General Description The SL8411 is an average current mode control LED driver IC operating in a constant off-time mode. SL8411 does not produce a peak-to-average error, and therefore greatly improves accuracy, line and load regulation of the LED current without any need for loop compensation or high-side current sensing. The output LED current accuracy is ±2%. The SL8411 can be powered from an 8.0 - 100V supply. PWM & Linear dimming input is provided
2021-7-20 15:37 上傳
2021-7-20 15:38 上傳
