- if(Y1==1&&Y2==0&&Y3==0&&Y4==0)
- KeyVal='*';
- if(Y1==0&&Y2==1&&Y3==0&&Y4==0)
- KeyVal=0;
- if(Y1==0&&Y2==0&&Y3==0&&Y4==1)
- KeyVal='D';
- if(Y1==0&&Y2==0&&Y3==1&&Y4==0)
- KeyVal='#';
- while(((GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN))|(GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN))|(GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN))|(GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN))) > 0);
- //等待按鍵釋放
- GPIO_ResetBits(X4_GPIO_PORT,X4_GPIO_PIN);
- KeyVal=1;
- KeyVal=2;
- KeyVal=3;
- KeyVal='A';
- KeyVal=4;
- KeyVal=5;
- KeyVal=6;
- KeyVal='B';
- KeyVal=7;
- KeyVal=8;
- KeyVal=9;
- KeyVal='C';
- return KeyVal;
- 按鍵表盤為: 1 2 3 A
- 4 5 6 B
- 7 8 9 C
- * 0 # D
- void Key_Test(void)
- int num;
- num = Key_Scan();
- switch(num)
- case 0: printf("0\n"); break;
- case 1: printf("1\n"); break;
- case 2: printf("2\n"); break;
- case 3: printf("3\n"); break;
- case 4: printf("4\n"); break;
- case 5: printf("5\n"); break;
- case 6: printf("6\n"); break;
- case 7: printf("7\n"); break;
- case 8: printf("8\n"); break;
- case 9: printf("9\n"); break;
- case 'A': printf("A\n"); break;
- case 'B': printf("B\n"); break;
- case 'C': printf("C\n"); break;
- case 'D': printf("D\n"); break;
- case '#': printf("#\n"); break;
- case '*': printf("*\n"); break;
代碼下載:
代碼Keil.7z
(182.25 KB, 下載次數: 21)
2021-9-7 23:45 上傳
下載積分: 黑幣 -5
