查看: 3416|回復: 0
TM4C123 GXL庫+MAX7219點陣C語言驅動
#ifndef __U_MAX7219_H__
#define __U_MAX7219_H__
/*Include==================================================================================*/
#include <stdbool.h>
#include <stdint.h>
#include "inc/hw_memmap.h"
#include "driverlib/debug.h"
#include "driverlib/gpio.h"
#include "driverlib/rom.h"
#include "driverlib/sysctl.h"
/*Define===================================================================================*/
/*Port----------------------------------------*/
#define Max7219_pinCS_H()        GPIOPinWrite(GPIO_PORTD_BASE,GPIO_PIN_1,GPIO_PIN_1)
#define Max7219_pinCS_L()        GPIOPinWrite(GPIO_PORTD_BASE,GPIO_PIN_1,0)
#define Max7219_pinCLK_H()        GPIOPinWrite(GPIO_PORTD_BASE,GPIO_PIN_2,GPIO_PIN_2)
#define Max7219_pinCLK_L()        GPIOPinWrite(GPIO_PORTD_BASE,GPIO_PIN_2,0)
#define Max7219_pinDIN_H()        GPIOPinWrite(GPIO_PORTD_BASE,GPIO_PIN_3,GPIO_PIN_3)
#define Max7219_pinDIN_L()        GPIOPinWrite(GPIO_PORTD_BASE,GPIO_PIN_3,0)
/*Function=================================================================================*/
void Write_Max7219_byte(uint8_t DATA);
void Write_Max7219(uint8_t address,uint8_t dat);
void Init_MAX7219(void);
void U_8X8_Lattice_Show_Byte(uint8_t addres,uint8_t byteData);
void U_8X8_Lattice_Show_Icon(uint8_t *icon);
#endif /*__U_MAX7219_H__*/
#include "U_MAX7219.h"
void Write_Max7219_byte        /*向MAX7219傳輸1Byte*/
        uint8_t DATA                /*1Byte數據*/
        uint8_t i;
        Max7219_pinCS_L();
        for(i=8;i>=1;i--)
                Max7219_pinCLK_L();
                if(DATA & 0x80)
                        Max7219_pinDIN_H();
                        Max7219_pinDIN_L();
                DATA=DATA<<1;
                Max7219_pinCLK_H();
void Write_Max7219                                        /*向MAX7219的寄存器寫入數據*/
        uint8_t address,                                 /*MAX7219的寄存器地址*/
        uint8_t dat                                                /*要寫入的內容*/
     Max7219_pinCS_L();
         Write_Max7219_byte(address);        //寫入地址,即數碼管編號
     Write_Max7219_byte(dat);            //寫入數據,即數碼管顯示數字
         Max7219_pinCS_H();
void Init_MAX7219(void)                                 /*MAX7219初始化*/
        uint32_t i;
        Write_Max7219(0x09, 0x00);               //譯碼方式:BCD碼
        Write_Max7219(0x0a, 0x02);               //亮度
        Write_Max7219(0x0b, 0x07);               //掃描界限;8個數碼管顯示
        Write_Max7219(0x0c, 0x01);               //掉電模式:0,普通模式:1
        Write_Max7219(0x0f, 0x00);               //顯示測試:1;測試結束,正常顯示:0
        /*清空MAX7219數據寄存器*/
        for(i=1;i<9;i++)
                Write_Max7219(i,0x00);
        if((byteData & 0x01) == 1)
                byteData = byteData ;
                byteData |= 0x80;
        Write_Max7219(addres,byteData);
        uint32_t i;
        for(i=1;i<9;i++)
                U_8X8_Lattice_Show_Byte(i,icon[i-1]);
#include <stdint.h>
uint32_t systemClock;
uint8_t disl[14][8]=
{0x00,0x08,0x14,0x28,0x28,0x14,0x08,0x00},
{0x08,0x14,0x22,0x44,0x44,0x22,0x14,0x08},
{0x1E,0x3F,0x7F,0xFE,0xFE,0x7F,0x3F,0x1E},
{0x00,0x1E,0x20,0x3C,0x3C,0x20,0x1E,0x00},
{0x00,0x42,0x24,0x18,0x18,0x24,0x42,0x00},
{0x00,0x00,0x02,0x04,0x78,0x04,0x02,0x00},
{0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00},
{0x00,0x00,0x18,0x3C,0x3C,0x18,0x00,0x00},
{0x00,0x18,0x3C,0x7C,0x7C,0x3C,0x18,0x00},
{0x0C,0x1E,0x3E,0x7C,0x7C,0x3E,0x1E,0x0C},
{0x00,0x00,0x3E,0x08,0x08,0x3E,0x00,0x00},
{0x00,0x00,0x12,0x22,0x3E,0x02,0x02,0x00},
//! \addtogroup example_list
//! <h1>Simple Project (project)</h1>
//! A very simple example that can be used as a starting point for more complex
//! projects.  Most notably, this project is fully TI BSD licensed, so any and
//! all of the code (including the startup code) can be used as allowed by that
//! license.
//! The provided code simply toggles a GPIO using the Tiva Peripheral Driver
//! Library.
// The error routine that is called if the driver library encounters an error.
// Toggle a GPIO.
void U_GPIO_Init(void)
           SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
     SysCtlDelay(1);
                GPIOPinTypeGPIOOutput(GPIO_PORTD_BASE,GPIO_PIN_1);
                GPIOPinTypeGPIOOutput(GPIO_PORTD_BASE,GPIO_PIN_3);
                GPIOPinTypeGPIOOutput(GPIO_PORTD_BASE,GPIO_PIN_2);
int main(void)
        uint8_t n;
        U_GPIO_Init();
        SysCtlDelay(5000000);
        U_GPIO_Init();
        Init_MAX7219();
         U_8X8_Lattice_Show_Icon(displ[10]);
        for(n=0;n<14;n++)
                             U_8X8_Lattice_Show_Icon(disl[n]);
這2個C語言文件下載: TI-MAX7219.rar (3.09 KB, 下載次數: 7)
admin + 50 回帖助人的獎勵!
