查看: 3090|回復: 0
stm32智能小車制作 舵機超聲波程序
ID:955119 發(fā)表于 2021-7-30 13:19 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
制作出來的實物圖如下:
STM32單片機源程序如下:
****************************超聲波避障模*******************************************************
float disleft,disright;
void Wave_BZ(void)
            int i;
            Distance = Wave_Start();    //超聲波測距存到Wave_Start() 函數(shù)中
            SG90_Front;                       //舵機轉向正前方
            delay_ms(700);
           if(Distance>80)                 //若距離大于80cm
                  forward();                //車輛繼續(xù)直行
            for(i = 0; i <= 300; i++)                   //速度不斷上升
                        TIM_SetCompare2(TIM3, i);
                        TIM_SetCompare3(TIM3, i);
                else                                              //若距離小于80cm
                stop();                                        //車子停下來
                TIM_SetCompare2(TIM3,0);         //電機pwm為0
                TIM_SetCompare3(TIM3,0);
                SG90_Right_45;                       //舵機右轉測距
                delay_ms(900);
                disright=Wave_Start();
                //printf("right:%f cm\r\n",disright);            //可打印串口
                SG90_Left_45;                                        //舵機左轉測距
                delay_ms(900);
                disleft=Wave_Start();
               delay_ms(900);
                        if(disleft>=disright)                         //若左邊距離大于右邊距離,左轉
                                do
                                         delay_ms(10);
                                        delay_ms(10);
                                        Turn_Left();
                                        TIM_SetCompare3(TIM3,450);
                                        while(Distance<50);                   //距離小于50cm,停下來超聲波測距
                                else        if(disleft<disright)          //若右邊距離大于左邊距離,右轉
                                do
                                        delay_ms(10);
                                        delay_ms(10);
                                        Turn_Right();
                                        TIM_SetCompare2(TIM3,450);
*************************************電機模塊*****************************************************
#include "motor.h"
void Motor_Init(void)
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);  //使能時鐘
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽輸出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //速度50Mhz
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_ResetBits(GPIOA, GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
void forward(void)                          //前進
      M1=0;M2=1;  M3=0;M4=1;
      M5=0;M6=1;  M7=0;M8=1;
void back(void)                             //后退
      M1=1;M2=0;  M3=1;M4=0;
            M5=1;M6=0;  M7=1;M8=0;
void Turn_Right(void)                //右轉
    M1=0;M2=1;  M3=1;M4=1;
          M5=0;M6=1;  M7=1;M8=1;
void Turn_Left(void)                //左轉
    M1=1;M2=1;  M3=0;M4=1;
          M5=1;M6=1;  M7=0;M8=1;
void stop(void)                       //停止
    M1=1;M2=1;  M3=1;M4=1;
          M5=1;M6=1;  M7=1;M8=1;
***********************************主函數(shù)**********************************************************
#include "key.h"
#include "delay.h"
#include "led.h"
#include "ultrasonic.h"   //超聲波
#include "motor.h"       //電機
#include "Engine.h"     //舵機
#include "pwm.h"        //電機pwm
int main()
         TIM3_PWM_Init(899,0);        //電機pwm初始化
         Motor_Init();                       //電機初始化
         Wave_IO_Init();                 //  超聲波初始化
         sg90_Init();                       //舵機初始化
         delay_init();
                 Wave_BZ();           //超聲波+舵機避障
全部代碼51hei附件下載:
stm32f103智能小車超聲波加舵機.7z (188.31 KB, 下載次數(shù): 56)
參與人數(shù) 1黑幣 +50 收起 理由
收藏收藏3 分享淘帖 頂 踩
