查看: 3106|回復: 0
4x4矩陣陣鍵盤小程序
ID:37685 發表于 2013-9-5 13:28 | 顯示全部樓層 |閱讀模式
控制4x4矩陣鍵盤,當1號鍵按下以后數碼管顯示1,2號鍵按下時顯示2,...,當10號按鍵按下時顯示A,...,當15號按鍵按下時顯示F,當16號鍵按下時顯示 error,而初次開機的時候顯示 HELLO...
#include<reg52.h>
#define uint  unsigned int
uchar code smg_duan[]={0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar code smg_wei[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
uchar code smg_open[]={0x80,0x80,0x80,0x3f,0x38,0x38,0x79,0x76};
uchar code smg_error[]={0x50,0x5c,0x50,0x50,0x79};
void delay(uint);
uchar keyscan();
void error_display();
void open_display();
sbit C_JA=P2^0;
sbit C_JB=P2^1;
uchar keyboard,num;
  num=17;
  C_JA=0;
  C_JB=0;
  P1=0x7f;
  C_JA=1;
  C_JA=0;
  while(num==17)
    open_display();
    keyscan();
    if(num==15)
      error_display();
    P1=0x7f;
    C_JA=1;
    C_JA=0;
    P1=smg_duan[num];
    C_JB=1;
    C_JB=0;
    keyscan();
uchar keyscan()
  P0=0xfe;
  keyboard=P0;
  keyboard=keyboard&0xf0;
  if(keyboard!=0xf0)
    delay(6);
    keyboard=P0;
    if(keyboard!=0xf0)
      switch(keyboard)
        case 0xe0:num=3;
        break;
        case 0xd0:num=2;
        break;
        case 0xb0:num=1;
        break;
        case 0x70:num=0;
        break;
  P0=0xfd;
  keyboard=P0;
  if(keyboard!=0xf0)
    delay(6);
    keyboard=P0;
    if(keyboard!=0xf0)
      switch(keyboard)
        case 0xe0:num=7;
        break;
        case 0xd0:num=6;
        break;
        case 0xb0:num=5;
        break;
        case 0x70:num=4;
        break;
  P0=0xfb;
  keyboard=P0;
  if(keyboard!=0xf0)
    delay(6);
    keyboard=P0;
    if(keyboard!=0xf0)
      switch(keyboard)
        case 0xe0:num=11;
        break;
        case 0xd0:num=10;
        break;
        case 0xb0:num=9;
        break;
        case 0x70:num=8;
        break;
  P0=0xf7;
  keyboard=P0;
  if(keyboard!=0xf0)
    delay(6);
    keyboard=P0;
    if(keyboard!=0xf0)
      switch(keyboard)
        case 0xe0:num=15;
        break;
        case 0xd0:num=14;
        break;
        case 0xb0:num=13;
        break;
        case 0x70:num=12;
        break;
   return num;
  uchar i;
  for(i=0;i<5;i++)
    P1=smg_wei[i];
    C_JA=1;
    C_JA=0;
    P1=smg_error[i];
    C_JB=1;
    C_JB=0;
    delay(3);
    P1=0x00;
    C_JB=1;
    C_JB=0;
void open_display()
  uchar i;
  for(i=0;i<8;i++)
    P1=smg_wei[i];
    C_JA=1;
    C_JA=0;
    P1=smg_open[i];
    C_JB=1;
    C_JB=0;
    delay(4);
    P1=0x00;
    C_JB=1;
    C_JB=0;
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
   for(y=70;y>0;y--);
