查看: 3125|回復: 0
交通燈 51單片機+proteus仿真
ID:955647 發表于 2021-7-28 20:35 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
sbit smg1 =P1^1;
sbit smg2 =P1^0; //定義共陽極數碼管引腳
sbit red2=P1^5;
sbit yellow2=P1^6;
sbit green2=P1^7; //東西路紅綠燈
sbit red1=P1^2;
sbit yellow1=P1^3;
sbit green1=P1^4; //南北路紅路燈
sbit k1=P3^2;  //南北禁行
sbit k2=P3^3;  //東西禁行
sbit k3=P3^4;   //全部禁行
sbit k4=P3^5;    //紅路燈時間減
sbit k5=P3^6;    //紅路燈時間加
uchar code s7_table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};  //共陽極數碼管鍵選
uint time=0;
uchar i;
void delay_ms(uchar z)    // 延時
    uchar i,j;
        for(i=z;i>0;i--)
            for(j=110;j>0;j--);
void display_time(uchar num)   //顯示倒計時
        smg1=0;
        P2=s7_table[num/10];
        delay_ms(2);
        P2=0;
        smg1=1;
        smg2=0;
        P2=s7_table[num%10];
        delay_ms(2);
        P2=0;
        smg2=1;
void keypro()
           if(k1 == 0)  //nan  bei ban
      delay_ms(10);
      if(k1 == 0)
                                red1=0;
                                yellow1=1;
                                green1=1;
                                red2=1;
                                yellow2=1;
                                green2=0;
                        while(!k1);
         if(k2 ==0 )     // dong xi ban
                 delay_ms(10);
                 if(k2 == 0)
                         red1=1;
                                yellow1=1;
                                green1=0;
                                red2=0;
                                yellow2=1;
                                green2=1;
                 while(!k2);
                 if(k3==0)   // all ban
                         delay_ms(10);
                         if(k3 == 0)
                         red1=0;
                                yellow1=1;
                                green1=1;
                                red2=0;
                                yellow2=1;
                                green2=1;
                         while(!k3);
                 if(k4==0)    // --
                         delay_ms(10);
                         if(k4==0)
                                 time=time+1;
                         while(!k4);
                  if(k5==0)  // ++
                         delay_ms(10);
                         if(k5==0)
                                 time=time-1;
                         while(!k5);
           EA=1;
        ET0=1;
        TMOD=0X01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TR0=1;
                 keypro();
                        if(time<60)
                        display_time(61-time);
                        red2=0;
                        green2=1;
                        yellow2=1;
                        red1=1;
                        green1=0;
                        yellow1=1;
                else if(time>60&&time<64  )
                                 display_time(63-time);
                                red1=1;
                                yellow1=0;
                                green1=1;
                                 red2=1;
                            yellow2=0;
                                green2=1;
                        else if(time<84&&time>64)
                                display_time(84-time);
                                red2=1;
                                green2=0;
                                red1=0;
                                green1=1;
                                yellow2=1;
                                yellow1=1;
                if(time==84)
                        time=0;
void_int0_isr() interrupt 1
        i++;
        if(i==20)
        i=0;
        ++time;
