2021-8-27 04:24 上傳
- // LCD module connections
- sbit LCD_RS at RB2_bit;
- sbit LCD_EN at RB3_bit;
- sbit LCD_D4 at RB4_bit;
- sbit LCD_D5 at RB5_bit;
- sbit LCD_D6 at RB6_bit;
- sbit LCD_D7 at RB7_bit;
- sbit LCD_RS_Direction at TRISB2_bit;
- sbit LCD_EN_Direction at TRISB3_bit;
- sbit LCD_D4_Direction at TRISB4_bit;
- sbit LCD_D5_Direction at TRISB5_bit;
- sbit LCD_D6_Direction at TRISB6_bit;
- sbit LCD_D7_Direction at TRISB7_bit;
- // End LCD module connections
- unsigned short read_ds1307(unsigned short address)
- unsigned short r_data;
- I2C1_Start();
- I2C1_Wr(0xD0); //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0
- I2C1_Wr(address);
- I2C1_Repeated_Start();
- I2C1_Wr(0xD1); //0x68 followed by 1 --> 0xD1
- r_data=I2C1_Rd(0);
- I2C1_Stop();
- return(r_data);
- void write_ds1307(unsigned short address,unsigned short w_data)
- I2C1_Start(); // issue I2C start signal
- //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0
- I2C1_Wr(0xD0); // send byte via I2C (device address + W)
- I2C1_Wr(address); // send byte (address of DS1307 location)
- I2C1_Wr(w_data); // send data (data to be written)
- I2C1_Stop(); // issue I2C stop signal
- unsigned char BCD2UpperCh(unsigned char bcd)
- return ((bcd >> 4) + '0');
- unsigned char BCD2LowerCh(unsigned char bcd)
- return ((bcd & 0x0F) + '0');
- int Binary2BCD(int a)
- int t1, t2;
- t1 = a%10;
- t1 = t1 & 0x0F;
- a = a/10;
- t2 = a%10;
- t2 = 0x0F & t2;
- t2 = t2 << 4;
- t2 = 0xF0 & t2;
- t1 = t1 | t2;
- return t1;
- int BCD2Binary(int a)
- int r,t;
- t = a & 0x0F;
- r = t;
- a = 0xF0 & a;
- t = a >> 4;
- t = 0x0F & t;
- r = t*10 + r;
- return r;
- int second;
- int minute;
- int hour;
- int hr;
- int day;
- int dday;
- int month;
- int year;
- int ap;
- unsigned short set_count = 0;
- short set;
- char time[] = "00:00:00 PM";
- char date[] = "00-00-00";
- void main()
- I2C1_Init(100000); //DS1307 I2C is running at 100KHz
- CMCON = 0x07; // To turn off comparators
- ADCON1 = 0x06; // To turn off analog to digital converters
- TRISA = 0x07;
- PORTA = 0x00;
- Lcd_Init(); // Initialize LCD
- Lcd_Cmd(_LCD_CLEAR); // Clear display
- Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
- Lcd_out(1,1,"Time:");
- Lcd_out(2,1,"Date:");
- do
- set = 0;
- if(PORTA.F0 == 0)
- Delay_ms(100);
- if(PORTA.F0 == 0)
- set_count++;
- if(set_count >= 7)
- set_count = 0;
- if(set_count)
- if(PORTA.F1 == 0)
- Delay_ms(100);
- if(PORTA.F1 == 0)
- set = 1;
- if(PORTA.F2 == 0)
- Delay_ms(100);
- if(PORTA.F2 == 0)
- set = -1;
- if(set_count && set)
- switch(set_count)
- case 1:
- hour = BCD2Binary(hour);
- hour = hour + set;
- hour = Binary2BCD(hour);
- if((hour & 0x1F) >= 0x13)
- hour = hour & 0b11100001;
- hour = hour ^ 0x20;
- else if((hour & 0x1F) <= 0x00)
- hour = hour | 0b00010010;
- write_ds1307(2, hour); //write hour
- break;
- case 2:
- minute = BCD2Binary(minute);
- minute = minute + set;
- if(minute >= 60)
- minute = 0;
- if(minute < 0)
- minute = 59;
- minute = Binary2BCD(minute);
- write_ds1307(1, minute); //write min
- break;
- case 3:
- if(abs(set))
- write_ds1307(0,0x00); //Reset second to 0 sec. and start Oscillator
- break;
- case 4:
- day = BCD2Binary(day);
- day = day + set;
- day = Binary2BCD(day);
- if(day >= 0x32)
- day = 1;
- if(day <= 0)
- day = 0x31;
- write_ds1307(4, day); // write date 17
- break;
- case 5:
- month = BCD2Binary(month);
- month = month + set;
- month = Binary2BCD(month);
- if(month > 0x12)
- month = 1;
- if(month <= 0)
- month = 0x12;
- write_ds1307(5,month); // write month 6 June
- break;
- case 6:
- year = BCD2Binary(year);
- year = year + set;
- year = Binary2BCD(year);
- if(year <= -1)
- year = 0x99;
- if(year >= 0x50)
- year = 0;
- write_ds1307(6, year); // write year
- break;
- second = read_ds1307(0);
- minute = read_ds1307(1);
- hour = read_ds1307(2);
- hr = hour & 0b00011111;
- ap = hour & 0b00100000;
- dday = read_ds1307(3);
- day = read_ds1307(4);
- month = read_ds1307(5);
- year = read_ds1307(6);
- time[0] = BCD2UpperCh(hr);
- time[1] = BCD2LowerCh(hr);
- time[3] = BCD2UpperCh(minute);
- time[4] = BCD2LowerCh(minute);
所有資料51hei附件下載:
Digital-Clock.zip
(308.52 KB, 下載次數: 31)
2021-8-26 23:18 上傳
RTC 下載積分: 黑幣 -5
