查看: 2646|回復: 0
bilibili信息獲取器 python語言
ID:831441 發(fā)表于 2021-8-22 10:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我用的是python語言
  • 這個bilibili粉絲獲取器可以獲取bilibili up主的很多信息,只要你一運行代碼,他就會讓你輸入要查詢的up主的UID,就可以了,還有一些功能我還未開發(fā),敬請期待!!!
  1. #python
  2. import requests #導入requests庫
  3. import json #導入json庫
  4. date = input("UID:") #將date變量設為屏幕輸入內容
  5. UID = int(date) #將date變量轉換整型常量,并把它設為UID的值
  6. print("請輸入你想了解的UP主的信息(填序號)")
  7. print("1.名字")
  8. print("2.UID")
  9. print("3.性別")
  10. print("4.簽名")
  11. print("5.LV等級")
  12. print("6.認證")
  13. print("7.是否成為大會員")
  14. print("8.粉絲數")
  15. print("9.生成報告")
  16. date = input()
  17. dateint = int(date)
  18. if dateint == 1:
  19.     URL = requests.get('https://api.bilibili.com/x/web-interface/card?mid=%d' % (UID)) #訪問bilibili的api獲取值
  20.     jsondate = json.loads(URL.text) #把json數據轉換成字典,字典名稱為jsondate
  21.     name = jsondate['data']['card']['name']
  22.     print(name)
  23. if dateint == 2:
  24.     URL = requests.get('https://api.bilibili.com/x/web-interface/card?mid=%d' % (UID))
  25.     jsondate = json.loads(URL.text)
  26.     mid = jsondate['data']['card']['mid']
  27.     print(mid)
  28. if dateint == 3:
  29.     URL = requests.get('https://api.bilibili.com/x/web-interface/card?mid=%d' % (UID))
  30.     jsondate = json.loads(URL.text)
  31.     sex = jsondate['data']['card']['sex']
  32.     print(sex)
  33. if dateint == 4:
  34.     URL = requests.get('https://api.bilibili.com/x/web-interface/card?mid=%d' % (UID))
  35.     jsondate = json.loads(URL.text)
  36.     sign = jsondate['data']['card']['sign']
  37.     if sign == "":
  38.         print("無數據")
  39.     else:
  40.         print(sign)
  41. if dateint == 5:
  42.     URL = requests.get('https://api.bilibili.com/x/web-interface/card?mid=%d' % (UID))
  43.     jsondate = json.loads(URL.text)
  44.     level = jsondate['data']['card']['level_info']['current_level']
  45.     print(level)
  46. if dateint == 6:
  47.     URL = requests.get('https://api.bilibili.com/x/web-interface/card?mid=%d' % (UID))
  48.     jsondate = json.loads(URL.text)
  49.     Authentication = jsondate['data']['card']['Official']['title']
  50.     if Authentication == "":
  51.         print("無數據")
  52.     else:
  53.         print(Authentication)
  54. if dateint == 7:
  55.     URL = requests.get('https://api.bilibili.com/x/web-interface/card?mid=%d' % (UID))
  56.     jsondate = json.loads(URL.text)
  57.     vip = jsondate['data']['card']['vip']['vipType']
  58.     if vip == 0:
  59.         print("False")
  60.     else:
  61.         print("True")
  62. if dateint == 8:
  63.     URL = requests.get('https://api.bilibili.com/x/web-interface/card?mid=%d' % (UID))
  64.     jsondate = json.loads(URL.text)
  65.     fans = jsondate['data']['follower']
  66.     print(fans)
  67. if dateint == 9:
  68.     URL = requests.get('https://api.bilibili.com/x/web-interface/card?mid=%d' % (UID))
  69.     jsondate = json.loads(URL.text)
  70.     name = jsondate['data']['card']['name']
  71.     mid = jsondate['data']['card']['mid']
  72.     sex = jsondate['data']['card']['sex']
  73.     sign = jsondate['data']['card']['sign']
  74.     level = jsondate['data']['card']['level_info']['current_level']
  75.     Authentication = jsondate['data']['card']['Official']['title']
  76.     vip = jsondate['data']['card']['vip']['vipType']
  77.     fans = jsondate['data']['follower']
  78.     print("用戶名稱:")
  79.     print(name)
  80.     print("")
  81.     print("用戶UID:")
  82.     print(mid)
  83.     print("")
  84.     print("用戶性別:")
  85.     print(sex)
  86.     print("")
  87.     print("用戶簽名:")
  88.     if sign == "":
  89.         print("無數據")
  90.     else:
  91.         print(sign)
  92.     print("")
  93.     print("用戶等級:")
  94.     print(level)
  95.     print("")
  96.     print("用戶認證:")
  97.     if Authentication == "":
  98.         print("無數據")
  99.     else:
  100.         print(Authentication)
  101.     print("")
  102.     print("是否成為大會員:")
  103.     if vip == 0:
  104.         print("False")
  105.     else:
  106.         print("True")
  107.     print("")
  108.     print("用戶粉絲:")
  109.     print(fans)
參與人數 1黑幣 +20 收起 理由
admin + 20 共享資料的黑幣獎勵!
